PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88]
  1. Need Upper Control Arm Bushings
  2. Looking for a dashboard for a 85 Cutlass
  3. heater blower switch for 77 olds cutlass
  4. W-31 Heads
  5. Fan shroud wanted
  6. tail light wiring for 62 88
  7. need some good stainless trim for my 1953 98
  8. 67 442 Air Cleaner
  9. 3.42 carrier for type O 12 bolt
  10. needed: 307 QJet
  11. Need 1970-72 Windshield frame
  12. Parts for 65 Cutlass needed
  13. 69 wheel well chrome
  14. Need seat belts
  15. chrome headlight bezel
  16. generator mount
  17. rear qtr patches
  18. "wanted" Power Bucket Frame
  19. 70-72 A/C controls with defroster
  20. 425 olds
  21. 68 delta parts
  22. Looking for Delmont Parts
  23. 1978 88 or 98
  24. Looking for these wheels
  25. trany
  26. 1968 delmont 88
  27. 1978-1980 Olds 350 short block
  28. 70-72 cutlass door lock rod?
  29. Four door body trim
  30. Wheels For My '87
  31. Complete 4 speed for '68 Cutlass
  32. wanted 75 H/O parts
  33. 69 Cutlass Bumper
  34. need top lever for 62 dynamic conv
  35. still need 64-67 a-body rear upper arms
  36. 1963 f-85 parts
  37. 72 Cutlass fender needed
  38. Throttle cable needed.
  39. Bumper/Grill and interior pieces
  40. Power Stearing Pump Bracket
  41. WTB: (Want to buy) parts for 1964 Olds Dynamic 88 "shipping is okay" *SOCAL*
  42. Nos 76 77 442 Grills Wanted
  43. 7029250 or 7029251 q-jet
  44. Delta Or Delmont Bumper
  45. Converting to 4 Speed
  46. 15x7 steel rally wheels
  47. Bumpers
  48. 69 cutlass parts
  49. 455 perf parts wanted
  50. Power Steering Pump Bracket
  51. stock steel wheels
  52. I want a new body kit for my auro 80
  53. hei
  54. Wanted; Molding Clips for 1983 98
  55. Wanted: Radiator for a 56 Olds Super 88
  56. Rear Bumper for 1968 Delmont
  57. Trim peices for 85 cutty
  58. Tunnel Ram
  59. 66 toronado kick-down switch
  60. 1984 Cutlass Supreme 2 door needs help
  61. 1974 Omega Passenger Fender
  62. Aftermarket or dry air filter cleaner for a 57 Olds
  63. 69 442
  64. 1973 cutlass parts needed
  65. Ssii
  66. 1964 Cutlass Side Glass
  67. 1968 Delmont
  68. need 64-67 A-BODY rear upper arms
  69. 64 olds 98 parts wanted
  70. 69 Olds Cutlass Passenger Door
  71. Please post your location
  72. Wanted Bench seat for 68 Cutlass
  73. 1999-2000 bravada grille
  74. 350 turbo trans
  75. Wanted: 56 Olds 88 Front and rear Bumpers
  76. running 455
  77. 69 Toro gas Tank
  78. '70 Cutlass parts needed
  79. Need 455 Heads
  80. !!!!!!!!!!!! need this steering wheel pic inside
  81. olds radiator overflow jug
  82. 1972 Cutlass Supreme Grills
  83. starfire exhaust manifolds
  84. 1962 Olds Dynamic 88 Trim Rings
  85. 1987 Cutlass 3.8l Carb
  86. 1969 w30 400 CID intake manifold
  87. Wanted 1966 Starfire parts
  88. 1970-1972 Cutlass
  89. '66 toro exhaust manifolds
  90. Manifolds needed
  91. crank casting 397363 needed
  92. WANTED: 77-79 Delta 88/98 Power Antenna
  93. Need A 403
  94. 55 olds 98
  95. Wanted 66-70 Toronado 15x6 rims
  96. 66 442 tail lights
  97. 1966 Olds 442 Dashboard
  98. WANTED: Trunk Bolts
  99. 1963 Dynamic 88 Holiday Coupe
  100. Wanted: 57 Olds power brake floor plate.
  101. my 62 dynamic hardtop doors stolen (green)
  102. 1966 olds delta 88
  103. 1969 442
  104. 400 trans dust cover
  105. Need "7040255" quadrajet and Fat W-31 balancer!
  106. 307 Fuel Line
  107. 350 rocket parts needed
  108. Flywheel cover Olds 350-turbo 350
  109. 1990 shift plate needed
  110. SS1 wheels, Delta, 1971
  111. Exhaust manifolds 69 98
  112. NON AC Fuel Bowl wanted early 60's
  113. 68 Toro shifter cable
  114. 87 Cutlass Doors
  115. 455
  116. 69 delta passenger fender
  117. 63 dynamic rear bumper
  118. 1970-72 W-25 Ram Air Hood
  119. 400,425, or 455
  120. heads
  121. Wanted: '71 Cutlass Hood, 15X7 SS Wheels
  122. 67 Cutlass driver door
  123. 1964 Oldsmobile F-85 4-Door Parts
  124. Interior light and stuff
  125. Looking for front bench seat 69 cutlass coupe
  126. Driver side front fender 69 Cutlass "S"
  127. Badly needed!! '64 throttle linkage
  128. 66 F-85 4-dr.. Parts needed........
  129. olds 98 1970
  130. stick-shift set-up, 65-70 Full-size B-body
  131. 371 Exhaust Manifolds / Headers Wanted.
  132. Wanted:Nice 4 speed console 70-72 cutlass
  133. W-31 intake wanted!
  134. auto flywheel
  135. Engine for a 85 Cutlass
  136. j-2 Man/and Carbs
  137. fenders needed for a 72 cutlass
  138. 1967 442 sway bar and rear seat
  139. 69 Cutlass steering column
  140. Pulley needed 81 Olds 98
  141. Looking for a '63 394 water pump pully
  142. Need 71 Cutlass front bumper
  143. 3.23 10 bolt ring and pin O type
  144. "Delta 88" script for a 1971 needed
  145. 1986 cutlass teims parts wanted!
  146. Need OLDSMOBILE ROCKET valve cover decals for 371
  147. Need a 394 head
  148. Speedo Cable
  149. 1971 Olds 98 Bumpers needed
  150. horn buttons
  151. Need 56 324 #10 heads & Jetaway
  152. steel wheel needed,just one
  153. Instrument Panel Parts
  154. 71 Cutlass Supreme grille needed
  155. Wanted-324 rods/pan
  156. Need a stock rim
  157. I need a power seat cable assembly.
  158. 1957 olds super 88
  159. 58 olds trunk
  160. 55 Rocket 88 Rear Bumper
  161. 68 olds cutlass convertible
  162. Need 73 Cutlass Parts
  163. Does anyone have any 62 Olds parts??
  164. Need intake manifold
  165. Exhaust manifolds....worth anything?
  166. 1964 Body side mouldings
  167. Need a water pump pully for a 394
  168. Need rollers for my hearse
  169. Inner Wheelhousing
  170. 1963 jetfire door windows/channelsw
  171. wanted-3or4-speed setup for B-body
  172. 66 dynamic / 88's
  173. WANTED: 80 Cutlass Coupe, Front Valance Panel and Grille
  174. Wtb: Bucket Seats For A 69-72 A-body
  175. 70-72 455 Starter cable heat shield tube & bracket
  176. SENDER UNIT
  177. WANTED 63 AM/FM Radio
  178. '51/52 accessorie steering wheel
  179. Quadrajet
  180. Tic Toc Clock Needed
  181. WANTED: 1965 DELTA 88 WIPER MOTOR
  182. cutlass doors
  183. 1968 rear bumper
  184. BBO wanted
  185. 61 olds steering wheel
  186. WTB: 1965 Delta 88 Front and Rear Bumpers
  187. WANTED: 1965 DELTA 88 FRONT DRUMS
  188. Wanted: '66 Delta 88 Power Antenna Assembly
  189. WANTED: '66 DELTA 88 REAR BUMPER
  190. LOOKING FOR 70 CUTLASS GRILLE
  191. '66 Delta 88 Convertible Frame Wanted!
  192. I need parts for my 86 cutlass supreme!
  193. 1984 Delta 88
  194. need left dual ex.manifold for 66dynamic 88
  195. Help! WTB '56-'59 J2 Rocket 88 valve cvrs.
  196. WTB Performer Olds Intake or better........
  197. 70 72 olds cutlass conv. rear seat
  198. Grill
  199. 62 F-85 Convetible Latches Needed
  200. WTB 1956 Olds 98 2dr quarter panel parts
  201. RADIATOR MOUNT
  202. EXHAUST MANIFOLD
  203. 61-62 olds 88 rocker panel trim needed
  204. overheating truck
  205. Toronado intakes oil pans and motor mounting harware wanted
  206. moulding
  207. rally wheels
  208. 1975 Olds Cutlass Supreme Bumper Filler
  209. 55 Olds circular "88" logo
  210. 55 Olds front signal lenses
  211. Finders Fee paid for info
  212. I need 1966 Delta 88 Seats
  213. 1977 98 Regency - plastic bumper filler panels
  214. 1974-1976, Delta 88 2-dr, Both Doors
  215. 1966 delta 88 conv parts.
  216. trans throttle control (kick-down?) switch
  217. 66 toronado driver side mirror
  218. 1956 Old's
  219. 1967 Positraction differential for a 98
  220. powerbrakebooster
  221. Need Top Well Trim/70 cutlass convt
  222. 455 Rocket and Tranny
  223. Starfire -65 parts wanted
  224. hurst dual gate
  225. 1969 OLDS. 4DOOR
  226. WTB: '59 Olds Super 88 Bumper
  227. 455 2-BBL carbs wanted
  228. 65-70 88/98 Dual Exhaust Manifolds
  229. 54 and 65 Starfire / 98 Rims Needed
  230. 1966 Olds Starfire Part List
  231. shifter conversion kit
  232. 1965 Delt 88 Rear Bumper
  233. motor vin # search
  234. motor vin # search
  235. 55 56 olds taillight lens (and some Ford stuff poss.?)
  236. 66 driver side rear view mirror
  237. 371 Starter ring/bottom cover
  238. 1964 Dynamic 88 Rear Bumper
  239. 1975 4-4-2 production numbers???
  240. looking for 68 442 VIN# 8Z122382
  241. 66 full size steel rims 14"
  242. 1975 ninetyeight parts needed
  243. Bench Seats for 66 88
  244. im overheating and loss of power off the line
  245. im overheating and loss of power off the line
