View Full Version : Parts Wanted
- Need Passenger side molding under quarter glass 69 442
- Harmonic Balancer for '60 371 low compression
- Need Brake drums for a 63 Ninety-Eight
- 71 Cutlass S parts
- 63 Starfire Heater Water Valve
- Help - Wanted 350 TH transmission pan
- 70 Cutlass S gold interior items needed
- need a nice set of 71 S grills asap.
- Headlight bezel
- 1970-1972 Cutlass Supreme Molding
- Hood for a 55 Olds
- 76 cruise transducer
- BOP TH350 Transmission in Souther California
- nice 1/4 emblem for 71 Ninety Eight
- 1970 to 72 Cutlass convertible shell
- WTB 1972 cutlass 442 Grille moulding
- 1960 Slip yoke 32 spline 1 11/16 diameter shaft
- VC roof rack
- dog dish hub caps
- 70 Cutlass SS1 wheels
- Need - Molding, right fender, eyebrow above headlight,
- 1967 442 Hood
- Flywheel Wanted
- 1965 cutlass bumpers
- Need Back seat support for convertible A body
- WTB - Tall Script Aluminum Valve Covers
- my newbie injtro, from Paul Idaho
- WTB: 1111930 distributor
- 68-72 Cutlass 8 Track player Face Plate
- 442 Seat Belts for front and back needed
- 455 Valve Covers Needed
- 1950 olds transmission valve rod.
- NEED axle shaft 71-72 BOP GM 10 bolt 8.5 bolt in axles
- 1963 Cutlass Parts wanted
- Wanted: 69-72 LH Bucket Seat Tracks
- man seeks 1949-50 ENGINE
- Wanted 1970 Starter 1108386
- f85 parts wanted
- Wanted-53 Olds Super 88 Starter
- 70-2 F-85 embems for fenders
- Wanter One 15"x7" Wheel SS111 bolt on
- Blend Door Motor
- 72 cutlass parts needed
- door hinge
- Wanted: 324 3 groove pulley and A/C Compressor Brackets
- need parking brake cables for 72 cutlass s
- WTB passenger door and fender for 67 442
- Wanted: Air Conditioning Duct box 1964-1965
- need 1 bumper bracket bolt for my 71 Olds 98
- WTB: 77' ssIII rally wheel center caps
- intake
- WTB: aluminum 455 intake
- vinyl and back window moldings
- 1968 455 rear alternator bracket for a/c car
- Rear window body panel
- Wanted: decent set of rally wheels
- Looking for some chrome valve covers for a 394 V8
- Rear Window Trim piece
- Wanted: Bumper Jack for 1972 Cutlass Supreme
- Air Cleaner 330 V8 & Trim
- 67 - 70 T&T steering wheel
- 1970 Vista Cruiser door panels, possi chuck
- 1969 442 Conv. Trunk Lid Wanted
- Wanted: 3 groove pulleys
- 70-72 Vista Cruiser rear brake drums
- '65 cutlass drivers door
- 1966 "88" emblems
- 66/67 A/C cutlass cowl piece
- 64 f85 cutlas covertible
- 1957 Olds Fuel Pump needet
- good set of headers for a 1969 442 with 455.
- horn
- 69 Cutlass Sport Wheel Center Cap
- F-85 emblem
- Hub caps ´57 wanted!
- WTB Wheel Vintiques 52 Series 15X8 5x 4.75 SSI looking rims
- 64-66 console spears
- Lower cowl sections needed
- passenger side rear sail body panel
- 68 black bucket seats and 4 speed Muncie trans and shifter for 68 442
- '73 Toro rear bumper & all front and rear filler pieces
- 1954 Oldsmobile 88 324 Connecting Rods
- 1970 Ram Air hood (442)
- wtb 1971 white passenger door panel
- 1970 Ram Air Hood
- 68 Cutlass Buckets and console
- 76-77 Cutlass front clip
- Chambered Tailpipes
- 1967 425 block or other big block
- WTB: Grill for 1972 Cutlass
- Front clip
- bow clips
- Need high output alternator for 68 Cutlass 350 100+ AMP
- 80-84 Olds 98 interior parts wanted
- intake
- used or junk 70 Q-jets
- 69 cutlass frontdoor window hardware.
- 69 power top wiring
- 1972 cutlass sedan seat buttons
- 70-72 Cutlass Spoiler
- WTB 455 Exhaust Manifolds
- 1969 HD water pump
- 1970 Cutlass Convertible rear interior panels
- 77 Cutlass Supreme Passenger Mirror
- A/C & Heat Underdash Manifold
- 1967 442 Trunk Trim
- 1966 442 4speed driveshaft
- Air cleaner snout needed
- 67 442 am radio
- 1966 442 crankase vent tube (pics)
- Micrometer, bore gauges to borrow in DFW
- 1966/1967 Cutlass 442 f85 Radio Plates
- 70 upper rear skin needed!
- 71 Cutlass Supreme Grills
- drivers door glass
- Needed: A single (or set) .030 over 350 piston minimum 6cc dish
- am fm radio for 67 442
- 71 delta 88 headlight assembly
- wiring
- 1966 442 4 speed linkage (on firewall)
- 1966 442 air cleaner (CA built cars)
- Rear Windows For A 72 Vert
- 1968 Cutlass hood release rod bracket
- 70-77 Cutlass Sport steering wheel
- Dash
- Looking for a rebuildable '66 '67 400 engine
- Seattle area 1956 Olds HOOD!!!!
- Front disc brakes for 69 442.
- 66-67 Fan Shroud
- Looking for good running engine
- 408329 water pump needed
- More 54 Super 88 Parts Wanted
- blower motor vent tube and connector
- 1964 Olds 88 2 door parts
- 74 Delta 88 Fender and Door Wanted
- WTB 12 bolt Olds posi rearend
- need 1966 442 doors
- 73 Olds Cutlass S
- '64 Dynamic 88 rear coil springs
- 72 cutlass items
- Toro air cleaner
- 1964 cutlass floor shift handle
- Upper & Lower Windshield Cowl 71' Cutlass
- Edelbrock O4B intake.
- 73-77 Cutlass 4 door or wagon stuff.
- 455 Oil Slinger/Mldg Clips
- 1966 hood chrome trim
- 1969 Cutlass Front Fenders
- 1968 Cutlass drivers side tail lamp lens
- Looking For 59 Door Lock Part
- Power Steering Pulley
- Heater A/C Blower Motor w/ Cage Fan
- early 60s oil cap needed
- Need AC Duct for 71 cutlass Convertible
- 56 olds brace
- WTB: Offy finned alum valve covers for Olds 215
- '72 Cutlass Supreme steering pump
- NEED 1971 DELTA 88 Decklid lower edge molding
- 69 cutlass / 442 steel wheels needed - Ky
- 1968 Olds Cutlass Alternator
- 70 Passenger side Sport Mirror
- Column shift lever 72 Cutlass
- 72 cutlass trunk rods & rear int. light covers
- Need misc items for '69 442
- '75 Delta 88 Royale Accelerator Cable
- 1972 cutlass tail light
- 1956 oldsmobile parts wanted
- 1967 442 or Cutlass Supreme lower tail light
- 69 Cutlass Hood Nose piece
- dash for 1974 olds cutlass supreme
- wanted 70 Cutlass 8-track Gold housing
- horn bars
- 66/67 442 Cutlass f85 Vista Cruiser instrument Panels
- 54 Super 88 door glass
- Need X,Y, or Z exhaust manifold olds 455
- 1967 F85 Backup assembly
- 81-88 hood
- Wanted- bucket seats 1972 4drcutlass supreme
- wtb boxed trailing arms for 1970-2
- Idle Solenoid
- Wanted - Rally Pac Fuel Gauge ONLY
- 1967 442 or Cutlass Auto Console and Shifter
- wanted 83 delta88 doors...
- 1971-72 442 Overflow Bottle
- Wanted: Edelbrock 065 Dual Quad intake
- 70 Cutlass S B85 Moulding
- Ka waterpump pulley
- 63 F-85 heater control valve
- edelbrock 04b intake
- 1978 Cutlass upper front bumper wanted
- double groove water pump pulley
- 69 350 Exhaust manifold
- WTB - Edelbrock IAS Classic Shocks
- Arm rests and sun visors
- 68 cutlass grille
- Wanted: 1964 Cutlass Drivers Side Rear Quarter Panel
- Wanted 70-72 cutlass column shift tilt wheel
- Wanted: 68 Olds 98 L. Frt fender
- ONE 6" rod
- 70-72 Floor Shift Speedo
- Need Olds 455 Edelbrock Intake and Th400 Tranny
- Wanted- 53 Olds Trunk letters
- WANTED - 1974 Delta 88 Ash Tray Insert
- Wanted- 53 Olds rearview mirror
- Wanted -1953 Olds Super88 4dr Sedan Sill Plates
- 66 cutlass rear bumper
- Wanted: 1964-65 2" Fan Spacer w/bolts
- 67 Dash Pad
- 1970 Rocket 350 310 HP
- Looking for very nice standard black plastic steering wheel for the '72 H/O pace car
- Wanted: Misc 71 442 parts
- '34 parts
- 86-87 Door Pull Screw Covers
- 1954 Olds Parts Needed
- Dualgate and console for 70-72 Cutlass
- Wanted: Tic Toc Tach
- Wanted: 1966 Cutlass Side View mirror
- 66 cutlass parts needed
- 1972 Fisher Body Manual
- Wanted: '67 Delta 88 Front Brake Drum
- Headlight housing Screws and clips 72 Cutlass
- WTB 1948-49 olds 98 Rear hood brace and tail lites
- Keys 82 cutlass
- blower motor capacitor
- 1970 Fenders
- 8 Track Lower AC Duct 70 to 72 Cutlass/442
- 86 cutlass
- Looking For A Quadrajet For 455 M/T A Body
- 1964 Dymanic 88
- rear speakers
- 1969 442 Hubcap wanted - PO2 option
- 330 crank and flexplate
- "KG" PS pulley
- Wanted: Mint 1969 Gold Interior Pass Kick Panel for a non-air 442/Cutlass
- Need 4 core radiator top support for 71' Cutlass S
- WTB: Cruise Handle
- 71' Cutlass S Front bumper, Trunk lid, doors
- Trunk lid molding 72 Cutlass
- # 673 posi wanted
- old olds backing plates
- 1970 442 Convertible Panels
- Center console harness
- C Heads needed in Ct..
- Wanted: 70 convertible rear window limiter
- **Wanted** 1964 Cutlass Rear Bumper
- AC Part
- Rally Pac
