PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88
  1. NIGHTY-EIGHT EMBLEM
  2. DUEL SXHAUST MANIFOLD 455
  3. 73 cutlass supreme parts wanted
  4. '62 F-85 PARTS
  5. 66 88 convertable
  6. 76 cutlass
  7. WANTED door lock / striker / latch parts
  8. 1961 olds trim
  9. 14x6 SSII rims
  10. 15" Super Stock II trim rings:
  11. IN SEARCH OF: 1970-1972 Cutlass Trim Molding
  12. 67 dash pad and more needed!
  13. Wanted: 67 Quadrajet
  14. 1968 442 sports coupe doors
  15. #8 heads
  16. 75-76 455 right side exhaust manifold
  17. WTB power door lock actuator
  18. '69 442/cutlass "S"
  19. '70 Black Bucket Seat Buttons
  20. Header emblem needed
  21. 1984 Delta 88 1/4 pannel window trim
  22. Want to buy console, etc for my 71 Cutlass
  23. WTB ralley pac gauges for a 69 cutlass
  24. 1/4 glass for 68 convertable
  25. 70 cutlass supreme interior
  26. PARTS TO ORDER ???
  27. 2 speed wiper/washer assembly
  28. '68-'72 GM A-Body Frame
  29. stone shield
  30. 61 2dr stainless trim wanted
  31. WTB '65 Cutlass original rims
  32. olds 455
  33. wanted 442 notched valve covers
  34. WTB....68 400 motor or 455
  35. Wanted: 67 jack BASE and HANDLE
  36. Wanted 70 71 72 Cutlass parts
  37. 66 442 Vert All Chrome including top edge of door
  38. need a 455 crank
  39. WTB: Damaged '69 OAI Under Bumper Scoops
  40. WTB-'61 98 Parts
  41. 1966 olds 98 parts
  42. 68-72 Convertible Hydraulic Cylinder
  43. looking for an 83-84 H/O PARTS
  44. Wanted: 1967, 1968, 1969 Auto Console Top Plate
  45. WANTED: 67 antenna assembly
  46. '63-'64 Starfire automatic floor shifter handle
  47. Hydramatic band adjusting tools.
  48. Any 455 E or C heads out there?
  49. 67 Cutlass Supreme 4 doors
  50. Need 455 HP Exhaust Manifolds & Frame Perches
  51. Wanted: 3.23 gears for 49-'52 Olds Rear end (9.25" ring gear)
  52. Inner Passenger side front wheel well
  53. floorpan 1964 jetstar 88 conv.
  54. Wanted AC/Alt Bracket Bolts & AC Duct for 71 Cutlass
  55. in need of a few part
  56. Service Manual
  57. 68 Cutlass/442 dash cone needed asap
  58. I need one 15X7 SSIII wheel that uses bolt on cap
  59. Piston Problems
  60. 1969-1970 88 or 98 front end trim
  61. 70 cutlass supreme parts
  62. parts needed for a 72 cutlass
  63. Wanted:Rear Glass & Moldings,Rt Rocker Molding & More For My `71 Delta...
  64. radiator for 64 conv cutlass
  65. 1977 Delta 88
  66. WTB '65 Cutlass parts
  67. 1949-1950 grille for 88
  68. Wanted: Good License (Rear) bracket 67
  69. WANTED: trunk torsion rods 67 Cutlass
  70. Ashtray for 72 delta royale
  71. WTB: 1970 Cutlass Supreme Hood Spear
  72. 1967 Delta 88 fenders
  73. 3 groove pulley set 303/324/371
  74. 1956 Oldsmobile 2dr Hdtp Roof
  75. 1970 cutlass dash pad
  76. Wanted: 67 Kickdown Switch
  77. 1953-1955 Fiesta Hub Cap
  78. need parts
  79. '54-56 324 motor wanted.
  80. 54 1/2" driveshaft needed 68 Cutlass w/TH400
  81. 1971 442 Carburetor
  82. Need Rubber conector '65 330 Air cleaner
  83. 65 manual transmission parts needed
  84. Blinker lever
  85. 1968 air conditioning parts
  86. rocker arm pivot bolt
  87. need 455 high compression pistons .040
  88. help me
  89. WTB: Early OHV V8 303/324/371 Pulley's Fan and Crank
  90. wanted interior parts for 85 toronado
  91. Original Oil CAP
  92. 72 Cutlass
  93. parts needed
  94. 63 F85 Cutlass and BOP Rover Engine Parts
  95. Need '78 Cutlass Grilles
  96. i need a 1955 olds master cylinder piston..
  97. 71 cutlass disc brake setup wanted
  98. Need '70 Olds 350 Q-jet #7040250
  99. 2 series limited slip or 3.31 ring and pinion
  100. s%*@t!!!........ I need asap
  101. 64 F85
  102. Newb here in need of parts...
  103. WTB: dash bezel/back piece 67 Cutlass
  104. Dash Board
  105. 70 cutlass/ cutlass supreme parts
  106. WTB: 1965 425ci DIPSTICK
  107. NEWBIE looking for 455 heads
  108. wtb: rear sway bar and lcr's for 85 Delta 88
  109. 66 cutlass dash harness
  110. 1970 Cutlass Driver Side Grille
  111. Wanted: 1962/63 Olds Jetfire(My car found)
  112. Wanted!!1970 Olds 98 bumper, fender skirt
  113. 70 Cutlass Passenger side door
  114. 455 Distributor Hold Down
  115. interior parts for 64 f85
  116. 1968 Cutlass hood hinges.
  117. 1976 Cutlass Supreme Brougham Locking Gas Cap
  118. performer 455 intake
  119. Wanted: 1969 Cutlass 442 Hood
  120. PM from a newbie
  121. Quest for #7040250 Q-jet
  122. I need both 71 442 grills and center section
  123. Wanted: HEI Distributor
  124. Looking for 69 Cutlass pass. side view mirror
  125. 1951 Olds 88 power steering
  126. wtb '78 cutlass fender
  127. I am looking for a 66 Cutlass Instrument Panel
  128. stock 4 barrel intake manifold for a 330
  129. 1968 Cutlass grille
  130. 64 t-handle shifter for floor shifter
  131. Front Fenders 1967 Delta 88 4dr
  132. 1968 1969 cutlass 442 Dash FRAME...
  133. door panels
  134. REPAIR MANUAL FOR 1971 OLDSMOBILE CUTLASS SUPREME
  135. 1955 Olds Rochester 4GC Carb
  136. N.C parts place
  137. 62 starfire transmission
  138. 15x7 & 15x8 plain steel wheels 5x4.75 pattern
  139. Centerline Drag Wheels Set of 4 For Sale
  140. Harmonic balancer and fuel pump for 55-56 Olds
  141. 71-72 bucket seat tracks
  142. EXHAUST TRUMPETS
  143. anyone have an OAI air breather base?
  144. Chrome Trim stuff needed.
  145. '70-'72 Cutlass Fender Bottoms
  146. WTB: blue 90-ish Silhouette leather steering wheel
  147. Steering wheel
  148. cassette player
  149. Rear Quarter Lamp
  150. Magazine
  151. WTB 1970 442 4 row radiator bracket/upper shroud bracket/shroud clutch fan
  152. Need 403, 425, or 455
  153. Wanted:Rocker Arms,Lifters,push rods for '72 350
  154. 65 cutlass owner's manual
  155. 1956 Oldsmobile Contential Kit
  156. Need Rear Quarters 1956 "98" Both Sides
  157. Floor Pan
  158. 330 heads N. IL
  159. Parts Needed for 1957 Convertible
  160. Sending Units
  161. Y manifold & chrome trim
  162. Still looking for a fuel tank
  163. 80-85 Delta 88 Opera fillers
  164. '66 Toronado parts needed
  165. WANTED!! 1969 442 FRONT FENDERS
  166. 68-72 Cutlass 8-Track Tape Player
  167. REAR DIFFERENTIAL SB 2.73 POSI
  168. Cruise carb linkage
  169. 1934 water pump, need one...
  170. WTB Oldsmobile 88 aluminum hood & plastic tailgate
  171. NEED BOTH BUMPERS 1967 Cutlass Supreme
  172. 57 Horn Ring
  173. oil fill tube cap
  174. 1956 Olds Fuel Tank
  175. 1964 jetstar 1
  176. Delco alternator wanted
  177. DX block + 425 crank
  178. !984 98 hood ornament
  179. 1968 cutlass parts
  180. '66 F85 trunk moulding
  181. '67 442 front bumper
  182. console emblem
  183. Need '70 Olds 350 Q-jet
  184. 1959 98 parts search
  185. '66 98 Junction block/ horn relay
  186. NEED G-BODY GAS TANK
  187. trunk lid
  188. Fiberglass parade boot 1971-1975 convertible
  189. 75 350 timming pointer
  190. looking for emblem
  191. Cruise control '67 vista cruiser
  192. WTB: 7040258 carb - 1970 442 W30
  193. 69-98 grills
  194. need a bolt
  195. Trim ring(s) needed
  196. Choke?
  197. 1975-1976 olds 98 instrument cluster
  198. NEED '70 OLDS 350 Q-JET
  199. 57 olds super 88 parts wanted
  200. Rear Qtrs 56 Ninety Eight
  201. 1956 Ninety Eight Rear Bumper
  202. 1968 442 DOOR and Cowl
  203. 350 Olds Parts Wanted
  204. 65 442 CARB
  205. 1961 88 Radiator
  206. Power Trunk Release
  207. wtb Lighting rod shifter
  208. 1975-1976 olds toronado parts
  209. 1948 trunk bezel an trunk handle
  210. Factory 2 bbl Carb Needed for 72
  211. WTB: 68 Cutlass Reverse Light Lens
  212. '70-'72 Vista or 4 dr sdn dogleg sections
  213. 69 Cutlass Convertible Qtr panel stainless trim
  214. Timing cover needed
  215. Door Pull Straps
  216. Boxed rear Control arms and Sway Bar
  217. wanted for 66 442
  218. 72 Cutlass 2 dr
  219. 72 Cutlass need Left exterior Door Handle
  220. 394 hedders
  221. 1968-69 442/cutlass dash pad
  222. 53-56 spindles.
  223. DO YOU HAVE
  224. In Dallas TX 72 Cutlass need 455
  225. Looking for Olds 455
  226. 1949 Olds 98 Hardtop- parts wanted
  227. Looking for a couple of these:
  228. Dual Gate Mounting Brackets
  229. wanted - standard bore 10.25:1 pistons for 455
  230. Wanted - 394 Flywheel
  231. 1969 REAR BUMPER W/CUTOUTS
  232. Oil Pan 455
  233. 403 block
  234. Missing Some Bits: 1972 Custom Cruiser
  235. intake manifold
  236. wtb oldsmobile stamped valve covers
  237. 455 near florida/georgia
  238. 1967 Oldsmobile 442 Parts Needed
  239. 1956 Oldsmobile 98 R.Qutrs
  240. 1948 oldsmobile tail light parts
  241. Wanted 66 Toro dash
  242. WANTED 4bbl intake for 72delta 350
  243. Need Head Gaskets!!!
  244. Horn Button For Sport Wheel
  245. WTB:1968 442 Rear Bumper Brackets w/dual exhaust tabs
  246. 1965 cutlass jack assy
  247. 1970 442 headlight bezels
  248. Need '87 Cutlass Cruiser RH Headlight Bezel
  249. 1968-69 442 parts wanted: dash, fenders...
  250. Need 455 Crank
