PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 0.8241 Speedo Gear Reducer/Adapter
  2. 1965 cutlass tilt steering column
  3. 3 dynamic 4 door parts needed
  4. 1970 Steering box
  5. WTB "W" exhaust manifold
  6. 1968 442/Cutlass B90 Post Trim
  7. Batten Intake
  8. WTB: 2" BBO Headers
  9. Dash plastic
  10. Still needed: Pass Side Lower Alt Mount
  11. 70-72 Cutlass floor shift gate
  12. 66 manual trans throttle linkage assembly neededasap
  13. SSII 15" wheel
  14. 68 air condition ducts - parts wanted
  15. Omega Hatch
  16. 72 442 Grilles
  17. 64-66 Cutlass/442 console tach mount
  18. W: 1977 Omega coolant reservoir/overflow tank
  19. 66 442 parts list needed
  20. 68-69 cutlass s trunk lid
  21. 455 Pistons
  22. 1972 Parts wanted
  23. 76 cutlass rear bumper
  24. 455 engine willing to ship to hawaii
  25. 1984 olds custom cruiser
  26. Rear Bumper for 1964 Olds Ninety-Eight 98
  27. 1959 Olds 88 sdn fuel tank
  28. Trunk Lettering for 65 98 Convertible
  29. Wanted, 1972 Cutlass Shoulder Belt Set in Black
  30. OEM #392053 Tailpipe for 66-67 442
  31. right door glass 70 thru 72 ,tinted w/ac
  32. 1972 Cutlass Rear Quarter Panel End Cap
  33. ISO 1981-1985 98 parts central Pennsylvania
  34. 1972 Cutlass lower dash panel
  35. Vendors
  36. '64 Olds 98 ignition switch
  37. 455 Engine Stuff
  38. glove box light switch
  39. 14" wire wheel hubcap
  40. 78 Toronado Rear Bumper
  41. Passenger Side Lower Alternator Bracket
  42. Wanted: 1970 radiator core support top plate
  43. W-27 rearend Cover, OEM 1970
  44. 1957 1958 small parts wanted
  45. 1965 Dynamic 88 Tilt Column Neutral Safety Switch
  46. Intake manifold
  47. 70 S or 442 door panels.
  48. 1955 Dash Cluster
  49. Wanted: 67 Interior parts and 72 engine parts
  50. WANTED: 68 Cutlass tail light lense screws and housing capture nuts
  51. 1969 Hood and Fenders
  52. Type "O" 3.08 or 3.23 gears Wanted
  53. 70-72 Cutlass console
  54. WANTED!!! 1977 delta 88 coupe exterior parts
  55. I-75 Parts Cars
  56. 455 block
  57. Looking for a 455 offenhauser intake manifold
  58. 70-72 4 Speed Console
  59. 455
  60. wiper motor
  61. 1965 442 4 speed console
  62. 55-57 std trans or parts
  63. 1100767 Alternator
  64. 64 Station Wagon Taillights
  65. 1964 Jetstar/Dynamic 88
  66. 455 '70 style driver side alternator bracket
  67. 1973 Cutlass Supreme interior parts
  68. Aluminum valve covers 455
  69. 1967 Olds Cutlass
  70. 1967 Delmont 88 Fuel Tank
  71. '65 Cutlass, Left Rear Fender Cap
  72. A pillar cover for vinyl roof
  73. 70 trunk lid light
  74. 62 F-85 fender trim
  75. What's it called ? Where can I get a couple?
  76. 1962 cutlass turn signal switch
  77. parts for 63 cutlass
  78. wtd- maybe- used tires 85 Cutlass 442
  79. Looking for more Screws
  80. Need alternator bracket for 72 350 non a/c
  81. need arm rest bases
  82. 1967 442 bumpers
  83. Quadrajet Wanted
  84. Wtb>66/67 fan shroud asap
  85. 55 88 chrome vent window frames
  86. hurst cable needed
  87. MI woman seeks '64 Cutlass AT Console SHIFTER KNOB
  88. 1980 olds rally pack
  89. Dash heater delete plate for a 68/ 69 cutlass/442
  90. WANTED: 68 Cutlass S Convt. LH AC vent duct
  91. Cowl Wiper Panel Screws for 66 Cutlass/442
  92. Olds Type "O" 12 Bolt Gears
  93. 72 Cutlass Supreme Body Side Molding
  94. 1969 cutlass parts wanted
  95. 72 cutlass bench seat plastic armrest cover
  96. 70 S Trunk Lid
  97. 342 Gears
  98. 1970 455 Intake Manifold
  99. 1969 Cutlass Rear Seat (Wide Version)
  100. WTB 65 330 RH Exhaust Manifold
  101. 64 442 Hood Lip Molding
  102. 1966-1967 Lower Radiator Seal #392049 cutlass 442 F85
  103. wanted 1970 455 valve covers
  104. '64 Dynamic 88 rear moulding (drivers side)
  105. Steering Wheel Center Piece?
  106. 1964 Olds 88/98 fan shroud
  107. WANTED>Muncie Speedo Cable Adapter
  108. 72 Cutlass Supreme Deluxe Steering Wheel
  109. 69 Cutlass ash tray
  110. Power steering pump brackets
  111. Bumpers
  112. 1966-1967 front license bracket & harness supports
  113. Patch panel 71-76 delta 88
  114. 1969 f85 fender emblem
  115. 330 Flywheel
  116. Trunk lock wanted 1966 Starfire
  117. 1968 Cutlass Supreme Trunk Emblem and Package Tray
  118. 68 Cutlass S Conv - NEED Rear Power Windows
  119. WTB 1971 Cutlass S Grille
  120. 1977 - 81 3A heads
  121. WTB: 1969 Cutlass "S" Front Grills
  122. WTB Oldsmobile 1958 parts
  123. Looking for '69 reverse light housings
  124. chrome air cleaner lid
  125. 66 Olds Delta 88 bumper jack
  126. Need '68-'72 Post B pillar interior molding, pass. side
  127. 70 442 Carburetor Needed
  128. Steering wheel 1969 Toronado
  129. 1956 324 starter
  130. Need a Crank Pulley
  131. 70/72 442 pass door and trunklid
  132. 70-72 Lap vent
  133. Wanted 1960 Dynamic 88 Headlight Trim Ring
  134. WTB Belts
  135. 200-r4/307 Trans Flywheel Shield WTB
  136. 1964 full-size non-a/c heater box
  137. Keeper wire for lifter
  138. 66 F85 Wagon window regulator
  139. 66/67 Dashpot
  140. 1968 Rear Standard Seat Belts In Black
  141. WTB-60's era dog dish cap set
  142. 15 X 7 rally SS wheels
  143. 72 Olds 98
  144. Upper Control Arm - 63 F85
  145. 1970 Cutlass Supreme Coupe
  146. 1972 Cutlass Rear side chrome needed
  147. Wtb 400/425 .921 hydraulic lifters
  148. piston needed, 66 330
  149. 1970 cutlass Steering column lever
  150. 1969 Non-AC Dashpad
  151. 1972 Cutlass S Hood - No OAI but one with Louvers
  152. Seat belts and retractor covers
  153. Convertible Boot
  154. 69 Cutlass TH350 detent cable
  155. 1967 Glove Box
  156. Tilt steering colum
  157. Rallye 350 decal/stripe set
  158. Upper Mast Jacket Bearing and horn contact
  159. 73 olds delta 88 rear window guide
  160. 1967 bumper
  161. '71 cutlass cigarette lighter housing
  162. 70 Cutlass Doors Wanted
  163. Dick Miller G Body Headers
  164. Looking For 5 Restored SSI or SSII
  165. Finger Grip -T grip
  166. Vacuum booster with Master cylinder -98 1970
  167. Passenger side door needed 72 Cutlass S
  168. 68 Cutlass S Conv - Rear Power Windows
  169. WTB: original blue and tan floor mats
  170. Wanted ssi ssii restored
  171. Need 1970 tail lights and license plate light.
  172. Wanted: 64 Cutlass driver's side rear quarter panel
  173. 71 442 possi rear axel
  174. ignition switch arm kit.
  175. 56 front hub/drum
  176. Looking for rear seats for 69 Cutlass Convertible
  177. 69 Cutlass A/C duct needed
  178. 1971 Cutlass Convertible floor section
  179. Wanted ground strap for Rallye 350!!!!
  180. seeking real "H" heads
  181. blower to junction block wiring for 1971 cutlass
  182. 1970 -72 Cutlass S/ 442 quarter panels
  183. 70-72 cutlass supreme tail panel
  184. 73-74 GM A body trans crossmember dual exhaust
  185. 1968 or 1969 Toronado Font License Plate Bracket
  186. Type O gears
  187. 84 olds custom cruiser
  188. 1970 442 radio delete plate wanted
  189. aluminum big block olds heads wanted
  190. offy super sonic big block manifold wanted
  191. 1956 Olds Super 88 windlace tack strip
  192. 65 Delta 88 Column Shift Lever
  193. 1980 grille
  194. 52 left front frender
  195. Looking for a fuel tank sending unit for a1966 delta 88
  196. Tires
  197. 63 engine transmission
  198. need lenses in-bumper 1964-65
  199. 87 Cadillac boroughs rear bumper
  200. 70-72 Rear bumper Reverse Light housing with wiring
  201. 1948 Oldsmobile 98 Fender Skirts
  202. 65 cutlass part
  203. looking for 68 cutlass convertible seats
  204. Harrison 4 core radiator for 70 442
  205. Rochchester 7042251 stop solenoid bracket
  206. W-31 Cam
  207. front fender headlight trim
  208. 66 Drivers side dual exhaust manifold for a Dynamic 88
  209. Heads or engine
  210. 1970 442 manual steering box wanted
  211. WTB a 3.91 TO coded rear end
  212. Holley Street Dominator 350
  213. 65 olds 98
  214. Need front left fender, left headlight assembly and bumper filler for a 1967 Cutlass
  215. 69-72 Heavy Duty Trunk Tensioner Springs
  216. No #5 Heads
  217. justin
  218. Rallye Pak Sending Units
  219. 9" dog dish hubcaps for 1961 1962 1963
  220. 394 AC crank pulley
  221. Positive for Olds442RedBeret
  222. 70-72 Cutlass Clock
  223. 1967 w-30 Air Cleaner
  224. 68 Manual brake push rod
  225. 76 cutlass supreme brougham
  226. Remote Mirror
  227. 71 Saddle brown vista interior parts
  228. looking for 71 convertible quater trim
  229. Sbo heads needed asap Washington state
  230. 1/4 extension
  231. '69 Convertible Seat Belts
  232. 70 cutlass rear sway bar
  233. steel package tray
  234. 69 parts & dash pad - black - wanted mint condition
  235. 57 trim
  236. '57 Rt Quarter panel
  237. Interior Belt Molding
  238. Wanted 1956 Rocket 88 - Chrome/SS Windshield Join Clip
  239. A-pillars/hinge pillars off a 1967-68 Olds 88 or 98
  240. Need Parts for 1967 Toronado....
  241. Seat belts
  242. 70-72 Cutlass console door w/hinge
  243. Interior molding for 1975 Cutlas Supreme
  244. notchback steel package tray
  245. 68 Cutlass S Conv Vent Windows/Glass
  246. 1962 cutlass f85 rims and door handles
  247. 57 Olds S88 Convert parts Needed
  248. 69 Delta 88 Intake Manifold
  249. Holly Carb Wanted
  250. 69 Cutlass Convertible trunk hinges and original steering wheel
