olds 455 power steering pump and brackets
Old Jan 11, 2019 | 08:36 PM
VinMichael's Avatar
I currently have power steering bracket that sits above the valve cover on my 455. This is a 64 Cutlass so the bracket is from a 330.
I would like to convert to pump style which sits lower. Please let me know if you have one to part with. Thanks
Old Jan 11, 2019 | 08:43 PM
2blu442's Avatar
There was a recent post where someone did this but had to cut part of the lower bracket off for clearance with the steering box. Also, you might need to swap all the pulleys over to get a set that match, and may or may not need to change the water pump to get the right length for the pulleys to line up. John
Old Jan 11, 2019 | 08:48 PM
VinMichael's Avatar
That’s what I was afraid of. I was going to try to cut/weld until it can work with my existing pulleys.
The water pumps are shorter on the earlier cars. I think the fan would hit the radiator with the longer pump installed.
Old Jan 11, 2019 | 09:00 PM
2blu442's Avatar
My thoughts are that your existing pulleys won't match the newer power steering pulley. Not sure about the radiator/fan clearance, you might need to take some measurements and experiment with that. There's a lot of variation between pulleys that will fit your motor.
Old Jan 11, 2019 | 09:49 PM
VinMichael's Avatar
Thanks for your input. Maybe I’ll take some measurements and take a walk through the junk yard when the weather gets better and find a combination that I can make work.
Old Jan 12, 2019 | 06:32 AM
jollyolds's Avatar
pm sent
Chuck Cole
Oct 8, 2019 04:18 PM
1968_Post
Sep 19, 2013 08:45 PM
Terryc
Jul 25, 2012 06:59 PM
68Tom
Sep 16, 2009 11:34 AM
ratsglass29
Nov 23, 2007 07:08 PM
