Power Stearing Pump Bracket
Old Jan 19, 2007 | 12:31 PM
mcutlass1969's Avatar
Looking for a power stearing pump bracket to fit my F Block from a 1976 Toronado.
Old Jan 19, 2007 | 12:34 PM
crazy'boutOlds's Avatar
I have a set from a 403. Will they work?
Old Jan 19, 2007 | 03:34 PM
mjscutlass's Avatar
parts
The 403 one's will work but if u cannot get ahold of crazy i have one set also
Old Jan 19, 2007 | 03:45 PM
Get mjscutlass ones. He's a good person to deal with.
Old Jan 19, 2007 | 05:17 PM
Ok email me at michael_kenny@csgsystems.com and let me know what you are asking me for them. Shipping zip code is Omaha NE. 68138.
Old Jan 19, 2007 | 05:19 PM
also this is for a 455. Forgot to state that.
Old Jan 19, 2007 | 05:21 PM
Why didn't you get the other set from your previous post?
Old Jan 19, 2007 | 05:25 PM
mjscutlass's Avatar
email
email sent mine is off of a 455 but there is no difference between 455 and 350. I have a 307 power steering pump hooked up on my 455 in my 83 cutlass even all the pulleys mount up the only thing i had to change from the 307 to the 455 is the lower alternater bracket
Old Jan 20, 2007 | 12:08 PM
Ok one post to clear up things. 455 block is from a 76 Toronado. Didn't have the car just picked up the motor form a local junk yard, so the brackets were not available. So this leads me to the next thing. I have rebuilt the 455 and now putting it in a 69 cutlass S. I found an upper Alt bracket but no luck locally. The only bracket and pump I have is from the 350 i pulled out of the cutlass. this leads me to my next question since the 350 bracket doesn't bring the pulley far enough forward then all is needed is to switch out the pulley or do I still need the bracket for the 455
Old Jan 20, 2007 | 01:09 PM
mjscutlass's Avatar
change pullys
yes that is correst just change the pulleys and u should be good
Old Jan 20, 2007 | 03:58 PM
ok by chance do you have a pulley or advice on were to get one. Junk yards around here don't keep the old cars.
Old Jan 20, 2007 | 04:04 PM
mjscutlass's Avatar
find
Do u have air conditioning in ur car and are u running the same pulleys
442Harv
Jul 30, 2012 07:12 PM
WinterGardenFL442
Jan 4, 2012 03:39 PM
xerxes600rr
Aug 30, 2011 06:43 AM
GreazyAnt
Apr 28, 2011 09:41 PM
jensenracing77
Feb 23, 2009 05:52 PM
