fuel sending unit 1964 jetstar 88
I would search around on here as this has been discussed several times.
No one makes these new specifically for full-size '64 Oldsmobiles. But it's possible that a unit made for a similar Chevy, which probably IS made new, would work. You would have to do a little research and compare what you have to what is offered for a Chevy. If it looks similar and has the same size mounting requirement, it would probably work as these are all nothing but floats attached to 90-ohm variable resistors.
I needed a sending unit for my '67 Delta 88, which is also not made new, but I found that the unit for a '72 Olds Delta 88 or Buick LeSabre, which take the same part and which is available new, is a drop-in replacement.
68RocketAction
Dec 18, 2014 11:19 AM
Oldskool84
Oct 10, 2014 06:21 AM
