SBO engine
Old Jan 8, 2016 | 05:20 PM
85Cutty442's Avatar
SBO engine
Looking for a 350 or 403 built olds engine,
Looking for the engine to be around 350-400 hp,
Thanks in advance...
Old Jan 8, 2016 | 07:34 PM
Where are you located?
Old Jan 8, 2016 | 07:36 PM
85Cutty442's Avatar
I'm located in Washington, Pennsylvania.
Little town 30 miles south of Pittsburgh, Pennsylvania
Old Jan 8, 2016 | 07:58 PM
coppercutlass's Avatar
Chevy budget Olds powered
You looking for new , used ,????
Old Jan 8, 2016 | 08:01 PM
85Cutty442's Avatar
Either.
Just want a good reliable/ good hp engine I can put into my 85 442.
I also would like a complete blueprint of the engine with part numbers and part names so I know what I'm buying.
Thank you
Old Jan 8, 2016 | 08:02 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Copper, I did not know they were making new ones anymore. Sorry, I just had to screw with you a little bit.
Old Jan 8, 2016 | 08:21 PM
Redoldsman you caught me with my pants down lol. I was considering selling my current engine but it would need a freshen up/inspection but the price i would sell it for would leave more than enough wiggle room for that but its tried and trued running 12.6's on pump gas driven to the track and back 120 mile round trip.
Old Jan 9, 2016 | 07:20 AM
85Cutty442's Avatar
I'm interested in hearing more about that engine.
Thank you
Old Jan 9, 2016 | 11:35 AM
Its a 350 .030 ove with speed pro forged flat top pistons , sitting .025 in the hole with .040 head gaskets. Compression is 9.98 to 1 with the chambers being appx 67 cc's. Good on pump gas.
The cam is a lunati voodoo grind with 522/539 lift with 233/241 duration @ .050 lift on a 110 lsa in installed straight up on 106. ( cam has 4 degrees advance ground into it)
It has pro gear timing chain
Rod bearing clearances are .002 / mains are .0025
Oil pump is stock replacemnt.
The heads where done by rocket racing and have ferrea valves 2.07 in / 1.71 ex with new hardware , stock type seals , where milled .024 . No port work no divider welded no heat riser filler . Just a little work under the valve for the oversize.
It has PRW full roller rockers , trick flow one piece hardened pushrods
The intake is an edelbrock rpm .
Thats kind of about it. I built the engine and i would be asking about 2500 plush shipping which would leave more than enough room for a freshen up or inspection. there is way more than 2500 in it parts wise but its been used , raced , driven and i understand the devalue of stuff. I also have a th350 thats rebuilt 0 miles and a 2800 stall converter i can throw in for another 500. I dont really want to sell this engine. but i need money to paint my car and i have another engine ready to go. I can sell that one too but that one will run about 4500 but it has NO miles ported heads , studs , arp bolts , etc etc. I can give specs on that one too. Its a similar build but better parts lighter pistons and more invested in it. I have all the specs for every single clearance for that one. Its a superior build to the one i currently have to be honest.
Here it is in action. with the build i mentioned.
Old Jan 9, 2016 | 06:44 PM
Paladin31's Avatar
Very Nice U-man, sweet sounds of smallblock Olds, Mmmmm Mmmm Good!
Brett
Old Jan 9, 2016 | 08:08 PM
11971four4two's Avatar
MOTORHEAD
355
for your consideration
1975 350 block
bored 30 0ver
cast crank
turned 10 10 rods mains
fully balanced assembly
balanced pistons
balanced connecting rods
with balancer and flex plate
pistons are forged flat tops
w31 style slugs
350dollars
Old Jan 9, 2016 | 08:37 PM
That's a deal.
Old Jan 9, 2016 | 08:53 PM
MOTORHEAD
i would rather see
someone put this engine back on the street
than try to get even or make a buck
tell kelso i said hello
Ctott70
Tech Editor's Desk
Jul 11, 2011 06:49 AM
f-85
Aug 15, 2010 11:15 AM
RAMBOW
Jan 7, 2010 09:46 PM
crazy'boutOlds
Aug 24, 2009 07:36 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
