PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1965 442 Conv't top molding
  2. Wanted Water Outlet With Part # 386129
  3. 69 sport wheel
  4. 1972 Cutlass Headers
  5. 1966 Quadrajet 7026250 wanted
  6. Wanted>66-69 4 speed shifter linkage
  7. WTB 1108389 Starter
  8. WTB 1970 Sport Steering Wheel Gold Horn Button
  9. Searching seat belts for 1975 Hurst /Cutlass Supreme
  10. WTB a 1970 442 W30 posi rear end
  11. Heater tube and shroud 455
  12. Tilt steering column parts
  13. 66 F-85 Emblem Script Wanted
  14. WTB 1966 Toronado Lower AC Brackets
  15. 7/16 head bolts
  16. SSll kidney trim set
  17. 1970-1972 Wheel Opening Molding Rear Passenger Side
  18. Defroster vent '70 A/C 442
  19. 1972 Cutlass S Dashboard / Dash Pad
  20. Boxed Real Contral Arms
  21. Looking for rims
  22. 1997 Olds 88/LSS Trunk Springs
  23. 1964 1965 Olds Cutlass 442 F85 Radiator Top Plate
  24. WTB 1962 Starfire Cylinder Head
  25. 1966 or 1967 Toronado, parts wanted
  26. 67 442 door frame trim
  27. looking for a nice set of c head big valve
  28. Console Lid
  29. 70 442 trans cover
  30. 70-72 Cutlass/442 rear side markers needed
  31. '69 Wheel well trim
  32. 1959 Oldsmobile 98 parts needed
  33. 1966 88 turquoise interior
  34. WTB main cap 400/425 B389298
  35. 1968 dash
  36. 1983 delta 88 royale brougham coupe
  37. Wanted: 68-69 Carb choke parts or parts carb
  38. Starfire interior trim
  39. "69 quarter window
  40. Old style comp roller rockers- need 2
  41. column plate
  42. oil fill tube
  43. wiper motor
  44. 2 groove crank pulley
  45. 1965-7 400/425 Crankshaft
  46. 67 Ninety Eight Bumper
  47. Intake needed
  48. looking for a remote driver side mirror
  49. Oai hood
  50. 1953 Super 88 parts ISO
  51. 1 7/8” ceramic headers ‘68-‘71
  52. 1949 1950 Olds Rocket - valve cover Palnuts
  53. 67 Cutlass wagon or Vista Tailgate Glass Channel
  54. 66 cutlass headlight cups/ buckets
  55. Looking for 1965 Starfire interior
  56. WTB 1/2 Gear shifter Lever/tTab for 1968 4Speed Muncie
  57. WTB 1968 Driver Side Kick Panel No A/C
  58. WTB 1968 Cutlaas LH Door Lock Rod
  59. ‘50 windshield stainless trim
  60. 1973 Delta 88 Royale trunk molding
  61. Does Anyone Have any New or Used Vista Cruiser Rocker Panel Trim Clip Part No. 405688
  62. Power Steering Brackets for 69 442
  63. 1972 Delta 88 Royale conv. front left fender
  64. 67 442 H/T door panel metal
  65. blower motor for a super 88
  66. 1970 Olds 442 455 Engine oil pan
  67. WTB: "Oldsmobile" Trunk Emblem '70 F85
  68. Wanted 20" Gray Boss 338 rims
  69. 65-66 98 convert rear interior panels
  70. 1970-1972 Rally Pack
  71. WTB 65 Cutlass Bumper
  72. Stereo radio knob
  73. WTB: looking for 68 442 horns 9000-261/262
  74. Wanted: 1972 Cutlass Shift Indicator Needle (on speedo)
  75. WTB 70 Cutlass Taillights
  76. 70-72 Convert Factory Quarters NOS wanted
  77. 1967 Alternator Wanted 1100730
  78. Bumper fillers wanted
  79. WTB Notched Valve Covers
  80. NOS Upper and Lower Radiator Hoses - 1970
  81. 1964 or 1965 F-85 Club Coupe Plastic Dash Pad
  82. ISO NOS Upper Tail Light lense Cutlass 442
  83. 70-72 Rally Pack
  84. 1947 Series 66 - Hood Hinge
  85. ISO '71-'72 W-25 OAI hood
  86. Iso 67 cutlass supreme convertible passenger quarter wheel well molding
  87. ISO original steering wheel (73-77?)
  88. Wanted 7042250 carb
  89. 62 cutlass wiring harness
  90. Rally I center caps
  91. 1964 Olds Cutlass AT console T handle shifter
  92. WANTED: 1970 Trunk Lid
  93. WTB 350 4barrel intake
  94. Wanted: 70 Cutlass/442 Disc Brake Spindle/Knuckle
  95. 65 cutlass eyebrow molding
  96. Parts Wanted for 70 W30
  97. 1972 Cutlass Tic Toc Tach
  98. 1972 Cutlass Supreme Trunk Lid
  99. looking for spinner hubcaps
  100. 68 to 72 Cutlass/ 442 Rear Glass
  101. 1970 Cutlass washer jug
  102. Looking for hood hinge headlight window interior moulding
  103. WTB: 72 CS Parts
  104. clutch fan
  105. Toronado dipstick tube
  106. Wanted BBO Edelbrock Victor intake or Batten Victor intake
  107. 3.23 Ring and Pinion
  108. WTB Hurst shifter handle
  109. Edelbrock Performer RPM intake
  110. Alternator brackets for 68 442 with AC
  111. 1971 left front fender support braket
  112. 1971 left front friended support braket
  113. 70 Cutlass right door
  114. BBO 2151 intake
  115. Wanted 7041253 carb
  116. olds 455 power steering pump and brackets
  117. 1965 olds 425 pistons
  118. ISO '67 cutlass 2 door hardtop drivers door panel
  119. ISO Looking for a good 4 speed solid driveshaft for a 1968 442
  120. 1964-67 Vista Cruiser Or F85 reverse light delete plate
  121. 394 transmission adapter
  122. Quadrajet 7042250
  123. disc brake
  124. 1969 Cutlass/442 Remote Mirror
  125. Need Hood for 68 442 or Cutlass S
  126. Thornton oil pan
  127. Looking for complete brackets and pulleys for an a/c 1968 400 442 engine
  128. ISO 1979 HO dual gate shifter and/cable(s)
  129. 1969 442 Carb Idle Stop Solenoid
  130. Dealer trunk emblem wanted
  131. Really nice set of 1970 notched valve covers
  132. WTB 1970 442 tilt steering column
  133. 1970 Emissions connector, end of the snorkel
  134. XT wheels
  135. Gas tank neck support bracket/ring - '70 Cutlass
  136. 72 Rally Pack Guages
  137. Walker 70 442 driver side engine pipe
  138. 67 442 dash harness with tach & gauges
  139. Need a clean power steering set up
  140. 1965 Cutlass Hood wanted
  141. Wanted for 1967 Delta 88
  142. ISO 1966 Delta 88 wheel arch moldings!
  143. Rear fenders for '47 model 66 coupe
  144. 384783 water pump needed
  145. In search of...
  146. 1973 Cutlass S front bumper filler
  147. 1964-1969 4 Speed Console Parts
  148. 70W30 rear carb Tee
  149. "Oldsmobile Dealership Trunk Emblem - Badge" - WANTED...
  150. Dealer trunk badge/sticker....
  151. WTB: 65 Vista power window conversion/ AC ball vents
  152. 65 Back up lens
  153. 1970-72 Shift indicator Clip needed
  154. 1967 Cutlass/442 Disc Brakes
  155. master cylinder
  156. Looking for an nos 403902 69-74 timing indicator
  157. 1970 OLDS 442 Dashpot Bracket
  158. oldsmobile door thermometer
  159. 1966-67 Toronado front bumper help!
  160. Wiper knob, cutlass dash emblem
  161. 69 vista rear doors interior trim
  162. 425 bb hei distributor
  163. 1949 Olds 98 Convertible Door Windows
  164. 1966 bucket seat back
  165. 70 442 parts
  166. 1969 dashboard knobs and bezels
  167. rear control arms
  168. S hook for parking brake cable
  169. transmission cross member
  170. A/C vents
  171. 1979 Cutlass Supreme Brougham
  172. Hurst Project: Parts Needed
  173. 1965 valve cover bracket
  174. 67-69 auto console bezel
  175. 1971 cutlass final parts needed to complete restoration
  176. 1965 A/C condenser
  177. Console Lid
  178. ISO 1979 HO shifter top plate
  179. Aero Body Kit
  180. 1956 88 or 98 bumpers
  181. 3.08 Type O
  182. 3.91 "O" type gear set (Ring and Pinion)
  183. 1977 Air cleaner base and lid
  184. 1970 442 front spoiler
  185. Wanted: 68 442 hood original
  186. 1956 88 Hub Cap
  187. 69-72 4 speed pedals
  188. 1970 Parts Needed
  189. W30 vacuum advance
  190. WANTED: 64 Cutlass part
  191. Wanted 7040256 Carb
  192. WTB Four Speed hump for 1968 Cutlass 442
  193. WTB 1970 W30 orignal red fender wells and fenders
  194. Rear bumper and passenger side mirror 78 Delta 88
  195. 72 right fender
  196. 72 right fender
  197. 1969 442 hood
  198. Need 4spd throttle linkage for a 67 442
  199. Wanted 1968-1972 Green 8 track
  200. WTB NOS 1976-77 Cutlass S tailights
  201. 61-63 Cutlass lower back glass trim wanted
  202. Want to buy
  203. 1966 1967 wagon power tailgate motor wanted
  204. 72 cutlass fender eyebrow
  205. In need of a Water pump pulley for 1970 442
  206. 65-67 power steering pulley
  207. WTB 1965 400 olds engine
  208. NOS Cutlass parts lead
  209. 1972 Oldsmobile cutlass supreme trunk torsion rods
  210. Main caps
  211. Climate control
  212. 1970 Water/Vapor separator - NOT the standpipe
  213. WTB: rocker panel moldings for a 1954 olds Starfire 98 convertible
  214. WTB SB Olds heads #5,6,7,7a
  215. 68 442 coupe stuff
  216. 1968 cutlass washer bottle
  217. Olds 307 air cleaner lid
  218. Looking for Lifters
  219. WTB NOS 442/W30 passenger side front grille
  220. Remote Hood Lock Handle - '70-2
  221. 1968 convertible peak molding.
  222. Vapor Emissions canister bracket for 1970 A body
  223. Stock 350 4 Bbl Intake Manifold Wanted
  224. 1957 Oldsmobile License plate lamp assembly
  225. Water Pump for '69 H/O
  226. 1971 1972 OEM Wing Pedestal Wanted
  227. 1965 442 A/C Brackets Wanted
  228. Wanted 7040251 Carb
  229. 1968 dash
  230. 1970-1972 olds cutlass 442
  231. 1964-1965 cutlass mirror bracket
  232. 1970 BOP automatic backdrive linkage
  233. Center console
  234. 1965 Cutlass F85 trim wanted
  235. Wanted to buy for 1967 cutlass/supreme/442 etc.
  236. Looking for Poiwer Steering set up for 1953 Olds Super 88
  237. 1967 442 automatic console lid
  238. 8 track case
  239. Holley Street Dominator SBO
  240. Need 14x6 wheels
  241. Dash bezel. 70 cutlass
  242. 8-Track to Dash Bolts and 8-Track Bracket
  243. 1970 #6 Heads
  244. P/N 1100879 alternator 37 amp for october ‘69 built Cutlass
  245. code FD radiator P/N 3014740 for ‘70 cutlass 4 speed
  246. need SS IV Trim rings
  247. 1965 plastic dash pad
  248. 4 Core Radiator 'C I' Code 'EC'
  249. "48 98 heater switch and knob needed
  250. Alero Passenger Side Airbag Cover
