View Full Version : Parts Wanted
- Stone Shield - Lower Rear Quarters for 72 442
- ball joints
- '66 Vista Cruiser
- super 88 fiesta wagon
- w30 Hood
- 1972 post (series 77) window trim
- WTB 324 #10 Heads
- 72 442 Convert Full Trunk Pan
- Wanted: nice 66 Cutlass front bumper
- SSII 15" Rims wanted
- WTB chrome piece for 68 Cutlass fender
- exhaust manifold passenger side 72 Toronado
- 1971 cutlass s parts
- WTB: 1971 Cutlass Parts
- Rear bumper filler for '75 Delta 88 Royale Convert
- 71 72 442 Rear Bumper Wanted
- Searching for a nice 66 F-85 2-door bench seat frame
- Wanted Parts for 1972 Cutlass Supreme
- intake manifold
- 1964 Olds F85
- Windshield moulding/trim, '67 Delta 88
- Cutlass 442 HOOD 4 A 1987
- 79 cutlass calais hood emblem
- Wanted: 71 Delta 88 Rocker panels
- WANTED: Looking for Tissue Dispenser
- 200r4 wanted in ohio
- Body Emblems, 1969 Olds Cutlass 'S' Holiday coupe, 2-dr.hdtp.
- 79 Holiday 88 part needed
- WTB 61 Olds Dynamic 88 Trim
- 68 parts
- 1963 Olds Brake Parts
- Wanted: bucket seat headrests 69-72 Cutlass/442
- 70 Culass/442 stuff
- '57 Olds radio delete plate wanted
- Looking 4: lower crank pulley cover
- 65 starfire coupe
- need parts for 65 starfire ,bad.
- crossmember
- wanted
- Spoiler and OAI hood wanted in AZ
- 66 Toronado front and rear bumpers
- 66 Toronado Headlight Switch
- Need a Switch...73 Delta 88 conv top
- Carburetor part needed, will pay good money
- 1970 98'
- Various Parts for a 1964 Dynamic 88
- Trim Clips
- 1968 442 wood steering wheel wanted
- 307 Olds motor
- 1954 4 Door windshield
- possi rearend 1971 cutlass
- wanted 54 olds parts
- 303 or 324 valve cover
- Molded lower radiator hose
- 62, 63, 64, Alternator Bracket
- 69 442 Parts needed
- Gear selector lever
- BBO G Body Headers
- 72 parts needed *convertible*
- 1970 Center post covers
- (2) 15" ralley's
- 12 bolt olds prefer posi
- Alternator Bracket 394
- 64 or 65 Starfire Conv. Boot and Floormats
- WANTED 4BBL CARB FOR 67 425 DELTA 88!!
- 1961 Dynamic 88 Front Fender Scripts
- 1966 442 Ignition Key Bezel Needed
- Service Manual for 1964 Dynamic 88
- Turn Signal Switch - tilt/Telescopic - 67-68 Toronado
- 394 exhaust manifold
- glove box light
- 1963 Oldsmobile Starfire RH tail light
- Glove box light assy
- wanted 1970 442 rear bumper
- wanted 70-72 350 olds engine in NC
- 1964 Cutlass Automatic Floor Shifter
- 1954 Olds shift lever
- 1980 DELta 88 Tail Lights. NICE
- cutlass calais hood emblem
- 67 supreme conv. door
- Various parts wanted 69 olds cutlass
- 49 Olds Deluxe Club Coupe Model 76
- 1986 old 442
- 1970 Cutlass S Passenger side door
- 455 edelbrock performer intake manifold
- 1972 eng trans and rear
- 4 spoke sport wheel
- H Heads wanted
- olds 442 Front Grille 1970
- green interior parts for 69 cutlass
- HELP!!!!
- 1955 hood lip for olds 88
- 70s-87* Cutlass G Body BBO Conversion Headers
- 67 olds 442 needed vinyl top trim HELP
- Thermostat housing for 394 olds
- 63' dynamic 88 holiday parts wanted
- 4 core top plate
- Wanted 1956 OLDS back up lenses
- 68 convertible quarter
- Need posi and gears for 1970 olds 98
- Need ac under dash ducts
- 69 4-door parts wanted
- Wanted 87-88 Cutlass headlights, bezels,grills,corner lamps.
- Wanted
- 1970 Delta 88 4-dr. sedan door panels
- 66 442 trunk bar lip, Grill, fender ports, tail lights
- Wanted 1958 Oldsmobile Super 88 Rocker panel trims
- '53 fender
- '56 rear bumper
- 1964-65 Cutlass Glass
- master & passenger 57 olds window switches!!
- olds frame
- I need an engine for my 64 F-85
- 1973 Omega Emblem
- Need a 69 Front Bumper
- 1968 442 3.90 posi 12 bolt olds rear for sale
- wanted oil filter housing from 403ci
- 69 parts needed
- Wanted:Olds Rocket 371 engine
- Steering Wheel for 1964 F85 Convertable
- Wanted: 455 (will consider 403)
- 68 Cutlass S choke heater needed
- Wanted: Running Olds 350 - Atlanta area
- 1964-5 Cutlass Hardtop Glass
- Wanted: Olds 455 Engine
- WANTED-'63 dynamic 88 rear bumper
- 81-88 CUTLASS MANUAL WINDOW SET
- 1950 Olds bell housing
- Wanted 54 Olds88 gas tank
- 68 442 Hood Hinges
- 66-67 Fan Shroud (Delta, Dynamic, Holiday)
- Wanted, Crank Ventilation, AC part CV639
- wanted 1970 442 bumper
- 77 Cutlass Supreme Dash
- Need a good quality Quadrajet Core
- 76 Cutlass Supreme dash
- 1980 Delta 88 Taillights (With emblems)
- 1972 Cutlass Glove Box Strap?
- WANTED: Flexplate inspection Shield
- 1966 Delta 88
- 66 Delta 88
- 68 Olds Conv Parts (NEED ASAP)
- 1969 Cutlass Supreme 4 door hard top
- 1964-5 F85 2-dr Sedan 1/4s
- Cutlass radiator overflow bottle
- exhaust manifolds
- posi axle
- 79 Supreme Rear Bumper
- 1963 Olds Dynamic 88
- Various 69 Cutlass parts needed
- 1959 Oldsmobile
- looking for 1968 cutlass 442 engine 400ci
- Toro oil filter adapter
- looking for exhaust manifold and other for 65 dynamic
- 4 speed crossmember
- 2groove crank pulley 399402-KB
- 2 groove Crank pulley 399402-KB
- Wanted!! L&r Full Quarters 72 Cutlass
- looking for 80 cutlass parts
- 58 gas tank needed
- 1973 Olds 98 Regency - Parts Wanted - PLEASE!
- 69 cutlass eyebrow moudlings
- looking for 59-60 spindles, and...
- 49 Model 76
- 67 Toronado Center Caps & Trim rings
- Wanted- 68 Vista Crusier parts
- 66 442 parts
- Need parts for a 65' Ninety-eight...
- 65 Delta 88
- 1965 Cutlass Parts
- 91 Cutlass
- WANTED: bucket seats
- 69 Driver Side Front Fender
- Steel hood for 68 F-85
- 1986 Olds Cutlass Supreme Passenger Fender Wanted
- NOS '81-'83 Cutlass Coupe Taillight Bezels
- Need to buy Hood hinges for 65 olds
- 62 oldsmobile f85
- Wanted:72 Delta Royale bumper impact strip
- 455 rebuildable wanted
- 1962 f-85 radiator
- Need 70-72 passenger side NOS fender
- Timing tab needed
- WTB Steering Shaft
- 1971 Cutlass Hood
- olds 71-73 delta 88 royale parts needed
- interior stuff
- 1969 Olds Delta 88 Royale
- Reverb Switch
- '67 Cutlass wheel opening trim
- Need 66-70 Toronado Intake
- 1962 Jetfire Turbo needed
- Exhaust Manifold Need
- 1963 Oldsmobile Dynamic 88
- Complete G-Body Sunroof Needed
- 81-88 Cutlass G-body SUNROOF
- 1968 Cutlass Convertible Chrome 1/4 Trim
- 1968 Cutlass Chrome 1/4 Trim
- 1966 442 Steering Column
- 1964 heater valve wanted.
- Looking For A 84 307q-jet 4bbl.
- Parts For 84 Delta 88 Two-door Only
- sbo heads & pistons 350
- 1987 Cutlass Supreme Broughm Trim
- 1973 toronado rear bumper filler
- WTB 425 Crank & Rods
- 1964 Olds Dynamic 88
- 1987 Cutlass Passenger Door
- Stick-shift setup for a 65/70 B-body
- 1983 olds 98 4 door
- Small Block Exhaust Manifolds
- 69 delta 88 armrests
- 1971 olds delta 88 front end wanted
- Trunk floor pan for 57 super 88
- Need a '68 Cutlass Convertible Frame
- 74-78 toronado gas gauge
- 1980-1990 Custom Cruiser parts wanted
- 69 cutlass parts
- Seat belts for pillarless 67 88 wanted.
- 1973 cutlass s 442 part wanted
- 79 hurst parts wanted
- 81 cutlass supreme grille needed
- 71 olds cutlass service manual
- Need a 68-69 2 Door Cutlass Frame
- 69 Toro parts wanted
- 1967 Delta 88 Custom - parts wanted.
- Fiberglass Bumpers
- Headlight Doors for 86 Cutlass
- Trunk Handles
- need 64-67 A-BODY rear upper arms
- 74-77 Cutlass four door rear bumper
- Fender turn signals......Mid-Eighties
- 455 Power Steering Pump Pulley
- WANTED: AIR pump and bracket for Mid-80s
- Wanted 1958 Oldsmobile Parts
- Looking for an Olds 350
- Burgandy 3 spoke sport wheel, early 80's
- 1970 -72 quadrajet
- 1978 Olds Regency 98 Interior Center Pillar Upper Trim Attachment
- RH side marker
- 87 cutlass euro grill
- New guy looking for some parts for his olds
- Wanted 1958 Oldsmobile Super 88 Parts
- Need: Passenger side front fender for 84 Supreme
- I need a drivers side headlight 87 cutlass
- 1958 Oldsmobile Super 88 Parts Required
- 69 442 parts needed
- 1970 cutlass front and rear bumpers both front fenders
- Need 1966 Delta 88 body parts
