4-speed manual
Old Mar 25, 2013 | 10:51 AM
FinOldsMan's Avatar
4-speed manual
Does enyone hawe one whit bolt on pack?
Old Mar 25, 2013 | 11:34 AM
oldsmobiledave's Avatar
explain
I would like to help but I have no idea what this post means.
Old Mar 25, 2013 | 09:16 PM
stan 65 cutlass's Avatar
ya, me too dave, i just wasted 5 mins of my life ill never get back tryin to figure it out too.
hey dave. any luck on a nice pair of exhaust manifolds yet?
Old Mar 26, 2013 | 08:39 AM
FinOldsMan's Avatar
Hi.. Sorry abaut my bad english. My meaning is to find 4-speed manual transmission for 66 f86 whit 455cid, and all stuff needed to work.
Old Mar 26, 2013 | 09:06 AM
manifolds
My bad buddy....I messed up & totally forgot.
Check your PMs. I got you covered.
Old Mar 26, 2013 | 11:49 AM
Rickman48's Avatar
Was the car originally a stick, or do you need all the clutch linkage, etc.?
Console car?
Which automatic, if so? [makes a difference]
If converting from auto on the column, do you need a steering column? Color?
Need all answers to do it right.
Old Mar 26, 2013 | 01:46 PM
taa442's Avatar
4 speed
Hi, My name is Tim.If you are wanting the complete 4 speed set up,I have what you need.I have a Muncie 4 speed tranny,bellhousing,flywheel,shifter,linkages,etc.T his set up came out of a 1971 Cutlass smallblock car.You probably do not need the console or column I have though seeing that yours is a 66.The mileage on the car was 66,000 miles when I pulled it from the car.I am asking $ 2,500 for everything, but again since you may only need the tranny ,bellhousing ,shifter ,etc.,I would take less.Thanks,Tim e-mail at TAA 442 @aol.com
Old Mar 26, 2013 | 02:35 PM
Fyi
Just an FYI the pedal assemly & related parts for a 66 Olds A body are differnet than those used in 71.
Old Mar 26, 2013 | 10:03 PM
taa442's Avatar
Oldsmobiledave,you are correct, but as I stated he would only need or use the tranny, flywheel,bellhousing as I said at a reduced cost that I offered for everything .I may also be able to get the rest of the parts he would need specifically for the 66.Just offering.Thanks,Tim
Old Mar 27, 2013 | 05:35 AM
ROCKETMAN269V's Avatar
Question stick conversion
You also need to see if the crankshaft in the engine that you are using is machined for a pilot bearing/bushing. If not, there is a "band-aid" type adaptor, but you may need to shorten the input on your transmission so that it doesn't bottom out in the rear of the crankshaft.
Old Mar 27, 2013 | 10:27 AM
FinOldsMan's Avatar
F85 is originally 330cid TH350.. i just read of manual transmission swap and i think, i donīt do it.. Itīs just too hart to do and taa442 your tarnsmission is too expensive.. Thanks for ansvers..
Old Mar 27, 2013 | 11:21 AM
Smile
Don't be easily discouraged. We're just trying to point out things to check before you jump into a project. The original engine isn't really important; the one that you are using NOW is the one that you need to check. Also, there may be other parts out there that are more in line with your budget. Be patient.
Boldsmobile
Dec 13, 2015 07:16 PM
Del70
Jul 6, 2011 03:46 AM
Boldsmobile
Jan 22, 2011 01:26 PM
Wyze
Brakes/Hydraulic Systems
Jan 9, 2011 12:19 PM
OldsMotion
Jan 6, 2010 03:14 AM
