View Full Version : Parts Wanted
- 1970 442/Cutlass fiberglass bumpers
- 4-speed manual
- Rear end Gears
- WTB 1976 - 77 Cutlass Reverse Lens
- 6 volt alternator
- 442 Sport Steering Wheel
- TCS pressure switch-71 Cutlass
- WTB Dual exhaust crossmember for a 1977 Cutlass
- wanting 72 cutlass supreme Rocker moulding
- WANTED--Auto Calculator
- Working 1963-1964 full-size AM radio
- 63 Dynamic 88 bumper
- remote side mirror escutcheon for 71 cutlass
- 1967 442 front and rear bumper
- wtb misc trim and etc
- Need Rings and caps for 15" SSII's
- WTB 70-72 Cutlass S Trunk lid
- 65 442 400 mounting brackets/hardware
- Looking for driver side door jam windlace
- 70 - 72 Front Cutlass fender
- Electric thermal vacuum switch
- Looking for an olds 400e block or engine
- Wanted 61-62 F85 / Skylark Rear Axle Assembly
- 350 Blower Manifold Wanted!
- Door Glass
- 67 fender moulding
- Need 70 Cutlass/442 front end parts
- WANTED 68 Cutlass S 2 door coupe left fender
- ceramic coated headers
- Auto floor shifter 70 Cutlass
- 1970 cutlass rad. Support
- 1970 442 cruise control
- 70 to 72 cutlass 455 aircleaner heat pipe
- 57 Air Cleaner
- 1941 66 Parts Needed in U.K
- 1970 Cutlass Supreme convertible: Need passenger door and trunk lid hinges
- 70-72 Cutlass S drivers quarter panel
- 1972 Cutlass post coupe window rollers
- Desperately Seeking: 1949 98 Door Latch
- 31 spline axle
- 1968 442 headrest
- 1969delta88coupe or convert trim,needed
- 64 Interior
- 4 spd. drive shaft
- 1949,1950 bumpers
- RT front fender chrome still needed
- WANTED 68 Cutlass drivers side front fender
- Inspection plate covers needed
- Looking for Cutlass Horn Relay
- looking for a 68 decklid 2 door coop
- Wanted: 1967 Cutlass 4 door hard top no post b pillar covers
- Looking for a front passenger side marker light - 1972 Cutlass
- Delta 88 taillight wiring harness
- Looking for good core or better 7041257, 7041253 or 7041256
- Still looking for 66 Delta 88 chrome trim!
- Looking for a 4 speed transmission
- 64-65 REMOTE MIRROR Cutlass
- 1970 toro/98 brown steering wheel
- Throttle Linkage (for MANUAL) 67 (wanted)
- 67 cutlass posi wanted
- Rust free 67 442 fenders
- 70 Olds 442 Decklid
- 1970 72 cutlass heat riser tube 455
- Pulley needed
- 1968 w30 carb #7028254 wanted
- Wtd- 56 Olds WIPER MOTOR vacuum type
- Toronado trans
- LTB breather, olds trunk letters, etc
- '67 Cutlass 330 Flex Plate/Flywheel
- 56 Heater Blower Motor
- timing cover
- 1971 SS1 wheel
- 1961 Oldsmobile S88 Front Drivers Directional Sginal Unit
- Core support
- Looking for 1985 Delta 88 Drivers side tail light !
- 1971 Instrument Control Panel
- Looking for a pair of Morroso valve covers for my olds 455
- 1970 cutlass lower dash
- Fan
- Heat riser spacer 394
- 1967 vista cruiser passenger side tail light bezel
- Convertible back seat
- 1972 Cutlass headlight knob needed
- Wanted 1955 Chrome Tail light bezel
- Found a needle in a haystack once, now for something really obscure
- 1972 Cutlass S hood grills
- need bucket seats for 67 cutlass
- need back-up light housings for 64-F85,65 wagon and....
- Brake Rotors wtd pre-71 Big Car
- 67 cutlass door trim.
- set of heads wanted, other than J's
- Steering Column
- need 1970 Cutlass Parts
- 65 water pump pulley
- 1968 Olds Cutlass Valve Cover To Air Cleaner Vent Tube
- w31 w350 intake manifold
- Fuel Pump Eccentric
- 1970 442 Drivers fender
- 1980-1983 Delta Taillight
- Chassis mount for 455
- 1962 Olds Dynamic Glove Box Strike
- 1970 headlight ring
- Trunk latch hook and lock needed - 1953
- Wanted - 324 371 Running engine
- Need any Delta 88 parts? 80-85
- 71-72 Cutlass 'S'/442 black door panels
- 70-72 Dual Gate Shifter & Console
- 70-71 Cutlass Interior Black
- Wanted>70-72 supreme right quarter
- 71 Delta 88 emblem
- 1970 original internal reg. Alt.
- 70-72 rally pac
- oil filter housing
- 72 442 power seat cables
- 70-72 Cutlass/442 Hi note horn
- '70 Olds Dual Gate Shifter Parts
- 72 tilt column
- 28 spline posi unit
- WTB Rocker Panel Extension 46-48 Olds
- Wanted 64-65 F-85 left hand mirror bracket
- 70-72 Cutlass console
- 1950 Oldsmobile clamp
- Th400& Parts for floor shift/console switch
- 1971 Cutlass Convertible AC Compressor brackets and other Parts needed
- 1972 Cutlass Door Trim Chrome Wanted
- I need a set of SS II wheels dated Sept or Oct 1969
- 1970 Cutlass Roof Rail Weatherstrip Molding Connector
- 1970 Trunk Lip Molding
- 1972 hood
- Serpentine belt setup for 455
- Steering gear/worm Oldsmobile 1942
- 403 Olds stock piston
- air dam 1970-71 cutlass/ 442
- 65-69 4spd tunnel hump
- 65 4spd console
- Blockoffs for 1966 L69 tricarb intake
- 1968 olds conv. Trim
- Plastic push rivets for 70-72 console
- steering column parts
- 1968 442 400ci Valve Cover Vent Tube
- autronic eye
- Console 4 speed 67 (wanted)
- 1980-1983 Delta parts wanted
- radio 1970 am/fm
- Pulleys brackets ps-alt for an ac car. 1966 330
- Looking for Stock Clutch Fork, Rod, Return Spring Assembly
- 55 Olds Radiator
- edelbrock 2151 needed
- looking for rims for toronado rims
- Olds 455 69-71 in the midwest
- 54 Super 88 bumpers wanted
- 1965 F85 Cutlass jack wanted
- 65 auto console
- 85 Delta 88 - fp turn signal cover
- 65 Buick hood ornament
- fuel sending unit 1964 jetstar 88
- Trunk Light?
- 1970 radio
- 1964 F85 post trim
- WTB: 71-72 442 Grille for Parts
- 67 Flywheel, Bellhousing, linkage, pieces
- Mini wire clip
- Looking for 4 spoke cutlass steering wheel
- 1972 Olds Cutlass S grills
- Need need need driveshaft
- 65 cutlass dog dish hubcaps
- KB and KE pulleys needed
- 1966 Olds Dynamic rear bumper
- 455 crank
- Alternator bracket set-up
- Looking for Antenna Mast & Nut for 66 442
- Looking for the 1969 supreme trim
- 1957 Oldsmobile 1956 Ford Fan Shroud
- 1964 Jetstar 88 Rear Bumper
- Mounting Bracket for Cutlass 70-72 Vent Delete Plate
- Black Dash Pad 70-72 Cutlass?
- Parts for 69 Olds
- I need a trunk lid for Convertible 1968 Cutlass
- 1967 Toronado Rear Windshield Exterior Trim
- power seats
- 72 supreme rear passenger side wheel well molding, no dents
- '64 Jetstar 88 Emblem
- Gas Tank for '69-'70 Vista Cruiser
- A Body Accelerator Pedal Linkage
- N o s front fenders 70 442
- exhaust pipe 394
- 1966 Delta 88 FENDER CHROME TRIM
- 1970 olds cutlass rear speaker
- 442 door panel rocket
- '69 Cutlass S convertible parts
- Blue 1972 Deluxe Steering Wheel
- real '69 H/O needs HOT AIR TUBE
- '68/'69 Cutlass/442 floor shift speedometer
- 62 starfire upper radiator hose
- 1958 olds 88 fender
- flywheel for '68 and newer 455
- 72 Hood Hinge Spring
- '72 Front Drum Brake Wheel Hubs
- 70 - 72 power trunk
- Need headlight housing f85-63
- Seats for '66 98 Convertible
- 1957 Super 88 Four Door - Exterior Trim & Backup Light
- Speaker grills
- 1962 Dynamic/Starfire Turn Signal Cancel Cam
- 1969 Cutlass bumper jack
- 68 cutlass grille
- BB Dipstick Tube
- wheel cover Delta88 1970
- 1970-72 rear defroster switch, cutlass
- 65 Cutlass 442
- 1979 hurst olds
- 68 Cutlass Radio - Complete, good shape, non-working is OK
- wanted
- 57 Olds A/C Mounting Brackets & Shroud
- Pui or legendary
- A few parts i am Looking for
- 70 442 rear bumper
- 66400
- Pebble guards 1950 Olds
- 1972 cutlass black steel wheels 14x6
- Seat Belt 5901 Black
- parts
- Headers
- wanted - sbo edelbrock intake
- 71 Delta Wheelhouse Trim and Seat Tracks and Release Knobs Needed
- need this part please
- delmont pieces...
- speaker grills
- Hood Insulation Retainer
- Dennis Casteele books
- Another member with a radiator need
- 69 Cutlass 350 exaust manifold
- Used Carpet 70-72 Vista
- pearl white interior 70 442
- U69 Jack Base
- Rear Glass 72 "S"
- 1969 Cutlass rally wheel
- 71' Cutlass Headlight housing LH side
- 1966 Delta 88...FENDER CHROME TRIM
- 1962 Starfire 394 cu engine
- 1970 442 4 core radiator
- wanted: 69 cutlass rear sway bar
- 1969 tach
- 1970 Cutlass Convertable Frame
- 71-72' Front Orange side marker lens
- '70-72 Console glovebox light switch
- LTB 455 in Texas
- '70-72 Cutlass/442 8 track front surround/pad
- 70 olds o-axle gears
- paint divider chrome
