View Full Version : Parts Wanted
- 67 Delta 88 Interior Window Trim Piece
- 71 cutlass inner fenders needed L/R needed
- anyone wanting to part with an edelbrock 2151 for olds 455?
- cheap radiator wanted
- oilpan
- Need Turn signal switch & Wiper motor
- 7.5 posi 26 spline wanted
- Wanted g-body 78-88 clutch pedals
- 1970 Engine/trans ...
- 1965 OLDSMOBILE STARFIRE for parts
- Body Trim For Cutlass Convertible
- th-350 core
- disc brake spindle
- Short Oil Filler
- comp cams roller tip rocker (1442) kit
- Looking for 66,67 Cutlass 442 instrument panel Cores
- '68 F85/Cutlass/442 'Vert/4 door decklid
- Oil pan
- NEED ONE 65 Window Fuzzy?
- 68 442/cutlass console lid (underside)
- Need 72 Cutlass Coolant Jug and Bracket
- 1972 Cutlass Frame Mounts
- 2 speed wiper motor
- Door and Trunk lock, with key
- want 303 or 324"motor+1950 "see-thru' hood
- Wanted-Set of Buckets '68-72 A-Body
- 84 Cutlass V8 Fan shroud
- 72 Rear Quarter Panels
- 1970 A/C pulleys (feeler)
- Black seat trim Aprons
- 66 442 parts wanted
- Supreme Tail Light Lens Screws
- shorty headers wanted
- tunnel ram wanted
- 65 Cutlass Trunk Letters
- rubber plug for OAI breather base.
- Need 72 core support
- Quadrajet wanted
- Stone shield/air dam
- 68 tilt steering column
- Chrome Parts Needs 69 Ninety Eight
- 4 speed wanted
- 1963 394 alternator brackets
- Wanted-- 71-72 442 LH Grill
- Wanted-- 69-72 Cutlass Tilt Column w/ Column-shift
- 72 Cutlass Hood with Louvers
- Drivers Side Exhaust Manifold 1972 Cutlass w/ 350
- GM Performace Parts Gauges with Oldsmobile Logo
- gen bracket
- Wanted - dead or alive! Canon S2, S3, S5 camera
- Road Block - 78-79 window trim needed!
- 1964-1965 J-Star and Starfire RESONATOR
- 1967 442 "C" heads with A.I.R. ports
- Looking for 3x2 intake Edelbrock ol396
- Need 68 31 spline t3 axle all or part
- 57- Ht. super 88 or 98 door trim.
- rochester two barrel
- 62 starfire, rear side molding!
- Console Lens
- Sport wheel Hub/horn contact
- need gbody fan shroud for v8 car
- 73-77 cutlass supreme rear bumper molding
- 70-72 convertible top boot black
- looking for some wheels
- '67 Olds F85, Cutlass, Vista Cruiser parts wanted
- 442 air shocks
- 46-47 Brake Pedal Assembly 60 Series Hydramatic
- cutlass console part needed
- NIGHTY-EIGHT emblem
- 66 442 Hood
- 56 olds Super 88 2 dr HT Stainless trim
- cutlass 15" chrome ralley
- 72 Fasten Seat Belt Indicator
- 69 Wheel Trim Molding
- looking for a rebuildable 7040250 carb
- Nice Original used or NOS? rear 71 bumper bolts
- 65 olds a/c evapoator
- Needed: Wheel well molding
- OAI Air Cleaner
- Cutlass Speedometer Part
- seats
- Keys
- 1961 Dynamic 88 Reverse/Back Up Lights Wanted
- Wanted: 1975-1977 15X7 Rally Wheels (5).
- I.D. wanted and WIW ?
- 68 h/o parts needed
- 1975 H/O sail panels wanted
- delmont 88 parts needed
- need p/s pulley
- 69 Cutlass
- 64 F-85 post doors
- Rally Gauges...No Tach
- Reverse light housing for 72 cutlass
- a/c vent pipping
- 1970 442 hood
- need lower trim for g body
- WTB nice front bumper for 65 Jetstar88
- Need Black Glove Box door for 72 Cutlass
- 1967 442 Steering Wheel needed
- Need relay
- 72 Cutlass non-tilt column shifter?
- 66/67 SS1 Wheels 795C
- 68/69 Cutlass Convertible Quarter Peak Mouldings
- looking for a complete cruiser control kit 67
- 1964-1965 Resonator
- Parts for 72 Cutlass
- 400 turbo shifter cable bracket
- Seat Belts
- wanted: 68/69 quadrajet baseplate
- hubcap tool
- 1965 starfire shifter
- wheels needed
- 14x7 ss
- 1970 High Compression piston(s)
- 72 cutlass blower resistor
- 1970-72 Cutlass Supreme Trunk Lid wanted
- 1937 Olds
- gbody v6 frame mounts
- 69 parts wanted (buy or trade)
- Need 69 Cutlass Supreme Parts
- Chrome radiator support
- 1969 442 antenna
- Wanted: 1963 Cutlass Front Windshield Channel
- Rally Wheel Horn Button
- 66 F-85 red standard seat belts
- Need 68 h/o non a/c axle
- wtb: 1964 442 air filter housing
- 67 425 Rod
- '70 Cutlass convertible switch bezel, Olds vanity mirror
- 1967 interior clips
- Need 67 442/Cutlass Manual Floor Vents Gold
- 1970 parts
- rear window defroster
- 1968 442 Non-A/C dashpad
- G-body Engine Perches
- 72 442 sunroof parts
- 1973 olds 98 headlight bezels
- parts needed for 60 dynamic 88
- Need 1970 cutlass back windshield Chrome.
- Parts needed 72 442 "S" Right side complete quarter panel Dallas area??
- 1970 Delta custom clock delete cover
- tail lights for a 1956 olds 88 & blinker covers for the front bumpers
- WANTED: 1962 olds bumper
- 64 dynamic, both bumpers, help!!
- 350 olds eng wanted
- Need some 4 speed parts for 69 442
- Looking for a 4bbl Carb, St. Louis, MO
- Exhaust manifolds from a 1965079 Starfire
- driveshaft yoke for 2004R transmission
- 1968 Cutlass "Post" "B" pillar trim
- body trim and bumpers for 56 88 holiday edition 4drsd
- 66 f-85 drivers mirror
- Glove Box Emblem
- relay
- 1955 Super 88 needs a super radiator.
- 84 Cutlass 2 door tail light (Pass.)
- relay
- Ignition switch bezel for 68 Cutlass S
- 1985 olds 442
- 1975-1976 oldsmobile instrument cluster
- olds 350
- Chev 202 heads
- 1971 olds oil,temp gauge from rally pack
- 1969 delta 88
- fuel gauge
- 1964 Jetstar1 exhaust resonator
- 72 Cutlass Sport Steering Wheel Hub
- reverse housing lights for 72 cutlass
- 69 350 exhaust manifolds
- 67 442/Cutlass Console (Automatic) Door and Hinge
- Front inner wheel housings
- '66 F-85 2-bbl air cleaner
- Needed 72 engine wiring harness
- Parts for 68 Olds 442 convertible
- Needed one set of 1972 7a Oldsmobile heads
- wanted 1972 cutlass supreme trim
- Wanted - 1972 steering column cover
- Need 215 V8 Intake Manifold
- Need 72 cutlass supreme parts
- neutral safety switch
- 66 Olds 98 Parts
- Need 66 Olds Delta 88 sunvisors.
- Parts needed for 1970 delta 88 w/455
- 1939 oldsmobile 70 series need parts !!
- Manifold Vacuum Switch
- 69 442 2 parts wanted
- Looking for Chrome Pass. Mirror
- still looking for a old school looking spoiler
- 12 bolt olds gears needed 3.08 3.23 3.42
- 1970-1972 vinly top trim set
- 1940 70 series hood ornament
- 68 Cutlass Convertible Rear Armrest Panels
- 70-72 Console Harness
- 1965 cutlass AM/FM radio wanted
- Looking for a nice 68-72 olds 350
- Wanted: distributor vacuum control valve 1971 Cutlass
- 1969 Delta 88 Royale hood
- Still need for '65 Cutlass/442
- WTB Center dump 425/455 exhaust manifold
- 68 cutlass 1/4 panel
- 71 olds rear axle needed
- 1962 Cutlass Hood spear
- 1968 Cutlass/442 doors
- 1962 98 4d hardtop
- 1966 Toronado Fenders Needed
- 1970 ,71,72 Parts needed
- 66-67 A-Body window regulators
- shifter parts wanted
- 71 455 dash pot
- 1987 olds toronado
- '66 Olds 88 Fender
- 61 Olds Starfire Rocker moldings
- Battery Cable Protector Tube
- 1968 cutlass "s" convertible stock wheels
- Trunk Weatherstrip channel needed for 1972 Cutlass convertable
- Vintage Mallory Distributor for 455
- exterior side molding/interior parts "442"
- Radiator/Fan Shroud Brackets
- Dealer salesman option booklets wanted
- Wanted parts 89 Olds 88 Royale Brougham 2 dr
- 69 442 alternator bracket
- NOS FRT TURN SIGNAL LENSES @ UPPER/LOWER TAIL LIGHT LENSES
- Valve Covers
- F85 Club Coup tailpanel trim
- 81 Sport Omega parts.
- top front fender trim for 64 starfire
- wheel opening mldg
- OLDS 350 DIESEL engine wanted
- looking for a 50 olds hood latch panel
- 1969 98 driver's side convertible hydraulic cylinder
- Hard to find part wanted
- 73-77 clock wire
- alternator Brackets
- FRONTBUMPER
- Looking for complete white interior for 72 cutlass convertable.
- need some parts!!!!!
- Trunk lid n/plate
- Need Starter 1108389 Coil 1115238
- IINTERIOR PANELS & REAR SEAT FOR 72 DELTA CONV
- Wanted: 1963 Olds Cutlass F85 new brake shoes, wheel cylinders, master cylinder
- 57 Olds Left Front Fender
- fender
- Dash Pad
- A-Body Turning Lamps ...
- 70 "O" type posi carrier
- 65 Cutlass remote mirror
- WTB 1971-72 10 bolt Posi
- 68-69 Cutlass dash wanted
- NEEDED Door hinge spring
- Fuel Gauge
