View Full Version : Parts Wanted
- Las Vegas Wreckers
- wanted 56 fender skirts
- Need floor panels for '65 Jetstar
- '64 330 balancer
- WANTED: 15x7 SS2 set
- WTB: '77-'79 403 Air Cleaner Lid
- 90-92 Trofeo Parts
- 1965 Cutlass Rear Axle Shaft
- Any '56 Olds 4 dr hardtop parts cars out there?
- 70-72 Dual Gate Shifter & Console
- 55 4-door sedan odds and ends
- 70 71 72 rear convert upper door panels
- Harmonic Balancer-1968 350 engine
- Looking for front hub assembly-68 cutlass
- Wanted: 4 XT Wheels
- Heater/ ac fan control knob
- hood inserts
- Need 1966 cutlass fan shroud for 330
- 1957 1958 Power Windows
- Bolts/Screws for proportioning valve for my 72 Supreme
- Wanted: Jack Assembly for a 70
- Steering wheel
- 1970 Cutlass/442 Blue Interior Pieces
- Wanted: 78 Delta 88 - Aluminum Hood Hinge
- Looking for Lower left control arm for sale.
- Looking for a toro engine mount for 39 olds project
- 73 delta 88
- 1985 Cutlass supreme
- Looking for lighting rod shifter
- Wiper Arms Wanted
- ram air setup {air cleaner}
- Wanted - trunk lock solenoid for '86 Cutlass
- 1964 Oldsmobile Cutlass Conv
- ... a long shot
- Parts for 68 olds.98 convertible
- 72 Olds Door Thermometer
- Standard set up
- 1969 antenna bezel
- Power antenna (whole shebang I think) + speakers
- 425 engine
- quadrajet 7040257
- WTB 1964 14 x 6 plain steel wheels
- Primary throttle shaft for 76 Pontiac Qjet
- 70-72 Black Bucket Seat Headrest(s)
- Rear chrome moulding for 72 Cutlass 442
- 56 Power steering pump manifold.
- Right Fender Bracket 67 Cutlass/442
- Truck floor plug
- 1967 98 tail lights
- Manual Steering gearbox for a 67 442
- '56 inside door handle mechanism wanted
- Wtb radiator support for 76/77 Cutlass S
- 308 Posi for 71
- Fender Right Side 1964 Dynamic 88 Wanted
- 73 through 75 Cutlass wish list
- wtb NOS 4 spoke steering wheel
- 1970 Sports mirrior
- wanted: 455 pistons, standard with small dish
- 59 olds 98
- WANTED 70 convert bucket seat seat belts
- WTB 65 speedo cable
- Looking for E heads
- 54 Olds Convertible door sills
- 68 Cutlass S hood piece
- 68 hurst, 442, or cutlas S HOOD T3 REAR AXLE HSNG
- 1977 crossmember for dual exhaust
- WTB: Rear end
- 64 F-85 heater box
- RE: steering wheel and horn contact/signal cancel
- 1968 cutlass radio bezel/plate
- 1970 442 sports coupe (post) interior
- 70 console parts
- Passenger side rear axle
- 1967 442 front bucket seats wanted
- Edelbrock O4B Intake Manifold
- trim pieces for 69 442 hardtop(above windows by headliner)
- WTB: Vapor Canister holder/screws for my 72 Supreme
- WTB:15X7 Olds SSII Rally Wheels - Bolt on Centers
- 6qt Toro Pan Dipstick + Tube
- Wanted: 68 Delmont 88 Rear Bumper
- WANTED 71 convert radiator support
- I need a 68 Cutlass 2dr passenger door & fender
- 61 62 Starfire Console Part
- 1968 Cutlass Fuel Gauge
- Cylinder heads 394ci 1963
- Wanted: 1970 - 1972 Cutlass S Drip Rail Moldings
- Wanted: 1970 Cutlass S Driver Side Grill
- 425 crank wanted
- Wanted: Cheap, Usable '68-'70 350 in the NE US
- a few other parts i need for my 68
- Domb light for a 1968 Cutlass convertible
- need quarter trim peak molding ......
- Desperately seeking "404847" water pump casting
- WTB 15x10 racing wheels
- Wanted 1970 442 Grill
- Need Grills,door lock ring,pilar emblems,headliner clips
- WANTED - Rear Tail Panel 70-72 Cutlass 442
- New front clip
- new front clip
- Parts wanted for 71 Delta Royal convertible
- 64 Cutlass Clutch Pedal Assy
- Wanted - nice set of Texas 1972 license plates
- 68 cutlass s, 442 or hurst hood
- Wanted: Tan/Brown GM Rubber Floor Mats 1971-1988
- Olds Custom Cruiser Wheel Well Trim
- WTB Texas Vintage 1969 Plates
- WTB: 70-72 Cutlass Console
- 73 Toronado
- 1967 NINETY EIGHT parts needed
- 72 Supreme Louvers and/or Grille
- 67 quarters
- 67 rear interior door panels
- 1973 Toronado Restoration - Brasov,Romania
- convertible quarters
- 1/4 Panels
- 1968 442 Rochecster Quadrajet 7028253
- fender skirts wanted
- WTB: Alternator Brackets 69-71
- 1956 88 parts wanted
- WTB 330 or 425 flexplate
- 69 H/0 (442, cutlass) pull handle
- 1968 4-door Delta Custom Trim
- 69 body shell 442/cutlass
- Body shell for 69 442/Cutlass
- Wanted: Lower control arms
- wanted stock 4bbl manifold/carb/air cleaner for 350
- 425 Oil Dipstick & Tube
- Glove box light
- Vintage style tachometer
- Horn relay for 64 Olds
- GM Sports Salvage 68 Tachometer
- Olds standard trans
- windlace 1969 442
- 67 Cutlass trim
- 72 442 Frt Intake Manifold Vacuum Fitting
- 86 442 Ram air or cowl induction hood
- WANTED a std 455 N-crank or 68 455 steel crank
- 64 F-85 Cutlass radiator support
- 1987 Toronado Moon Roof Seal
- 1955 olds 98 trunk emblem
- WTB: Mint pit-free 10-bolt rear end diff cover
- WANTED 455 torque plate
- wanted harmonic balancer for 56 324
- 68-69 Hurst / Olds Dual Gate Shifter Bracket
- Parts for 70` Delta 88
- WTB: 66 Cutlass Plastic fan shroud
- Wanted: Oldsmobile Emblems
- 1965 cutlass fuse block--free or cheap
- Wtb 8 Track tape player
- need Rochester Quadrajet for 307 Delta 88 (1985)
- slotted wheels/ mags
- WANTED: 66 or 67 Olds 4-Barrel Air Cleaner
- Looking for Parts - 80s GM and 50s Oldsmobiles
- Fender trim
- Parts for '56 Olds
- NOS 4 spoke steering wheel
- 64 rear quarter trim clips
- WTB 46-47 coupe or convertible trunk lock
- Outdoor Car Capsule (Min 18ft)
- 1980-85 Delta, 80-81' 98 Oldsmobile rare parts
- WTB: dashpot for '68 442
- Wanted: '69 Cutlass Trunk Lid Moulding
- WANTED: 70 SX Hood Emblem
- WANTED: 1957-58 J2 Air Cleaner
- Olds 394 Vintage Valve Covers Wanted
- 1970-442 open face alernator
- Stainless Vent Shades for 69-Vista & 76 Wagon
- 1976 Custom Cruiser Rear Bumper
- 1966 Starfire wheel well trim pieces
- 70 Vista Mouldings
- WTB : 67 442 Hood
- 54 Olds Rear Bumper Guards
- 1954 Rear Bumper Guards
- 70-72 console insert and shifter ball
- wanted - preheated air intake shroud 1972
- WTB 68-69 442 patch panels
- WTB: Original Front Upper Control Arms
- Wanted: 1967 442 Head light doors only!
- Space Saver Spare
- 394 Running Motor
- 72 cutlass window wash bottle
- accelerator cable.
- Single Groove Water Pump Pulley 66 67
- WTB passengers side 69 OAI scoop
- 57 olds parts
- 66-67 cutlass ragtop parts needed
- WTB ASAP!!: 68 442 air cleaner part
- 72 442 Fan Shroud/Harrison Rad/Fan Clutch
- 72 442 Fan Shroud
- Wanted Resonator and antenna mast for a '66 98
- Wanted Rear Bumper and side view mirrors 1979 Delta 88
- 215 camshaft
- Looking for Parts for 69 Cutlass
- Hood Springs 69
- Wanted: Large Sway Bars '71 to '76 Fullsize
- 1986 Oldsmobile Custom Cruiser Parts
- 67 Cutlass Holiday Coupe Rear Bumper Needed!!!
- Factory tach for 81 Omega
- SBO vavles 1.875" int./1.562" exh.
- adjustable rocker or pushrod 324 olds
- 68-69 1/4 sail panel sections
- SSI center caps
- 1969 convertible Frame
- Large valve heads
- WTB 1983 Front license plate holder
- 72 Supreme Metal Front Fender Wells
- 1966 Cutlass Convertible Quarter Window & Pinch Weld Trim
- WTB Passenger side defroster vent. 72 Cutlass
- Bent hood hinges, need 2 for a 71 cutlass
- Fender piece 64/65 f85
- WTB single 15X7 rim
- 1989 Regency 98 ---- rear bumper wanted
- Factory Floor mats
- 15x7 SS ll's
- WTB dash studs
- Wtb 69 442 air cleaner
- Wanted: 71 / 72 442 Rear Bumper
- 1954 Oldsmobile rear bumper guards
- WANTED: 15 ssII/III and 70 "S" grill
- 1971 sienna interior stuff wanted...and other 71 items
- Wanted: 1957-58 Interior Headliner trim
- 72 roof section
- Pontiac / olds engines
- Fan shroud for 85 Cutlass Supreme
- wtb 15th anniversary license plate 83 Hurst
- 64 F-85 Hood
- Hood Latch linkage Rods
- TH 400 shift cable bracket & clip
- want: '56 back up light chrome housing
- 1940 Olds model 70 club coupe
- anyone got any cutlass parts in Nova Scotia
- Radio
- '84 Ninety-Eight Wire Wheel Center Caps
- 1972 442 Cigarette lighter assy
- Wanted: BBO Professional Products Airgap "Crosswind" Intake/Lunati 60803
- Anyone have parts for 1969 Oldsmobile Ninety Eight?
- 67 442 Cruise Servo
- 70' Cutlass rad top plate
- Rocker Arm Wanted
- 72 Olds Cutlass Supreme Air Clearner Needed
- Set of White 1975 Super Stock III rally wheels with trim rings and center caps
- 66 Cutlass Horns
- I need a choke!
- 69 442 coupe trunklid
- Looking for a drivers side exhaust manifold off a 63-64 Starfire
- '69 Cutlass Radio Plate
- 68 Cutlass deck lid
- 69 front fenders HELP!
- 324 pushrods
- rear panel 1964 starfire
