PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1964 Cutlass, F85 Dog Dish / Poverty Caps
  2. 1967 cutlass convertible window sill moldings
  3. Looking for Cutlass 442 Tilt Steering Column Part
  4. Rochester 7041251 7041257
  5. 455 edelbrock performer intake
  6. Trim ring seat belt retractor
  7. Power steering bracket 64-67
  8. 1968 Steering Column Upper Bearing Assembly
  9. turning light assemblies for 70 Toro
  10. 7040253 Carburetor
  11. 71 Cruise Control Parts Needed
  12. 1979 Oldsmobile Cutlass Exhaust Manifolds
  13. 55 Oldsmobile 324 rocket Manual Transmission
  14. 1969 Cutlass S/442 hood
  15. 66 cutlass hood and grill
  16. 1953 instrument cluster
  17. Parts need for my 98 olds
  18. Oldsmobile Toronado 78- 85 oil pan
  19. Rear lenses
  20. 1969 Hurst Olds
  21. 1964 Olds Cutlass
  22. 68 Cutlass Supreme body/interior parts
  23. Looking for 71 TM code rear end
  24. transmission slip yoke
  25. ISO 15” wheel complete
  26. 70 442 rally gauges
  27. 1970 rally gauges
  28. KG water pump pulley
  29. 1970 w31 manifold
  30. nos 1972 442 rear bumper
  31. wanted nos 1972 442 grills
  32. 1966 Cutlass parts needed
  33. 1975 Delta 88 driver side door
  34. Intakes
  35. 1963 dynamic 88 parts car
  36. 1975 Cutlass Frt License Bracket
  37. 1975 Cutlass bumpers
  38. Front seat belt
  39. ISO GMPP Oldsmobile gauges
  40. Upper Steering column bowl
  41. 1974 Cutlass Supreme Body side molding
  42. 1967 Cutlass Hood Spear
  43. 1965 Club Coupe hood
  44. 1964 Starfire Convertible RR Wheel Well Molding
  45. 1978 Olds Toronado
  46. Looking for 1/8 npt intake manifold fitting
  47. seat track
  48. 72 Cutlass Dash Housing
  49. 1971 442 4speed carburetor 7041253
  50. Intake manifold for 1970 Cutlass
  51. 1969 442 4 Speed Steering Column backdrive linkage
  52. WTB 1969 blue shoulder belts (esp. female ends)
  53. 67 400 dipstick/tube
  54. 71 442 Grille Wanted
  55. Parts for 1965 F85
  56. Wanted 56 98, starfire, (& some others) DS kick panel trim
  57. Column Shift Arm for '70 Cutlass Tilt Column
  58. 15" x 8" steel wheels
  59. Who sells these?
  60. Ralph oldsmobile
  61. 1970 98 front bench seat
  62. Wanted - Antenna lead-in and cable for a 1957 Oldsmobile.
  63. 1969 code T.O. Rear End < chassis and body manuals.
  64. ISO 1965 dash clock
  65. 1972 Olds 98 LH Parking Light Lens
  66. 1969 Cutlass heater box in bad shape
  67. Wanted - '70 442 Rear Drivers Side Quarter Panel
  68. Wanted,,omega lights
  69. 87 cutlass trunk lid
  70. 455 Nodular Crank Needed
  71. Wanted: 1970 Night Watch Amplifier
  72. KA Pulley
  73. Wanted 66 B Body Wiper/Washer Switch
  74. 68-72 Rear Spoiler Pedestals Needed
  75. Edelbrock OL4B or Olds 350 aluminum intake #406114
  76. 66 Full Size or Toro Tilt Wheel Part Needed
  77. 67 442
  78. 1984 Alternator Part No.: 1105565
  79. WANTED: 1971 Delta 88 Royale trunk lock assembly
  80. Wanted:1975 Oldsmobile Custom Cruiser Wagon Back Up Light
  81. Wanted 1956 324 engine
  82. 68 442 Dash
  83. 67 442
  84. Rochester Quadrajet Throttle Shafts
  85. 1966/1967 Reclining Passenger Seat
  86. WTB 1970 black drivers arm rest pad original
  87. Throttle cable 1970 cutlass
  88. 1970 T.O. code rear-end for trade
  89. 1984 Cutlass Temperature Gauge wanted - NOS
  90. WTB dark red bucket headrests
  91. 1971 cutlass parts
  92. rear axles
  93. 65 reverse delete plates
  94. 1972 Cutlass Supreme Pair Reverse Light Assemblies
  95. NOS BB motor mounts
  96. Wanted: 1971 Oldsmobile Cutlass Fuel Gauge
  97. 66 Cutlass 3 groove pulleys
  98. Comp cam part# CL 42-423-11 Wanted
  99. SP400 needed
  100. 68 Cutlass/F85 442 dash map light
  101. 1971 - 1976 fullsize 12 bolt oldsmobile open 2 series carrier needed 2.56 2.78
  102. antenna for 69 cutlass 442
  103. 71 442 nos
  104. Tic Tac Toc for '67
  105. 1970 442 rally gauges
  106. 1970 442 rally gauges wanted
  107. 71 Rear Door Panels
  108. Fuel sender 64 Starfire
  109. 1964-67 manuel console rear courtesy light assembly
  110. 1969 442 Thermostat Housing
  111. 70-72 cutlass convertible body shell
  112. Looking for a 70-72 console with broken glovebox
  113. 14"X7" assembly line style clamps trim rings wanted
  114. Need 66 98 Fender & Trunk Badges
  115. 1971 Cutlass S. Bench seat tracks
  116. 70-72 Console Parts Needed
  117. Parts wanted
  118. 1955 olds 98
  119. ISO 350 or 455 engine Illinois
  120. Wanted 65 442 side scoops
  121. '70 442 Grilles (would consider damaged ones)
  122. WTB '64 Jetstar 88 Parts
  123. 85 euro front end
  124. 63 Olds 98 LH taillight lens
  125. 12 bolt Olds rear gears..3:42 or numerically higher.
  126. 425 or 455 near PA
  127. "KM" water pump pulley
  128. 1973 Oldsmobile Omega hood torsion bars
  129. 1977-1984 NOS delta 88 center caps
  130. 69 hurst wheel 15x7
  131. Fuzzies needed
  132. 1968 442 cigarette lighter
  133. TH350 Vacuum Line Needed
  134. 1969 Cutlass Courtesy Lamp Harness
  135. 1965 cutlass column shift assembly
  136. WTB 1969 Cutlass radiator core support
  137. Wanted for 71 442
  138. 1970 Vista Cruiser Tank Sender Unit
  139. Need this 60/40 bench seat for 1986 Cutlass Supreme
  140. 1949 Olds 88 hood release cable
  141. 1949 Olds 88 jack
  142. 1969 442 Door Jamb Windlace
  143. Air deflector/splash shield
  144. 69 hurst wheel 15x7
  145. WTB NOS or Damn Nice Headlight Switch Assembly 70-72 Ctlss. Also want hi beam switch
  146. 1967 Olds 400
  147. WTB NOS or Damn Nice LH Dash Vent for AC car, 70-72 Cutlass etc
  148. convertible decklid
  149. 1970 w31 manifold
  150. wanted nos 1972 442 grills
  151. 1969 442/Cutlass Headlight Housings Passenger
  152. 66 Cutlass Front Bumper Rubber Fillers
  153. WTB - 1970 442 PW Steering belt & spiral shocks
  154. Wanted: 1990 Olds Custom Cruiser Front End Parts
  155. 1967 quadrajet 30 cui idle stop solenoid wanted
  156. 1972 convertible cutlass ducting
  157. WTB ​​​​​​​Bolt in frame to mount front bumper 72 Cutlass?
  158. Head-light switch
  159. WTB: Grease/dust cap 392035
  160. flywheel 1966 tornado
  161. looking for any kind of L69 OAI shroud
  162. WTB 1967 Cutlass Supreme Left Rear mldg
  163. WTB (Maybe) - '68 Type O 28 Spline Axle Shaft (?)
  164. 72 350 Exhaust manifolds
  165. 66/67 parts please read
  166. rear bumper
  167. Looking for a crankshaft 1952 303
  168. Battery top vent cover 66-67 442 for trunk..
  169. 70 - '72 Convertible A Pillar Weatherstrip Channel
  170. Window Sweeps
  171. 1964 Super 88 Rear Bumper
  172. Cruise Control dash switch 70-72
  173. 1958 Eighty Eight Emblem
  174. Rally guage parts
  175. 1969 88/98 Front Bumper Fillers
  176. 1966 Vista Cruiser Molding
  177. 1970 W30 Auto Carb
  178. Wanted: 1980-1985 Delta 88/CC Header Panel Parts
  179. Passenger Side Kick Panel for 1968 Cutlass
  180. 455 single plane intake
  181. NOS temp gauge
  182. WTB 1971 Cutlass Supreme Convt Quarter interior side panels
  183. Bumper hook
  184. WTB blower speed switch
  185. 1972 NOS Supreme drivers Grille
  186. Wanted: 84 Cutlass Rear Quarter clips
  187. Removeable floor sheet metal for master cylinder access non power brake 1955 olds
  188. WTB: Red W30 Fender Well - Drivers Side 1970-72
  189. 1962 f85 215 v8 oil dip stick
  190. 1111466 distributor
  191. 1967 442 RH bottom fender mounting bracket
  192. Olds tachometer needed
  193. Flywheel cover Toronado 66.
  194. Wanted 1968 Delta 88 Steering Wheel
  195. Wanted: 84 Charcoal Canister mounting clips
  196. WTB Power Window Motors
  197. Rear quarter window channel 70 Post coupe
  198. 1969 442 door panel emblem
  199. Want 1967 Dashpot and Bracket for AC 400ci. engine
  200. 1968 442 tail light sockets.
  201. 1969 442 A/C Fan cooling line
  202. 69 hurst wheel 15x7
  203. WTB 67 400 ci balancer
  204. WTB 57' Taillight housing
  205. WTB passenger side mirror for a 1967 cutlass
  206. recovery tank
  207. Standard Front Sway Bar for 66 442
  208. Chrome Clip Needed
  209. Wanted 1970 W30 manual trans radiator
  210. Need Valve Covers for 5.0 307 1984 riviera
  211. Quadrajet rebuild kit for 1979 California Hurst Olds
  212. Good 1967 cutlass radiator auto trans
  213. 69 442 - Front RH floor panel & 2.5" trumpet exhaust tips
  214. 1957 Super 88, Intake manifold 371 engine, 4BBL
  215. 330 pushrods
  216. Need wheels for a 48 Olds
  217. Hydraulic Roller Lifters
  218. 1972 cutlass supreme white door panels front and rear w arm rests
  219. 1966 vista cruiser glass
  220. Cutlass 8 track vents
  221. WTB. SS1 Wheels - 14x7 LZ with painted rims 1970
  222. 1960 oldsmobile rear quarter panels
  223. wanted 7029253 carb
  224. all oem 1111932 distributor wanted
  225. Tires
  226. WTB T44 Hood Release Option
  227. Wanted - Various Parts for 1990 Oldsmobile Custom Cruiser
  228. Looking for a 79 hurst olds black header emblem
  229. Wanted: 1965 Dynamic 88 - Bumpers
  230. stock height cast covers for 455
  231. 1968 Cutlass S Hood
  232. 1965 A-Body Hood Spear Wanted
  233. Monroe 71801
  234. Wanted: NOS 84 Cutlass PW Passenger Woodgrain
  235. Bbo aluminum heads
  236. Wanted: 71-72 10 bolt posi
  237. WTB: Edelbrock Dual Carb Intake Manifold
  238. Wanted - LA area. 14" steel 5 x 4.75 rim
  239. Broken T-44 hook lock cable end
  240. Iso 65 cutlass passenger rear quarter
  241. 455 rpm air gap
  242. 1971 442 passenger side grille/surround wanted
  243. WTB 88-98 passenger side outside mirror
  244. 1970 "EB" OEM Manual Disc Brake master cylinder
  245. 69 olds 442 bucket seats
  246. NEED TO KNOW BY 5 PM SUNDAY!! Need 1972 oldsmobile cutlass driver sport mirror
  247. '61 - '64 Roto Hydramatic Transmission
  248. vent window
  249. Anyone have a steel dash frame?
  250. Hood hinge adjustment bolts
