- 65 F85 cutlass rear bumper
- Chrome antenna nut 64-66 F85 442
- Oem dipstick tube used or nos 455
- NOS Passenger Side front wheel well molding
- 69 Olds Cutlass L-R trunk drop off panels wanted
- 70-72 Convertible rear interior upper panel - Cores
- Wanted, a 1968 manual transmission 400 crankshaft.
- WTB: 1964 Cutlass hood letter I
- 1972 Cutlass Supreme Front Driver Side Innner Wheel well
- NOS Oil Pan
- 62 rear bumper
- 1974 Delta 88 headlight bezels
- 62 Starfire bracket
- 1968 w30 air cleaner
- 2 1970 442 Tail Light Lenses
- 56 Olds windshield
- looking for a damaged aftermarket Ram Air pin on hood
- WTB 7040257 quadrajet
- 7040253 Carb
- WTB 1968 Spark plug wires bracket
- 1970 Cutlass Holiday Sedan (4-Door) Trim
- Harmonic balancer 1957-58 Olds
- 1972 Cutlass Driver side amber Marker light
- Factory Harmonic Balancer for a 350 Engine
- WTB set of 14x7 SSII rims
- 61-63 oldsmobile f85 gas tank wanted
- Looking for 1972 Cutlass Steering Wheel
- 425 connecting rods
- *Wanted - 1965 442 Carb Spacer Bracket
- 1970 Black Front Floor Mats
- 1970-72 Radio Block Off / “Delete” Plate
- 1968 Cutlass Vent window and ignition wires bracket
- NOS 40713 / 6470331 Fuel Pump
- 1964-1967 Oldsmobile-GM split bench seat
- 1988 307 7A Olds heads
- Dash needed
- In need of 1970 olds cutlass s parts
- 67 Holiday coupe Cutlass-442 left quarter
- 66 cutlass hood
- Sheet metal speed nuts
- ‘70 442 NOS Door Jamb Switch(s)
- 81-87 Rochester 307 Carb Bracket
- 371 4-bbl manifold
- seat back hanger
- 330 flywheel
- 1949 hood release
- 69 442 rear bumper brackets
- 66/67 inside ac box
- 57 olds L/F spindle
- Wtb: 1965 cutlass/f85 upper door trim
- 1966/67 4 door hardtop vent window needed
- Wanted - NOS 72 Conv Pillar Weatherstrips
- 390327 intake
- trim for '79 Olds 98 2 door and fender ('77 and '78 also?)
- 1964 394 2 barrel carburetor
- Need 1 Goodyear Speedway 1970 Pace Car Tire
- Wanted 72 cutlass upper tail light only NOS 5965249
- 260/307 accelerator bracket
- BBO victor intake
- 1969 cutlass S Convertible door
- Wanted
- 455 and th400 parts needed
- 70-72 dash pad
- 215 Valve Cover / Offenhauser wanted
- 1948-49 Olds 98
- FNG TexasCutty85
- 53 Oldsmobile
- 1970 convertible driver door shell
- 71-72 442 Fender Wells
- 64 F85 passenger side trim
- 1967 442 Choke Coil, rod and housing
- ISO 68-70 rear PS bracket
- ISO 68-70 AC Alternator bracket 398667
- Clutch Linkage Wanted
- Still on the hunt...🙄
- 7040250 Carb
- Needed used Dual plane intake for short deck 350
- 1972 cutlass core support
- American Racing Headers SBO
- Need a Power Steering Pulley #1246472
- Spiral shocks for '70 442
- 1965 442 A/C strut
- Special Pilot Bearing - Automatic to Manual
- 1970 #6 350 Heads
- WTB: 1980-90 Custom Cruiser tailgate window outside sweep seal
- W-31 carb
- Wanted 68 442 parts - trunk lid, bumper, more
- 1965 Delta 88 coupe parts - hood spear, bumpers
- Tv cable bracket
- 67 cutlass wiper part
- 71/ Cutlass Bumper needed
- Set of Kooks headers
- Need 65 full size steering column rag joint flange
- 57 58 olds
- CRAGAR SS or Keystone Classic 15x10 5.5 backspace 5x4.75 rims
- Need 71 Supreme Conv top frame
- 66/67 lower 1/4 patches
- 1975 Cutlass Supreme Rear Driver Quarter
- In search of 67 Cutlass or 442 driver side quarter panel
- WTB Kooks headers for BBO
- 1951 olds 98
- WTB 1100879 37A alternator.
- looking for a 384786 water pump
- WTB mid 50s 324 Engine
- WTB: Green steering wheel for ‘76 Cutlass Supreme
- 1977-79
- Looking for O4B manifold
- WTB: 1977-85 Custom Cruiser Header Panel Emblem
- Olds tachometer
- ISO 1956 Back Up light assembly
- 1968-69 442 drip rail molding
- 1972 Cutlass door molding
- 1967 cutlass
- Carburetor
- Wanted: 1100797 Alternator
- Hei
- ISO KK & KH pulleys
- Horns needed
- 1 C head
- Wanted: NOS 404896 Steel Head Gasket for 350
- '48 Olds 98
- 1965-67 Cutlass engine oil dipstick wanted
- WTB: 1959/1960 a/c belt tensioner
- Single head in Texas
- WTB Edelbrock performer 350 intake
- window felts 72 Supreme
- Seat Cover
- 62 cutlass oil slinger
- Looking for 73 olds omega
- NOS Front cross bar bushing (side) GM#579067
- #4, #5, #6 heads
- Wanted 1971-72 MT Speedo adapter
- Power Steering pump
- 1969-70 B/C body Exhaust Hangers
- 1971 442 Window Channel
- 390327 intake
- Bench seat
- ISO short headers for 455 engine
- Oldsmobile Aluminum Valve Covers
- NOS Bumper Guards for '84 Toronado
- 1968 hood rear vent grille
- 70 442 Turbo 400 Vacuum Modulator 8623365
- Stock 425 Rods
- 70 Tick-Tock-Tac Housing
- Wanted: '77 Cutlass non-tilt/telescoping steering column
- Toronado
- 66 cutlass firewall accessory grommet 392199
- 69 cutlass door panel
- 1969 H/O - 442 or Cutlass backup lights
- Wanted: 1966 Olds 98 4 door Luxury Sedan front doors
- 1967 do red window cranks
- Door pull strap end cap
- WTB 455 alum intake
- Rear drums 55 olds
- Turbo 400 Trans.
- 1962 Oldsmobile 9.3 Rear Drum Brakes
- 1988 Cutlass Supreme
- 1968 Oldsmobile 442 D/F Fender
- Need a SBO 350.
- Wanted: aluminum intake manifold, casting number 406115
- WTB | 4L80e Transmission
- 350 or 403 near phoenix.
- 1942 harmonic balancer
- 1973-1975 Right Side Cutlass quarter panel skin
- 1964 f85 club coupe 442 rear Olds letters
- Need vista cruiser right passenger rear side window rear trim
- 4 Speed back drive
- '74 Omega Side Emblems
- 1968 1969 Cutlass power antenna parts
- 260- heads and intake
- Wire Harness
- WTB: 72 7042251 carb
- ‘70 442 Rear View Mirror
- Looking for oil fill tube and cap for a 66-tri carb set up.
- 394 exhaust manifold
- WTB 74-7 swivel bucket seat belts
- WTB 2bbl Rochester Carb for 70-72 350
- 2bbl Rochester Carb for 70-72 350
- WTB: 1990 Custom Cruiser Turbine Wheels
- Lug wrench / Tire iron with o stamp
- 1965 Oldsmobile Cutlass Reverse Light Bezels
- Need '53 Olds 98 fender skirts....Anyone?
- WTB NOS passenger 1970 cutlass hood trim
- 1967 442 Passenger side headlight bezel
- 65 cutlass etc. Power steering pump setup
- 1967 cutlass radiator
- Looking for 1 7/8 headers
- 1972 Seat belt Retractors
- Center Dash Ash Tray
- 1969 Rally Pac Cluster
- 72 Cutlass passenger side mirror
- WTB 41-42 front and rear bumpers
- 1948 FUTURAMA 98 License Plate Holder
- Looking for a 425 builder
- Looking to borrow a 70 cutlass hood
- 65 Cutlass F85 330 cubic engine transmission dip stick
- Tee handle
- 72 passenger side mirror
- 70-72 Intake Manifold 350/4bbl
- Grab Handle needed
- Looking for GM Deluxe Map Dome Light
- Looking for a POA valve for a 1973 98
- 64 cutlass
- 400/425 crank
- 1969 442 4 speed back drive linkage
- Power brake pedal for a 66 cutlass
- 1968 Glove box striker
- 1964 Dynamic 88 quarter panel
- 1964 Cutlass bumpers
- 1980 Cutlass Supreme Driver Side (LH) Headlight Surround
- Need Bumpers for 75 442
- 1957 Super 88 chrome trim piece
- 1965 Cutlass Dash
- 71olds cutlass split bench seat
- 68-72 driver side bucket seat track needed
- Door Pull Straps 1970 Olds Cutlass Conv.
- 67 Headlight Buckets
- Wanted Virgin 66-67 425 .921 Olds Engine
- WTB - 1967 Oldsmobile Front Skylight Glass
- 1968 cutlass supreme lens needed
- '65 Cutlass/442 Pass side partial QUARTER PANEL
- Wanted 14” red line tires
- 1977 Cutlass Supreme
- ISO: 1964 Olds 98 tail light
- 1970-72 Heater Control Applique / placard NOS
- Slip Yoke required for 1960 Hydra Matic
- 66-67 Cutlass Interior Front Headliner Trim
- 62 Starfire parts
- WTB: one 15x7 ss2 in Colorado/Wyoming/Kansas
- vent glass rivets
- 1972 nos 442 rear bumper
- 63 f85 windshield
- Instrument Cluster Lamp Sockets
- Head Bolts
- Oldsmobile 425 .921 Solid Lifters
- Late '69/early '70 deluxe retractable belts
- 70 442 looking for 455 Block
- NOS or Similar Condition Inner Fenders for 72 442
- Searching for 1970 Olds 442 Parts
- Looking for 1970 NA9 Emissions Pieces
- 2 Rear quarters , deck / trunk lid and 2 front fenders for 68 Cutlass Convertible
- 1965 Delta 88 Coupe Body trim
- 1974 Front Bumper Impact Strip
- 324 176t flywheel
- Horns
- 1970 455 Block & Crank
- Help finding 59 to 61 gm bucket seat driver cable
- Wheelwell trim 64 Cutlass
- 69 Cutlass 442 black bucket seat cover needed
- 1956 Starfire
