68-72 Bolts for rear sway bar mounting
Old Dec 31, 2015 | 04:43 PM
69442murph's Avatar
Looking for 4 correct style bolts for the rear sway bar mounting...the ones I have are very corroded and would like to find some nice pieces...I think they are 1/2x20x 2 5/8 ...anyone from the south have some nice ones for sale? thank you, tim
Old Dec 31, 2015 | 04:59 PM
Ryan 1969 Chevelle SS396's Avatar
Are the ones from AMK correct?
I have had a very positive tip to use AMK, but they don't sell an entire chassis kit for 69 cutlass so I will be buying a 69 Chevelle Small block drum brake kit and using everything that is the same and the few differences I will need to buy separately. By memory sway bar bolts were an extra.
Ryan
Ryan
Old Dec 31, 2015 | 06:44 PM
Octania's Avatar
I vaguely recall stabilizer fasteners requiring 5/8 or 11/16 wrenches which would make the size 7/16-20, not 1/2-20...
Old Jan 1, 2016 | 12:03 AM
70Post's Avatar
As Octania suggests, they are 7/16 bolts (and 2-5/8 length).
If you don't have to have originals I can provide new Grade 8 (originals were also Gr 8) black phosphate-plated versions....new bolts along with new stover (ie - locking) type nuts in a clear zinc finish.
Fine or Coarse thread (your choice) and 2-1/2" length ( 7/16 - Gr 8) with new zinc plated nuts.
Edit: How are your sway bar shims (if any)??
No "biggie" if you want originals but I figured I'd make the option available. If the 1/8" length difference bugs you then you should realize mine weigh slightly less than the 2-5/8" originals.....think of the E.T. you'll gain with less weight!
Old Jan 1, 2016 | 08:38 AM
ROCKETMAN269V's Avatar
Originally Posted by 70Post
.....you should realize mine weigh slightly less than the 2-5/8" originals.....think of the E.T. you'll gain with less weight!
Patton, don't forget, that's "unsprung weight"; it will handle better, also!
Old Jan 1, 2016 | 11:26 AM
Octania's Avatar
Can you get these with cross drilled heads for a greater weight savings?!
Old Jan 1, 2016 | 12:13 PM
70Post's Avatar
Lol
Old Jan 2, 2016 | 06:17 AM
Talking
Actually, if you have them "gun drilled", you can really lighten them up.
Old Jan 2, 2016 | 06:46 AM
Octania's Avatar
"I thought I smelled marijuana sir. Do you have any weapons in the car?"
"Well, officer, I do have gun drilled stabilizer mounts."
"Step out of the vehicle, sir."
Old Jan 2, 2016 | 07:56 PM
66-3X2 442's Avatar
The sway bar bolts I have seen have a letter 'P' and I have looked everywhere and no success.
Old Jan 2, 2016 | 09:36 PM
70Post's Avatar
Pic shows head/marking from an original '72 442 rear bar setup..this set has coarse threads... I think we lost Tim on this thread.
Old Jan 3, 2016 | 05:29 PM
69442murph's Avatar
Everyone, Thanks for the responses...and, as you all pointed out, they are 7/16, not 1/2 like I typed in my original post....
Ryan, I could not find these original type in the AMK catalog...
Patton...I am considering these, but holding out hope that I can find some originals...will let you know shortly as I have been trying to get multiple things done in the shop this week and haven't really been here the last couple days....
I appreciate it everyone! Happy 2016!
Old Jan 9, 2016 | 03:33 AM
briane's Avatar
I've also been looking for these bolts. Did the originals have pilot points as I've seen on some Chevelles?
Old Jan 9, 2016 | 10:07 PM
70Post's Avatar
No - that end is basically flat....no pilot points like A-Arm bolts and some rear control arm bolts. Proof is in the pic below showing the original '72 442 rear bar "F"-marked (same bolt I posted a pic of earlier in this thread).....
Old Jan 10, 2016 | 12:19 AM
z11375ss's Avatar
Senior Moment Member
Go with the Hotchkiss. They're better and don't require special bolts. My two cents.
Old Jan 10, 2016 | 09:59 AM
I will try to get mine out today, or this week and examine them here:-)
Ryan
nolabigdawg
Oct 25, 2014 11:50 AM
MDchanic
Suspension & Handling
Aug 11, 2012 09:30 PM
Olds luvr
Jan 19, 2009 06:35 AM
cola
Mar 15, 2008 03:08 PM
Carleta
Jul 4, 2006 11:44 AM
