wheels needed
Old Jan 23, 2010 | 09:07 PM
Bob Lynch's Avatar
wheels needed
mounting 275 60 15s on rear of 69 442 rag top ... understand that I need 15 x 8 with 4 to 4.5 back space to make them fit right ... anyone out there have something that will work? Have SSII now but narrow and anywat I want to keep my other tires mounted and ready to go back on... Bob Lynch .. bynch@fusioncmg.com ... 949 466 7873
Old Jan 23, 2010 | 09:25 PM
2blu442's Avatar
Bob, if you want to keep the stock look you can have a set of 15X8 inch wheels made by cutting the center out of some 14X7's and having them welded into 15X8 blanks. That way you can put the backspacing at whatever you want. I know there's a guy selling on ebay that does that. I had a set of 14X7 SSI wheels made into 15X7 chrome plated rims. John
Old Jan 24, 2010 | 07:54 AM
Bob Lynch's Avatar
amazing! will consider that ... must be a good blacksmith around los angeles somewhere ... have u ever run 275 60 15 on the rear of an A Body? Is 4 to 4.5 the right b s? ... thanks ... Bob
Old Jan 24, 2010 | 08:58 AM
leadfoot067's Avatar
that backspace will get it done...stocton wheel will make you what you want..
Old Jan 26, 2010 | 06:21 AM
dc2x4drvr's Avatar
Yah, Stockton Wheel, or Wheelsmith, both in Cal, and they both do excellent work..however, you may want to find deeper trim rings first, they're hard to find with the factory style hole for the valve stem, then you can do some measuring so as to have the ring fit the same as your 14" inchers.
I'll try to get some pics of 15x8 SSII's we had made.
My442
Dec 26, 2017 05:08 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
69442murph
Feb 19, 2012 05:00 AM
WTony
Jan 15, 2011 07:53 PM
Natas
May 3, 2010 04:02 PM
