1970 Olds 442 455 Engine oil pan
Old Jan 31, 2019 | 02:48 PM
Scheil442's Avatar
I am looking for a correct reproduction OEM style 1970 Olds 442, 455 engine oil pan. The companies that carry the OEM style pan are out of stock. Not sure who the manufacturer is. Apparently there is only one company/supplier who reproduces the correct oil pan for all of the major Olds restoration parts suppliers. Also would be interested if anyone has a very nice original. I thought I would inquire....Thanks in advance.
Old Jan 31, 2019 | 05:59 PM
442crzy's Avatar
PM sent on both pans.
Old Feb 1, 2019 | 06:05 AM
Eddie Hansen's Avatar
I bought a factory style pan from milodon from summit, it actually holds 1 quart more but looks oem
OLDS STOCK - ALL CHASSIS
350-45530765
Pan Capacity is 5 Qts. Plus Filter
7" Sump Depth, 7 1/4" At Deepest Point
Oil Pump and Pick-Up Required:
Pick-Up for (Melling M22)18665Oil Pump Shaft22575Oil Pan Gasket 40800Pan Bolts85000Pan Studs81300Allows 4.500" Stroke crank
Old Feb 1, 2019 | 06:18 AM
scrappie's Avatar
Do you need a different pick up for that pan?
Old Feb 1, 2019 | 06:29 AM
No, everything fit like it should and it holds 5 qts ( plus the filter makes six) better than a toro pan! because there is no hump
Old Feb 1, 2019 | 01:18 PM
Scheil442's Avatar
Thanks for the info. I appreciate it but I need it to look 100% correct including the drain plug location.
Old Feb 2, 2019 | 08:04 AM
Scheil442's Avatar
Part found, thanks 442crzy!
george landis
Aug 16, 2019 03:26 PM
Hacked Up 74
Jan 17, 2019 04:02 PM
Fpcopo
Jan 8, 2019 03:28 AM
rptw32
Jul 14, 2018 08:15 PM
RandyS
Oct 28, 2013 11:57 AM
