1962 f85 215 v8 oil dip stick
Old Sep 19, 2021 | 07:37 AM
big.rebar@hotmail.com's Avatar
Big rebar
Looking for an original engine oil dip stick for a 1962 Oldsmobile cutlass f-85. 215 ci aluminum V8.
Old Sep 20, 2021 | 02:58 PM
olmanwinter's Avatar
I have a NOS one on hand, as long as your F-85 doesn't have air conditioning. Let me know if you are interested and I can send you more information about the part. Email works best for me over PMs.
Thanks, Olmanwinter
Old Sep 20, 2021 | 05:58 PM
Big rebar
Ok
This car came with factory air. Does that change the length of the dip stick?
I couldn’t find the original dip stick length anywhere. Changed the oil for the first time this weekend and the book says 4 quarts, everything I find online says 4 quarts, and the dip stick actually says 4 quarts.
I put in 4 quarts oh high zinc Lucas hot rod oil and the dip stick shows 2 quarts low. It has been modified, the top of the dip stick is discolored and the end that sticks out is riveted to the bottom half.
can’t believe I didn’t screw up the engine, I added an extra quart earlier this year thinking it was low.
Old Sep 20, 2021 | 06:13 PM
jensenracing77's Avatar
If it is stock it will hold 5 quarts with the filter change.
Old Sep 20, 2021 | 07:17 PM
I am not sure how it changes the dipstick, but there is a separate one listed in the parts catalog for the Jetfire models and ones with air conditioning. Sorry that I won't be able to help you with that part.
Regards, Olmanwinter
Old Sep 21, 2021 | 03:23 AM
The Jetfire and A/C dipstick is nearly impossible to find. I would suggest that if you have a stock oil pan that you just use what you have. Do an oil and filter change and add exactly 5 quarts. Run it for a few minutes and then check the oil. Make a new mark on the dip stick where it is at and that is the new full mark.
Old Sep 21, 2021 | 03:25 AM
If you really wanted to you could just add 4 quarts and run it, then check the oil. Make a mark there and it will be the "add one quart" line.Then add the quart and check the oil again and make another mark for the full line.
Old Sep 21, 2021 | 05:46 AM
Big rebar
Dip Stick Pics
That is what I have done. Drained the oil, changed the filter, added 4 quarts. It shows to be almost 2 quarts low on the stick. Here are some pics of the stick that I have. It is stamped on the stick 4 quarts, but you believe I should add 5?
Old Sep 21, 2021 | 06:51 AM
With a filter change it would be 5 qts total. The bottom of that stick looks like the original. They have modified it from what it looks like.
Old Sep 21, 2021 | 08:02 AM
Big rebar
Thanks for the offer Ol Man Winter
tenracer
Feb 13, 2019 11:17 AM
Lewbo
Jul 24, 2018 07:33 AM
grandpa206
Jul 7, 2015 02:46 PM
maybell32
Jul 16, 2006 09:51 PM
