WANTED 455 torque plate
Old Nov 20, 2010 | 10:18 PM
sx455raidercelticfan's Avatar
hi, im looking for a used torque plate, my cam change has turned into a engine rebuild, i dont want 2 spend 500 on a new 1, if any1 knows of a shop that will rent 1 that will help 2, thanks every1
Old Nov 21, 2010 | 10:34 AM
Bobsw32's Avatar
BobsW32
There are a couple of us here who rent out their torque plates.
I rent mine for $20.00 and you pay the freight back.
Has fastners and head gasket with it
Bob Rosa
Old Nov 21, 2010 | 12:51 PM
Run to Rund's Avatar
If you want your own, J&S machine has them for a reasonable price, $150
http://www.jsmachineoldsmobile.com/PRODUCTS.html
Old Nov 21, 2010 | 03:57 PM
wow 150 is cheap!!! any idea whats the difference between that 1 and this 1 for 500?? http://www.cylinderheadsupply.com/ol-1.html
thanks bob but if the 1 for 150 will work for a 60 over hone ill just buy my own and let it sit till i need it again, 150 is a deal for a hard 2 find part
Old Nov 21, 2010 | 04:09 PM
Bobsw32's Avatar
BobsW32
Jim
Will take good care of you at J & S.... He is one of the good guys......
Old Nov 21, 2010 | 05:23 PM
The expensive ones such as BHJ are 1.75" thick cast iron or aluminum. J&S is two pieces of 1/2" steel welded together with precision torched or laser cut holes. Functionally, I think the J&S piece is just fine; I bought one. All it is supposed to do is stretch the block in a way similar to what the head does. I expect the J&S piece does at least 80-90% of the good for a small price. He can also sell you correct length grade 8 bolts and washers for another $25.
If you just have to have every bit of the possible good, you would have to use a dial bore gauge and the correct gasket, a new one, torqued to spec, then after measuring the distortion, bolt on a torque plate and gasket and torque the bolts to whatever torque spec gives exactly the same distortion to the .0001 inch.
Olds442toro
Feb 25, 2015 06:22 AM
Macadoo
Jun 7, 2014 08:09 PM
smcurro
Jan 8, 2013 06:36 PM
Al2011
Feb 15, 2012 03:57 PM
Bobsw32
Aug 14, 2009 07:45 PM
