PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1967 cutlass 442 driver side quarter trim
  2. 67 cutlass 442 driver quarter trim
  3. '66-'67 4-4-2 Hurst Shifter Linkage
  4. 1965 Starfire 425 engine parts
  5. 1988 Oldsmobile Custom Cruiser Station Wagon
  6. 68-76 Toronado Oil Pan
  7. 69-72 Hood Hinges
  8. WTB: NOS 81-85 cutlass console ashtray lid (BURLWOOD)
  9. 1971 Cutlass/442 Driver's Side Door Latch Mechanism
  10. 74 Omega
  11. Single G70X14 Wide Oval Tire Needed For Spare
  12. 1965 Cutlass parts wanted
  13. 455 Block needed
  14. WTB rebuilt muncie m20
  15. SsII center caps
  16. 1963 Starfire trim
  17. 67 442 w-30
  18. Bucket Seat Tracks
  19. Bolt On Center Caps
  20. 56 olds
  21. 70-72 Cutlass th400 Gas Pedal Assembly
  22. 1976 toronado hood pop up spring needed
  23. 68 cutlass/442 dash panel
  24. Split lower vent for 8 track
  25. '65 Vista Cruiser Rear Bumper
  26. '68 door regulator
  27. Help??????
  28. 1964-65 F85 2dr sedan door edge molding
  29. Batten valvecovers
  30. QJet Vacuum T Fitting
  31. Looking for oldsmobile 350 v8 in Phoenix, az
  32. Batten valve covers
  33. 1971 Cutlass r/side power doors lock parts.
  34. Turn signal lever needed
  35. 1969 Cutlass Speedo floor shift wanted
  36. Blower Motor Resistor Needed
  37. Wanted: 1964 Dynamic 88 trim piece(s)
  38. 71 Supreme Conv Tick toch tach, blue ash tray door, blue collar for steering column,,
  39. 1970 cutlass rad support
  40. 1980 olds cutlass frame motor mounts
  41. 73 rally gauge wanted
  42. Radio
  43. 1968 Cutlass, 442 front black Seat Cover Upholstery
  44. 72 Cutlass Windshield stops or guides
  45. 65 442 4 speed throttle linkage
  46. Wanted: Olds 455 "N" Crank. Cut For 4 Speed Pilot Bearing With Snap Ring
  47. Hood Latch Support Assembly
  48. 72 CS Convertible Black Seat Belts
  49. 1967 cutlass supreme convertible drivers door
  50. 66 q-jet throttle arm & "au' metering rods
  51. 76 Cutlass door pull-strap end caps
  52. Mini-Starter
  53. 70 442 Coupe full quarter panel - Driver's Side
  54. Tilt steering column parts 69-75
  55. 1972 Cutlass AC/Heater Control Switch
  56. 403 sbo
  57. 67 Cutlass Bench seat w/ armrest
  58. WTB Front & Rear door panels 71 vert
  59. Interior parts for 55 Super 88
  60. 70-72 speedometer
  61. WANTED: Repro or Orig, upper OIA Plastic tray with vac valve and flap.
  62. 1966 Cutlass doors, hood, etc.
  63. 1964 dynamic 88 coupe. Need chrome trim
  64. Seat belts (Gold) for a '70 442 Holiday Coupe
  65. 68 Cutlass tail light lens
  66. 68 Delta Custom, need hood hinge
  67. WTB: 65 starfire hood
  68. 1970 Original Literature and Parts Catalog
  69. Toronado 1971 looking for NOS parts
  70. WTB: 1956 Olds 98 full quarter panel
  71. 1969-70 cutlass gold floor mats
  72. in need of a mint 1969-70 cutlass gold steering wheel
  73. Looking for 1970 Cutlass Bumper mounts
  74. 1955 olds gas tank
  75. 71/72 cutlass floor shift tilt column wanted
  76. power steering pump pulley
  77. 69 350 Quadrajet 7029250
  78. 1968 Oldsmobile 98
  79. 71 Supreme B-85 Moldings In Excellent Condition
  80. Need a 67 Cutlass Fan Shroud
  81. Air cleaner base
  82. SSII Olds wheel centres
  83. 71-72 bumper guards.
  84. 64 330 PVC vent tube wanted
  85. Super hail Mary pass here, anybody parting a 66-67 chevelle?
  86. 1957 hood
  87. WTB 1962 F-85 Lower Control Arm
  88. 1968 442 or W-31 radiator top plate - any condition
  89. WTB 15x8 SSII's need 2
  90. WANTED: 1976 Omega Parts
  91. Stock 350 Thermostat housing
  92. WTB 72' Cutlass 2-Speed Wiper Switch
  93. Dark green vinyl top
  94. 1970 cutlass s. Grilles / trim
  95. 1971 w-25 hood and a rear spoiler
  96. 1957 Super 88 Hood
  97. WTB Rear Axle Bump Stop Bracket
  98. Still Looking 70-72 Black Console and Standard Auto Shifter
  99. 57 Olds front license plate holder
  100. Harrison IF code 4 core tank
  101. 64-65 330 valve train
  102. 1949-50 Torque Converter
  103. 72 Cutlass 442
  104. WTB Rear Seat belts
  105. 67 442
  106. 70-72 Cutlass Rear qtr window tracks wanted
  107. Super T10 Cast iron mid plate
  108. Toronado dog dishes
  109. i need the H- type alternator bracket for an 455 with P/S and A/C
  110. 72 Cutlass steering wheel
  111. 70 core support
  112. 71cutlass tail lights
  113. 69 center console top plate
  114. 1967 OAI Parts or Pieces
  115. 1955 98 power antenna switch
  116. Wheel Well Trim (driver rear) 73 88 Royale
  117. Wanted: Drum hubs to fit 72 spindles
  118. 1970 4.33 or 4.10 Gear and Posi
  119. 70-71 supreme body side moldings
  120. Where to find drums 62 Cutlass
  121. looking for a L400/455 crank S.E. WI
  122. Battery Cable Tube for 1970 350 (4 Speed)
  123. 67 4 speed console
  124. 71 and 72 hood inserts
  125. 1970-1972 Oldsmobile FM/AM Radio
  126. Turbo 350 Kickdown cable and dipstick tube
  127. 1969 Cutlass Front wheel hub - drum brake
  128. 72 Cutlass S deck lid needed
  129. 66-67 Vista Cruiser Rear Bumper Wanted
  130. 1970 350
  131. 73-77 ttop Oldsmobile roof Hurst olds/442
  132. 1961 Olds 98 Water pump/AC unit
  133. Harrison rad tank
  134. 1961 Olds Starfire, Super 88, 98 wiper linkage
  135. ISO 1970 cutlass sports mirror driver side
  136. 81 Cutlass engine
  137. 324 Wanted
  138. 16" wiper blade holder
  139. 1965 N93 wheel cover emblems
  140. 330 valve train posts
  141. WTB: 1983 Chassis Service Manual
  142. 73-77 floor shift tilt steering column
  143. Body side molding fasteners
  144. Speed nuts for vinyl top trim
  145. Vinyl top trim pieces needed
  146. ISO blue ashtray door and springs 71 olds cutlass supreme convertible
  147. J pierce 64 dynamic88
  148. 64/65 cutlass dash pad, glove box door
  149. 67 cutlass/442 A/C dryer brackets and A/c control head
  150. 66 cutlass/442 rear tail lamp harness
  151. Pass side sail pannel for 72 cutlass S
  152. Starter number 1108333
  153. Rear brake parts
  154. 70 cutlass Convertible
  155. '72 Cutlass Supreme B85 Molding
  156. Passenger side fender
  157. 72 cutlass supreme convertible
  158. 70 442 shift lever
  159. Wanted 68/69 tach light bulb socket
  160. Trim Piece for '66 F-85 Bench Seat
  161. WANTED: 1965 98 Rear Bumper Brackets
  162. 1965 Delta/Dynamic Front Wheel Hub
  163. 1991 Olds Calais International
  164. NEED 2 1968 Cutlass Backup Light Housings
  165. Wanted 79 Cutlass interior parts
  166. Gas guage with dummy lights
  167. Plastic B Pillar inside covers, 77-79 B or C Body sedan
  168. 1969 hood
  169. transmission parts needed
  170. A body disc brake set up
  171. Need a Left Front Disk Spindle for a 72 Cutlass
  172. 1969 cutlass/442 B pillar trim wanted
  173. WTB - 1969 Remote Mirror Escutcheon Bracket
  174. 1953 olds super 88 manual trans
  175. wanted power steering pump pulley for 76 toro
  176. 1969 Cutlass Supreme body trim
  177. Wanted 1968 Fender
  178. Anyone know where I can buy a W25 OIA hood complete for a 1972 Cutlass 442
  179. Four-five 15X7 standard steel wheels
  180. 1966 1967 Cutlass 442 F85 left front fender
  181. 1967 rear end
  182. Toronado Gas Tank
  183. 1965 Delta 88 POLICE SPEC rear brake drum needed
  184. 1971 442 OAI Air Cleaner Base
  185. 1957 Auto glass
  186. Anyone have a 1966, 66 98 convertible side window glass
  187. 1962 Dynamic 88 emblem/script
  188. 1970 Cutlass wagon glass needed
  189. Water Nipple for Heater Core
  190. 350 olds SB oil pan
  191. HELP!! NEED a 350!
  192. For sale
  193. Wanted - 69 Cutlass trim, lights and misc.
  194. 72 convertible frame
  195. 66 442 Parts Needed
  196. 67 Cutlass conv top switch bezel
  197. 72 supreme
  198. 1977 Cutlass Backup Light Lens Needed
  199. 75 Cutlass NOS inner wheel well
  200. 1971 cutlass
  201. WTB edelbrock intake manifold for SBO part number 2711
  202. 1936 Oldsmobile F36
  203. Ralley Pack needs
  204. Oil Pan Plug
  205. Th 400
  206. Hold In Relay & AC Compressor for 70 442
  207. Wanted - junk BBO head
  208. WTB 70 455 SMT Battery cable tube and bracket
  209. 1970 W-30 Alternator
  210. Batten Olds Valvecovers
  211. Wanted #5 heads and other 69 parts
  212. 70 Cutlass Coupe Weatherstrip Retainer Corner Piece
  213. Looking for driver side sport mirror for 1970 cutlass 442 convertible
  214. 54-55-56 Heater Fan Resistor Wanted
  215. I need a driver sport mirror for my 1970 cutlass 442
  216. 1969 glass - passenger front window
  217. Looking for parts !!!
  218. WTB: 71-72 442 Rear Bumper Core
  219. 69 water pump 400269 wanted
  220. Single groove ps pulley needed
  221. 1970 Post, Sport Coupe Dash Pad. Non A/C
  222. 1970 Post Doors 442 W30 Sport Coupe
  223. Need non-a/c crank pulley 1972 350
  224. 455 Hot air pipe
  225. Dark Green 72 Cutlass headrests needed
  226. 67 442 Parts Needed
  227. Need 1970 cutlass core support
  228. 72 cutlass supreme FRONT BUMPER BRACKETS
  229. 70-72 Doors
  230. 66 cutlass bumper
  231. plastic 90 degree fitting for ca emission air cleaner (70-72 cutlass)
  232. 73 delta 88 molding
  233. #6 head
  234. 1970 7040251 carb needed
  235. NASCAR Block
  236. Power steering pulley
  237. Man seeks single real D head 400370
  238. Trim for side windows 76 toro
  239. Adapter Defroster 70-72 442/Cutlass 397784
  240. wanted: upper driver side door hinge 76 toro and
  241. 1964 Jetstar 88 Resurrection
  242. Need SS1 Wheel and car jack for a 1970 442
  243. WTB 3 speed Hurst lighting Rod shifter
  244. Bill D
  245. 66 98 2 door or convertible door moldings?
  246. Bill D
  247. 1967 Delta 88 Holiday rear bumper / side exterior trim
  248. white seat cover 1973
  249. WTB 69 Cutlass grills and headlamp bases and surrounds
  250. 1973 to 1975 plastic inner wells
