68-72 Bolts for rear sway bar mounting
Looking for 4 correct style bolts for the rear sway bar mounting...the ones I have are very corroded and would like to find some nice pieces...I think they are 1/2x20x 2 5/8 ...anyone from the south have some nice ones for sale? thank you, tim
Are the ones from AMK correct?
I have had a very positive tip to use AMK, but they don't sell an entire chassis kit for 69 cutlass so I will be buying a 69 Chevelle Small block drum brake kit and using everything that is the same and the few differences I will need to buy separately. By memory sway bar bolts were an extra.
Ryan
Ryan
Ryan
Ryan
As Octania suggests, they are 7/16 bolts (and 2-5/8 length).
If you don't have to have originals I can provide new Grade 8 (originals were also Gr 8) black phosphate-plated versions....new bolts along with new stover (ie - locking) type nuts in a clear zinc finish.
Fine or Coarse thread (your choice) and 2-1/2" length ( 7/16 - Gr 8) with new zinc plated nuts.
Edit: How are your sway bar shims (if any)??
No "biggie" if you want originals but I figured I'd make the option available. If the 1/8" length difference bugs you then you should realize mine weigh slightly less than the 2-5/8" originals.....think of the E.T. you'll gain with less weight!
Everyone, Thanks for the responses...and, as you all pointed out, they are 7/16, not 1/2 like I typed in my original post....
Ryan, I could not find these original type in the AMK catalog...
Patton...I am considering these, but holding out hope that I can find some originals...will let you know shortly as I have been trying to get multiple things done in the shop this week and haven't really been here the last couple days....
I appreciate it everyone! Happy 2016!
No - that end is basically flat....no pilot points like A-Arm bolts and some rear control arm bolts. Proof is in the pic below showing the original '72 442 rear bar "F"-marked (same bolt I posted a pic of earlier in this thread).....
MDchanic
Suspension & Handling
Aug 11, 2012 09:30 PM
