Coolant overflow bottle needed..........
I most likely have an NOS one in my stock since I have at least 20 for the 81-88 A-G Body... I should also have the windshield washer tank as well if you need that....
The casting number & part number should be the same for coolant recovery tanks.... According to my part system, the correct part number used to be 459229, in 11/83 it was changed to 14013344, & in 7/85 it was changed again to 14085692.... Not sure why you show 14013343 unless they did decide to use a casting number instead of the actual part number, which makes sense since your number is only one digit difference from the actual part number back in 1983.... The good news, the part number 14085692, is still available from any GM dealer... GMPARTSDIRECT lists the part as available with a sale price of $15.79 (Normal list price is $23.50) plus shipping... If they list the part, it usually means that it is available from any GM dealer as well... Hopes this helps...
