View Full Version : Parts Wanted
- Sport Steering Wheel-Small Diameter
- Need a crankshaft for a 68 350
- Iso B body 67 & 70 drivers front fenders,70 r. bumper
- SS3 wheels wanted
- Looking for an engine.
- Quarter glass molding
- Wanted 1966 oai shroud
- WTB 455 short block in Norcal
- 1970 A/C compressor hold in relay
- 70-77 Sport Steering Wheel Horn Cap
- 1978 98 Red Steering wheel and tilt column
- Bumper fillers
- Front Bumper Fillers-1975 Hurst Olds W-30
- Factory wheels
- 1969 Oldsmobile 442/Cutlass PWR Antenna
- 1975 Hurst Olds W-30
- I have parts to trade
- backup light housing
- 67 cutlass 2dr convertible or hardtop drivers door
- 68 442/cutlass tail lights
- WTB 1970 Ignition Lock NOS 3981938
- 1 Trim Ring for SS2 14x7
- 400/455 Oil Dipstick
- Wanted a 1972 ram air hood
- 37 4 door parts wanted
- 1965/1966 Jetstar 88 spindles
- 66 Electrical Routing Tube Clamps Wanted
- VWTB: '69 442 Complete Bumper Jack
- 1970 cutlass driver door
- WTB: 1967 442 HB Code Wheels/Rims
- 98 custom sport coupe
- 70 Cutlass front bumper brackets / braces
- 67 2-dr parts needed please read
- Olds Rally Wheels 15"
- '65 bumper brackets
- 1964 F-85 front clip wanted
- WTB Hood for 70 cutlass
- 71' Cutlass Rear bumper guard strips
- Steering column washer + wave washer ( 76'?)
- 70-72 Cutlass Driver door
- Seeking List of 1956 Oldsmobile Super 88 parts (4d HT)
- 1972 455 power steering pump
- “Seeking 455 olds engine from a crackhead“
- Seeking: 70 442 Hot Air Pipe
- 1964. 98 394 engine parts
- 67 inner and outer rear wheelhouses
- 1971 Olds 442 Manual Trans Crossmember Wated
- Looking for plastic space for my 66' 442
- 1963 Dynamic 88 Hood Lip Trim Wanted
- showroom dealer oldsmobile license plate
- 1967 Cutlass Supreme Rear Quarter Panel trim moldings
- 1965 F-85/Cutlass front bumper
- 68 442 Antenna Base/Lead in
- 69 2 door hard top factory tinted door glass and hardware
- 70 sport mirror
- 68 442 drivers side bucket seat
- Wanted 5x5 chrome reverse wheels
- 15x7 SS2 Wheels
- TCS solenoid #1114428
- Consul top plate
- Power Antenna
- 1970 W31 Carb 7040255 trade ??
- 66 L69 4 Speed Accelerator Bracket Parts Needed
- 8 track parts
- 66 67 remote mirror mounting bracket
- 1967 442 4 speed
- 1970 W30 auto carb and dist (69 dates)
- Anywhere I can buy the window tracks/mechanism for a 1965 olds delta 88 coupe?
- Need '71 Cutlass Supreme Delux Steering Wheel
- 1969 442 Hood Springs
- bucket seats for 1962 Oldsmobile dynamic 88
- 64-65 Auto Floor Shifter Trans Rod
- LOOKING for running 455 long/shortblock
- 67 Cutlass Left Rear Wheel Opening Molding
- R/S lower tail light lens 67 Cutlass Supreme
- Need passenger door for 71 Cutlass S
- Anyone have some reproduction 1968-1972 convertible weatherstripping
- 68 442 ignition switch connector
- 1970 cutlass lighter housing
- Wtb: a/c compressor brackets 1958 thru 1962
- 70 cutlass, exterior front door handles
- 1973 cutlass supreme parts
- Hood wanted
- Olds hood
- 1970 Disc Brake Hold off Valve & bracket
- 67 cutlass/442 AM-FM radio parts
- 65 Auto Shifter Wanted
- 1977 Cutlass Bucket Seat Parts - Wanted
- 1973-77 Cutlass Rally Gauges - Wanted
- Wtb
- 90 degree transmission adapter
- Pittman Arm
- 1967 Cutlass Floor Shift Tilt Column
- 1970 supreme gear indicator mechanism needed
- Air breather
- Buy Steering Column Oldsmobile 88
- 350 exhaust manifolds
- Black 1968 convertible rear seat covers (new)
- Tilt column directional lever
- Air breather
- Original notched valve covers in very good condition.
- frame wanted
- WTB WHITE '71 Supreme bucket seat covers - survivor, nice used, etc
- Distributor Vacuum Advance Wanted
- Hood molding
- WTB: TCS Bracket
- Wanted 71 thru 76 Olds 98 AM FM stereo radio
- Steering Wheel Gasket 1970 442
- 1969-70 NOS or Takeoff 14” Wire Hub Cap 402495
- 1971 4 Door 98
- 70 olds f85 parts needed
- 90 degree M21 Adapter Wanted
- wanted 70-72 cutlass front fenders
- 68-72 convertible Pinch Weld Moldings
- 72 CS Grill Oldsmobile Blk. back plate
- Trunk lid for 1970-1972 Cutlass convertible and 442 convertible.
- WTB 66-69 OEM 4 Speed Reverse Shift Rod
- 1967 442
- 67 Cutlass Air Conditioning Vent Bezels needed
- Original 1968 442 W30/W31 or Hurst Olds Air Cleaner
- Looking for a ‘69 cutlass frame or rolling frame.
- 1949 Olds 88 Hood Release Cable
- WTB '66-'69 4 Speed Shifter complete
- Bench seat release cable
- 68 A Body dash
- 1970 Cutlass htp trunk lid
- 68-72 headliner side trim
- G body - 86 supreme front driver seat
- 1973-1977 cutlass / a body rear end core needed!!!
- sbo heads
- 68-72 Deluxe Seat Belt Receiver Cover
- Engine oil Dipstick and tube
- White Hurst shift knob for 67 442
- new dash
- Bumper filler/Grill
- 69 cutlass convertible frame off
- Thermostat housing
- Horn button assembly
- Rear end cores to build Ohio Akron Cleveland area
- Looking for 425/455 Big block core
- 69 cutlass hardtop/post tail lamp panel with partial floor
- 1968-9 Cutlass Washer Reservoir
- Steering Gear
- WTB Exhaust Manifolds
- 1970 442 Convertible Sail Panel plastic backings
- 1970 Power Door Lock Switch
- 1970 Sport Steering Wheel horn hub
- 1970 442 Glovebox Emblem needed
- 1970 Intake Manifold Vacuum port
- 1968 Delmont pot melt script pieces needed
- W30 parts trade ???
- WTB: 71 W30 intake
- Wanted Quadrajet 7040256 Carburetor 1970 W-30 4SP
- Dealer tag ; Roger Holler Olds Orlando
- 67 Cutlass Supreme Fender, wheel and door lower moldings
- Iso engine parts 350
- 68 442 post trunk lip molding
- 66 dynamic fuel sending unit
- frame wanted 64 or 65 cutlass ( 4 speed frame only )
- 1936 Olds Dash Pieces needed
- Anyone have a sbo dual quad intake?
- 68 442 headliner clip
- Power window fuse box tap
- external water pipe fitting 303 v8
- 69-72 bucket seats
- 65 Chrome
- 1964. 394 headers
- Parts for a 58 Hardtop or Fiesta
- 1970 Olds 8.5 "0" axle gears
- 58 olds fluid coupler
- 1970 Oldsmobile Cutlass S grills in used, driver condition
- Wanted 1966 Cutlass 442 headlight buckets
- Looking For: 1968 Speedometer, Auto floor shifter
- 69 442 splash shield
- WTB 1968 Tilt Steering Column (Floor Shift)
- WTB 68-72 Clutch / Brake/Clutch Pedal Assembly
- Multiplexer support bar - ‘70 Cutlass
- Wanted '69 Cutlass tilt column
- '67 Cutlass Speedo needed...
- Wanted - A Pillar Covers for 1971 "S" Posted Car
- Wanted nos 1973407 vacuum advance control
- WTB 1964 Olds 98 Tail light lenses
- 1977 Cutlass Supreme Grills
- Rear 71 Sienna seat belts
- Wanted: NOS 1970 Parking Lamp Lens - RH
- 72 SSII Bolt On Center Cap Logo Stickers
- Wanted 1968 4 core radiator top plate
- 66 cutlass long mounting screw for round wiper motor
- 1955 Hydramatic slant pan.. need fill tube & dipstick
- Wanted: 70-72 Black Inner Fender Well - LH
- Inner wheel house fender
- WTB | 72 - 455 | Alternator Lower Bracket needed
- 1970 Cutlass gauge pod blank
- Paint: Seat covers: Vinyl top: 77 Cutlass
- Comp plus shifter
- 1957 diaphragm and bracket for water control vave
- 1970 W25 Factory Hood Screen
- Kick panels, black, 70-72, non-AC, vent window
- NOS Cables for Vent Pulls for non-AC kick panels #8756278
- WTB CT or CO Dealer Plaques
- Need fenders. 1970 Delta 88 sedan hardtop.
- 1970 Cutlass Supreme Hood Spear
- Need package tray metal, some call it the tulip panel. On a 71 Cutlass S
- 70 Cutlass "'S" or 442 Passenger Quarter Panel
- W24 Hood Screen for 70
- 57 Olds 98 hood
- 1964 grill emblem
- 1968 442 31 spline axle needed
- 64-67 Rear seats(any a-body)
- ISO decent set of 71 Cutlass Rocker Moldings
- WTB: Chromed Valve Covers for Olds 350
- Right quarter glass molding with rubber seal
- Visor bracket
- Visor plate
- 69 F-85 Gauges
- Power steering pulley
- Washer sprayers
- 1971 Cutlass Sienna Color Ash tray Door
- 83-84 G Body NOS Maple Red Seat Covers
- 1963 Cutlass Hood Needed
- WTB 68 Cutlass Misc. Parts
- 1966 cutlass supreme f85 rear bumper needed
- Brass external water bypass fitting for 303
- 67 Holiday Coupe Parts
- Need a 65 F85/442 shell body
- Early 7028251 Q-Jet core needed
- Wanted factory tricarb accelerator rod
- 1967 Oldsmobile Vista Cruiser Window Rubber
- Mid 70's cutlass? roof badge/emblem
- WTB Driver quality 1971 Oldsmobile Cutlass Headlight bezel
- 66/67 Cutlass 442 Speakers
- 67-9 hub caps
- 71 supreme hood chrome
- WTB: '68 Cutlass Vacuum Reservoir
- 71-72 Driver's side front fender
- WTB 1966 Oldsmobile 98 Hood
- Pass door
- KA water pump pulley
- 455 air gap looking to buy
- Will 1950 Chevy fender Skirts work for the 1950 Oldss
- 1964 F85 convertible
- "Needed - 4 - GM Steel Wheels"...
- 1966 non ac heater cables
- NOS sunvisor mounts
- sport wheel horn cap
- WTB 425 block
