PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Wanted 1969 442 Hood latch pin
  2. Looking for a 350 block near Illinois.
  3. brace
  4. 1941 Oldsmobile series 98
  5. 68/69 drivers rear qaurter convert.
  6. Toronado Caliente Rocker Trim Needed
  7. '70 Quadrajet Wanted
  8. 1980 Delta 88 passenger taillight lens wanted
  9. Eldelbrock Performer
  10. WANTED - 68 f85/CS single width taillight lens'
  11. One SSII wheel 14"X 7" to use as a spare
  12. 1964 F85 automatic center console
  13. Needing a 69 Cutlass hood
  14. 57 Olds Crankcase breather tube & canister
  15. Door Latch needed
  16. 1972 cutlass emblem
  17. 1970 442 Air Cleaner Base
  18. Firewall grommet 70 442
  19. 53 Olds rear fender molding??
  20. 1100935 alternator
  21. 72 cutlass blower motor capacitor wiring
  22. Wanted 67 400 tri power engine for cutlass
  23. Olds 350 .030 over pistons
  24. 1970 Cutlass Supreme Bumper Jack
  25. Rear seat cores
  26. 68-72 A-Body Bucket Seat Tracks
  27. 1964 olds cutlass hood moulding
  28. Hood & Trunk springs for 1949 88
  29. 1936 Throwout Bearing Replacement HELP!
  30. 1969 am/fm radio
  31. 72 cutlass Need 442 Hood
  32. 72 serpreme
  33. gauges
  34. 71 column
  35. 1984 Olds 98 Regency Hood bumpers
  36. 1970 350 4bbl Intake Manifold #404520 Wanted
  37. 67 cutlass instrument panel
  38. Electric window door panels
  39. 53 98 2dr htp parts wanted
  40. 72 CUTLASS inner Fender Liner
  41. 1967 Vista Cruiser Rear Bumper
  42. Flat top 350 pistons
  43. 70-72 Console - Piece from bottom half needed
  44. 70 cutlass s 350 parts needed
  45. 1972 Olds Cutlass Vapor Canister Bracket
  46. '68 OAI scoop(s)
  47. 67 cutlass factory tachometer also ram air air cleaner x duct work
  48. 1970 Cutlass Supreme Steel Hood
  49. 350 Crankshaft
  50. 1967 Custom Delta 88 Rear Bumper tail light housings
  51. 70-72 Cutlass Supreme rear package tray plastic fillers corners
  52. 69 Passenger window
  53. a/c compressor brackets
  54. 55 Premium Steering Wheel horn parts
  55. 1984 Maple Horn Button
  56. 1970 Cutlass Jack & Parts Wanted
  57. Fisher body manual
  58. Cutlass Bumper Jack Hook
  59. wanted a lower power steering bracket for a 1972 olds 455
  60. 67 Deck LId Hinges
  61. need axle nut for '73 toro
  62. 67 Cutlas Supreme left quarter panel trim
  63. 1966 Dog Dish Caps
  64. 69 H/O mirrors,air cleaner,D heads
  65. 65 cutlass vent window pivot springs and washers
  66. Interior Drivers Side Door Pull Strap
  67. -76 Cutlass S, interior parts
  68. Looking for a 2004R
  69. 68-72 Post coupe items needed
  70. 1964 Cutlass Fender Emblems?
  71. Posi Rear End/Differential
  72. 1962 Olds Dynamic 88 fender molding needed
  73. 67-68 A-Body Bucket Seats
  74. Ram Air Flapper
  75. Bulb Holder
  76. looking for 63 Dynamic 88 Fin Trim
  77. 1970-72 Cutlass cruise dash switch and servo
  78. '68 442 Rear Bumper + Brackets
  79. 74 Oldsmobile delta 88 window switch
  80. 1968 4 speed console
  81. S88 door trim
  82. 64 Cutlass Fender Badges
  83. Th350 Intermediate and Direct Drum Cushion Plates
  84. 70-72 Rear Driver & Passenger Wheelwell Moldings
  85. 67 Cutlass Seat Tracks and hood trim
  86. Small Part: shift indicator linkage for '68 column shift 442
  87. 68 69 70 71 72 Guage Pod Assembly that Needs Work
  88. 1967 442 carburetor for 400ci
  89. SBO engine
  90. 70-72 Cutlass console insert
  91. 72 cutlass pillars wanted
  92. Armrest Cups
  93. 66 cutlass floor shifter
  94. 1953 grille extension
  95. 74 cutlass seat belts
  96. 65 Vista Cruiser parts
  97. 83-84 hurst olds spoiler tips
  98. '70-72 Convertible Rear Upper Panel pieces needed
  99. Fuel tank needed ASAP!
  100. Wanted 1955 olds 88 back up lights
  101. Exhaust Valves, possibly dipstick tube needed (1967 Low-comp 425, specs within)
  102. Coolant overflow bottle needed..........
  103. Wanted Inside door pulls
  104. 92 Toronado Trofeo Control Arm
  105. 1989 Olds Touring Sedan Radio
  106. Wanted 70 Sport coupe body parts
  107. Wanted: 69-72 Bucket Seats with Head Rests
  108. Need three different posi carriers
  109. #671 Posi Carrier
  110. Wanted: 1973 Delta 88 Convertible Rear Trim
  111. Wanted: Edelbrock Performer Intake
  112. Wanted: 1976 Cutlass 455 starter part #1109026
  113. 1947 bumpers
  114. Ash Tray slides
  115. Wanted: "O" Type Posi Carrier for 8.5 inch, 12 bolt cover, 10 bolt ring gear
  116. Wanted: Original Equipment Oil Pan 455. No Toro. No 350. Confirmed 455.
  117. 70 442 Heater Duct Parts Needed
  118. 64 Olds Jetstar turnsignal switch parts
  119. wanting a 425
  120. P/S bracket part wanted
  121. 72 cutlass needs
  122. 87 cutlass steering column with tilt, floor shift
  123. 1967 442 decklid and hinges
  124. need 74-76 olds 98 coupe 1/4 window chrome mouldings
  125. 87-89 Toronado parts wanted
  126. 71 Bucket Seat Covers
  127. 442 Heat/AC
  128. 64 olds 98 door jam switches wtd
  129. Offenhauser intake
  130. Wanted 69 F-85 Parts
  131. MI man seeks 70 Cutlass Grilles, any condition
  132. 70 cutlass parts
  133. Brake Drums for 98 ´67
  134. NOS 1970 442 grilles and the phillips screw used to hold them together
  135. 68-72 Bolts for rear sway bar mounting
  136. 1968 Cutlass / 442 Headlight Housing Wanted
  137. 1957 Olds Air Cond. vents and controls
  138. 69 Cutlass auto console cover lock
  139. 1965 442 center console lid
  140. 1972 rear quarter
  141. 1951 303 exhaust manifolds
  142. gauges
  143. Wanted: junk front bench or buckets for 70-72 cutlass
  144. Olds jetfire turbo
  145. brace 1970 olds
  146. 64 Cutlass, looking for turn signal lenses
  147. Timing tabs
  148. 76-79 Olds 5-speed Shifter
  149. 1965 Jet Star Convertible Moulding Needed
  150. 72 supreme b85 moldings
  151. 72 supreme glass
  152. 70-72 power door lock mounting screws
  153. 73-77 cutlass radio bezel non ac
  154. 69 cutlass front hood molding and hood tongue/entention
  155. 62 Jetfire trim wanted
  156. 1968 oldsmobile cutlass / 442 assembly Manual
  157. Olds 15x7 bolt on superstock rallye rims pair or single?
  158. Master Cylinder
  159. 73-77 passenger alternator bracket
  160. Turbo 350 trans pan
  161. WTB - Headrests
  162. wanted Z bar stud
  163. Wtb 1966 442
  164. Wanted 74 cutlass dash
  165. ***Wanted 1969 Cutlass Core Support***
  166. ***Wanted 1969 Cutlass Hood***
  167. Wanted: 70 442 Trunk Lid
  168. 68 Cutlass/442 body parts
  169. 67 442 4 speed air cleaner with chrome lid
  170. 68 Power Trunk Release
  171. Wanted: rear bumper for 1964 Ninety Eight
  172. Wanted ! 75 hurst bracket
  173. 1962 Olds Dynamic 88
  174. 68 speedo for column shift 3 speed auto
  175. Looking for a nice 66 442 Hood
  176. Power windows
  177. 1968 442 metal hood
  178. Looking for 62 Cutlass NOS tail light housing, P/N 5951788
  179. Any affordable NOS 70-72 fenders?
  180. Wanted: 1963 Cutlass/F85 4 speed trans support.
  181. '69 dated cooling fan SHROUD 402995 for H/O
  182. 71/72 10-bolt 8.5" 3.08 Posi Rear Axle
  183. 70 Post parts
  184. 1959 98 coupe trim
  185. Wanted 1971 Toronado right (passenger) mirror
  186. Looking for complete 455 running
  187. 72 442 s hood
  188. 55 88 2 door sedan stainless moldings needed.
  189. 64-65 muncie parts
  190. 68/69 convertible rear quarter
  191. 64-69 4 speed console door/hinge
  192. looking for a 7040257 carb
  193. 68 4 speed console NEEDED!!
  194. Parts Needed
  195. WTB 79-80 Cutlass/Omega steering wheel
  196. Retainer ring for 72 Cutlass Standard Trans Shifter Boot - No Console
  197. Wanted: Oldsmobile mud flaps
  198. WTB 1969 dashboard
  199. 66 Toro Headlight Vacuum Can
  200. WTB 68 2dr. Cutlass Transmission tunnel.
  201. Plug wire bracket to valve cover
  202. Brackets for Alternator on non A/C 455 olds
  203. WTB 73-75 Hurst Hood Ornament
  204. looking for metal trans dust cover 69 hurst
  205. Wanted 68 or 69 Power Antenna Switch
  206. 1962 Bumpers
  207. 69 cutlass/442 left headlight bezel and housing
  208. 1969 toronado wanted parts
  209. Service Guild wanted, August 1962
  210. 1972 Cutlass S Grilles - NOS or Near New Wanted
  211. 1965 Vista Cruiser F-85 steering wheel +++
  212. steering column and gas tank wanted for 69 toronado
  213. ISO wiper motor w/o washer
  214. 1984 Olds 98 Brake pedal pad
  215. 68 69 cutlass 442 wheel well opening moldings
  216. 69 cutlass headlight switch knob
  217. Wtb 1970 hood
  218. Wanted 455 oem intake manifold
  219. 70-72 Black Vented Dash Pad Wanted
  220. Sending unit 1961 oldsmobile super 88
  221. Trunk Gutter
  222. 1973-75 Cutlass
  223. 72 Supreme side trim fasteners
  224. Wanted Type O 3:08-3:23 posi carrier
  225. wtb window sweep 68 442
  226. 69 cutlass drip rail moulding
  227. WTB 70 Toronado parts
  228. 12 bolt posi 68/69
  229. A/C brackets and radiator
  230. 72 Cutlass Supreme a/c vents
  231. 71-72 Parts car
  232. A/C brackets
  233. 1950 Olds Odometer speedometer needle assembly
  234. 1964 f-85/cutlass hood or trunk
  235. NOS parts & date coded 7028251 carb
  236. 68 block wanted
  237. 68 cutlass hood hinge
  238. 67 Cutlass conv top switch
  239. Looking for a 70s Toronado oil pan
  240. Oil filter adaptor + Exhaust manifolds
  241. Wanted: Solid relatively pit free frame for 59 dynamic 88 near Cleveland OH
  242. '64-'67 "A" wagon lh quarter window inside trim
  243. 67 Cutlass Center Arm Rest Trim/Covers
  244. 455 engine block
  245. 66 kickdown
  246. 1957/1958 wagon gate letters. WANTED
  247. Ram air hood for a 1972 w29
  248. 425 flat top pistons
  249. 65 olds 98 speedomoter cable
  250. '65 f85 Headlight Bez and Fender Trim
