- WTB 455 exhaust manifolds (in Washington or nearby)
- wanted obr intake
- th350 dipstick tube
- Altenator WANTED
- 85 chrome trim
- 1968 front
- 69 CUTLASS headlight bezel
- Steering wheel for 69 Cutlass
- still need a convertible top switch 69' delta88
- WTB: Alternator and Power steering brackets SBO
- wanted manifold and 4 barrel carb
- Wanted: 1967 Olds 98 choke coil
- Need Motor Wheel Spyder Center Caps
- 72 supreme drip edge molding
- Need A Non A/C Heater Blower Switch & Control "Plate"
- Weather strip b85
- Need G-body Carburetor -- 422 or Monte SS
- RR 1/4 window trim (front) 74 Omega
- 68 Cowl
- Boxed control arms
- Oil filler pipe
- Exterior trim 71 442
- non a/c g-body under hood
- 1972 Convertible Rear View Mirror w/courtesy light
- sport wheel horn contact
- 69 cutlass supreme front bumper
- Wanted W31 Hamonic Balancer
- Crank pulley for 63 olds 215 2 groove
- 68 Olds 98 power seat 6 way switch wanted
- Distributor Hold Down needed 69 442
- throttle linkage component, 1967 Delta 88
- Carb wanted
- WANTED: Clock knob 67
- Wanted: 67 Cutlass Steering Wheel
- A/C parts
- under hood & trunk light
- Motor Wheel Spyder Center Caps Needed
- cruise control unit (1971)
- RT side quarter glass for 72 Delta Conv.
- WTB Quadrajet Fuel Filter Housing Inlet Long
- WTB 1968/69 Cutlass Radio
- 1970 Cutlass Drivers Lower Cowl Needed
- 64 330 shaft rocker arms
- trunk lid
- Frame mounts/pads
- 1969 442 w-30 distributor wanted
- 1969 442 w-30 carburator wanted
- Wtb 1966 tranny hump 4 speed non console
- Interior mirror stalk
- Head bolts with stud for a/c
- 425 crank, rods, heads, etc
- Lighting rod shifter
- 1969 delta 88 convertible top switch wanted
- Want: HEI or Pertronix Elec Ignition
- 70-72 Cutlass Console and shifter
- WANTED: Speedo cable for 66 Full Size
- Exhaust Trumpets
- dash face plate
- WANTED, window part for 1965 442
- 68-9 Cutlass parts
- 66 442 auto floor shifter
- wanted: pre 73 sbo heads
- 1964 F-85 bumper needed + more
- woodgrain plate for 1970 8 track
- Convertible Top Switch
- 68 Delmont wish list
- Parts in Canada wanted.
- 1957 Bumpers
- '72 442 Hardtop rear window trim
- 330 shaft rockers
- 69 400 exhaust manifolds
- Two (2) F-Eightyfive fender emblems?
- 61 F85 parts
- rear bumper
- Looking for a 66 "x" exhaust manifold.
- 69 driver side "eyebrow" chrome
- 63 cutlass F-85 power steering gear-pulleys
- A head rocker arm washers needed
- 70 442 Q-Jet
- 65 jetstar convertible weatherstripping wanted all
- Jack Haggerty of Chicago License Plate Frames?!
- wanted 62 starfire doors&bumpers
- WTB: 68 442 Rally Pak and Tac
- dipstick tube for '73 S w/ 455
- 1965 starfire sheetmetal
- 72 supreme driprail molding
- reverse lights lens cover
- '70 W-30 parts needed.....
- 1967 cutlass / 442 rear bumper
- 307 parts
- interchange
- 63 oldsmobile98
- 71-76 Delta 98 parts needed
- 1956 88 Exterior Moulding
- 1972 Cutlass front end parts needed!!
- 1964 cutlass f-85 passenger side rocker trim
- Alternator Bracket and Power Steering Pump Bracket NEEDED!!
- Murphy motors license plate frames
- Wanted: Gumpp Oldsmobile License Frame
- WTD Starter for 1970 442 1108389 dated Nov or Dec of 69
- Seeking: Seat Belt Retractor Covers RCF-401
- 70 SF 402227 3.23-1 axle hsng or 671 w gears
- Wtb 63 dynamic conv. Parts
- WTB:Rocker arm studs!!
- door hinges for 1935 olds F-35
- Want to buy 1971 Olds service manuals
- 70 442 parts needed - saving a car from the crusher
- A/C Brackets
- 59 Oldsmobile outside sun visor
- Wiper Arm 1966 Full Sized Passenger Side
- need 64 jetstar 88 convertible parts
- 74 delta 88 front bumper
- AM /FM radio for 1967 Cutlass Supreme
- TH400 gas pedal & kick down switch bracket
- 68-70 "O" type ring and pinioin
- Front Bumper Rub strip - '73 S
- 70 tilt wheel
- rocker molding 87 full size wagon
- 69 442 Door Parts
- PS Pulley for '73 w/AC
- 67 442 front and rear bumpers
- Looking for Battery Hold Down Plate - 1960 Olds
- 76 Supreme electric module harness needed
- 69 98 disk brake spindles
- 1970 cutlass supreme p/s brachets
- aluminum intake
- Need fuel tank filler neck 1968-1972 Cutlass
- Pre 73 350 heads
- 330 carb & manifold wanted to trade or buy
- WTB: Rear convertible armrest to Cutlass/442 -69
- manifold exhaust needed
- power bench relay needed
- 68/69 Cutlass/442 front side marker light retainer
- Wanted: Dual Gate Mounting Bracket
- Looking for 403 qjet
- Looking for 1966 olds 400. New england/ct
- WTB 68 Cutlass/442 2 Door Hardtop Trunk lid (Pref. central CA)
- Want ot buy Delmont 425 front fender emblems
- I need a set of 350 head bolts
- 66 floor shifter
- Isky valve covers
- 59 Olds hubcaps
- 66 F85/Holiday/442 Rear Bumper Needed
- sbo intake and roch carb
- 70 cutlass rearview mirror
- Convertible parade boot snaps
- Wtb original '70 442 valve cover bolts and bracket, heat riser pipe
- Wanted console base, bottom piece 72 442
- Wanted saginaw 4 speed shifter
- Needing a 455/350 Oil Filter Adapter
- WTB Block off plate and exhaust hangers
- Wanted: 66 442 floor shifter
- Wtb quarter window chrome 1966 f86
- Looking For Complete Rear End
- Wtb 324 std piston
- still wtb carb
- 65 cutlass trunk letters
- 4A heads wanted
- WTB: 63 Full Size Brake Booster
- Oldsmobile pulleys
- 56 Olds Air cleaner wanted!
- WTB trim rings for 15x7 ssIII
- Wtb looking for ss2 center caps
- WANTED: Good used HEI distributor in the Toronto area
- 72 Cutlass Supreme Shifter
- WTB - 70-72 Cutlass Chrome Fender Peak Moldings
- parts needed for 72 converible
- 330 ci carb & intake
- 70 350 intake and carb
- 74 DELTA 88 CONVERTIBLE window parts
- wtb 71-72 cutlass hood hinges
- WTB: Circuit Board (back of speedo/gauges) 67 Cutlass
- Looking for 70-72 am/fm radio
- Looking for a 1970-72 oem Tach
- WTB 14" SS1 Rims
- shiny stuff - 1937 Olds 4.dr tour. sedan
- need a good 350 core
- WTB: Edelbrock 350 Manifold Intake and 600CFM Carb
- Need Full Repro Passenger side 72 Convertible Quarter Panel
- starter motor
- Power Rear Antenna for a 66/67 cutlass
- 70-71 Cutlass Supreme Body Molding
- Wanted--68-69 Cutlass Vacuum Power Trunk Part
- 70-72 Console
- '67 442 Exhaust Manifolds
- 1968 98
- 70 Rear Bumper Bracket.
- seats
- Edelbrock performer rpm intake
- Dash Pad
- 72 442 4 Core Harrison Radiator
- Want 650 or 700 cfm holley
- bumper jack, coolant bottle for '73 S
- bumpers for 1965 98 convertible
- Wanted 455 intake
- Wanted 1970 442 3.42 posi rear-end
- 1968 Cutlass Parts (Grill & Bumpers)
- Need 1964 vista cruiser left top glass
- WANTED!! exhaust manifolds 1950 88 303
- 72 442 Vert Items Needed
- 1965 Starfire parts
- Looking for used intake and carb (350)
- Wtb 1966 buckets or corresponding year
- Wtb 1966 cutlass console and shifter
- Wanted: 1967 Rallye Pac Gauge
- Wtb 1966 3-4 speed cutlass setup
- Interior/Exterior trim parts for '75 Cutlass
- Need Distributor Holddown clamp for 72 350 and front fenders
- 1959 Oldsmobile Dynamic 88
- 1972 cutlass conv.
- 1962 dynamic 88 celebrity 4dr
- 67 Delta 88 side view mirror
- Wanted 68-69 Cutlass Clocks
- WTB disc brake prop valve
- 63 f-85 convertible
- 1979 Oldsmobile 98 2 door parts needed
- Wtb 69 cutlass wheel well molding
- 71 Cutlass NOS Upper Tail Light Lenses
- wanted 63 98 bumpers
- Driver's door switch plate & switches
- Vent Window Weatherstrip Retaining Clips 68?
- 350-403-455 Manual Flywheel
- Wanted neutral safety switch for 69 cutlass
- 67-69 cutlass/442 three speed shifter wanted
- cheap 403 heads needed
- Parking brake strut lever 11"
- 68-69 442 -cutlass vista window cowl
- 1969 Convertable Top Frame
- Wanted: 59-64 Olds/Pontiac Posi 31 spline
- 400 turbo transmission yoke
- windlace/pinchweld
- WTB: Olds 307 or compatible valve covers
- Earlier crankshaft & water pump pulleys
- WTB Clean Show Ready vlack dash for a 1972 Cutlass
- oil filler tube
- convertible parts wanted
- A Few Parts Needed
- Parts needed
- 68 or 69 250 6cyl.
- 70 cutlass SX parts wanted
- A/c hose
- 66-67 Evaporator case
- Still looking for the rear panel for a '70 Cutlass Coupe
- WTB 6 Blade Fan
- 1935 Grille Insert
- Needed Badly, Parts for my F-35
- 1966 Dynamic parts
- 68-72 GM A-Body Convertible Frame
- Radiator overflow bottle for '73S
- Wanted: 1969 Cutlas/442 tail light bezel
