View Full Version : Parts Wanted
- Turbo 400 cable mount bracket
- 68-72 Rear Window Moldings
- 69 cutlass steering wheel
- omega parts
- 68-71 lower front air deflector
- 71 4 speed parts
- 71 Sienna interior
- 1st gen Toro parts
- 1970 Sheet Metal Wanted, 1/4s & Ribless Fenders
- 70-72 Cutlass/442 front marker lights
- Need windshield molding . 1967 Cutlass .
- Parts Wanted
- Looking for floor shift TILT column for 72 442
- Parts seller scam.
- 1965 Cutlass convertible glove box lock
- drivers side 1970 442 front grill
- Need '69 Cutlass 442 metal hood tonge
- need a fender (s)
- 1978 Cutlass Window Felts??
- 69 Cutlass Original or Repro In-dash Tach
- Vista Cruiser Frame
- 59 Power Steering Gearbox wanted
- 72 utlass Supreme window sweeps
- 1970 W 30 intake manifold wanted
- Turn signal switch
- 1970 cutlass 2D body, Supreme or "S"
- 61-63 Cutlass, Buick Special, Pont Tempest Front Subframe to Body Bushings
- Need rear end housing.
- 75 H/0 Interior Sail Panels wanted
- 71/72 rear windshield fastback
- Wanted 1975 Rear Bumper Filler
- WTB 1972 rear windshield w/defog
- aftermarket 4 barrel intake for a 350
- 1972 Trunk Reinforcement Rod
- 67 Cutlass Back Window Inside Trim
- 1975 Cutlass bumper
- Ratty looking 72 cutlass convertible interior
- Holley Street Dominator Aluminum Intake-OLDS
- Red Center Cap for 4-Spoke Sport Steering Wheel
- Looking for spark plug air fitting
- 67 Toronado Ball Joints
- 1956 Olds Power Steering Pump Bracket
- Rusted Crossmember mount
- Trans linkage
- 1972 Service Manual
- Wtb 70-73 4v rochester
- 58 tail lamp lens
- WTB Toploader 3-speed shifter
- Looking for a 70 Cutlass core support.
- '70 Olds 442 Rear Window Defogger Switch
- Wanted: F heads for 70 442 W30
- 1970 cutlass LAP VENT
- Delta 88 in Ireland, Rear quarter window
- Wanted 1966 88 or 98 fan and shroud
- Need BPO TH350 Inspection Cover
- 1968 Quadrjet Carb 7028253
- 8 Track
- Steel Fuel Pump to Bowl Line
- 71 Toronado
- 1963 394 needed
- Various parts for 69 Cutlass S needed!
- Need L-R rear 1970 convert rear trim panel
- 1965 f85 blue handled window cranks
- #8 heads
- 1969 F-85 front fender emblem
- Looking for 15" SSII's
- Parking Brake Pedal Pad
- Chrome hood hinges
- 72 hurst sunroof
- dashpot
- Wtb dual exhaust manifolds 69 425
- WTB 1/4 panel 70 hardtop 442
- WTB, a nice set of sheet metal or aluminum valve covers
- 1969 cutlass442
- GM Fuel Economy Gauge
- 67 Cutlass Steering Wheel.
- 1969 rally pack,bucket seats wtb
- 61 Olds Radio delete plate
- wanted 1970 OW transmission
- Looking for fuel injectors '81 DELTA 88 ROYALE, V8, 5.7L, N, DIESEL
- 68-72 A body power seat switch
- 1966 Toronado Floor Mats needed!
- 61 62 63 64 Olds 394 Engine Parts ,pulley brackets
- WTB 1966-1967 crank and water pump pulleys
- 1972 Olds 442 Sport Steering Wheel
- Black horn button for 71 sport wheel
- 62 starfire
- Water Pump?
- 68 442
- 67 Toronado 425 Decel Valve
- 1970-1972 Cutlass S Hardtop Quarter Panels
- 1970 98 fuel sending unit
- Sports Coupe Door Panel Clip
- 65 trans yoke
- 62 starfire center console
- Need rear for 70-72 A body in NJ
- 69 cutlass hood extension
- 1969 stock Q-Jet 4 Barrel Air Cleaner
- BBO exhaust manifolds
- o-axle gears / carrier
- 69 Cutlass Convertible Molding
- 70-72 Cutlass console lid
- Need: 1955 Rocket Trunk Emblem and Door sill plates
- 72 cutlass supreme convertible split bench black seat belts
- spider and dog bones from a 307 hydraulic roller cam motor
- 65-67 400 Dipstick
- 68-72 Convertible Frame
- Carb core:
- Gas Tank and carb:
- 61-62 Olds 394 3 groove water pump pulley
- 1965 Olds F85 Emblems
- caliper bracket
- Wanted dipstick/tube
- trade 7041251 for 7040251 carb.
- '70 Olds 442 Power Trunk Release Button
- 200.00 CASH PAID!!!! for 61,62 394 3 groove harmonic balancer
- 3 Small Parts Wanted for 72 Cutlass (vent, wing-nut, & plate lamp lens)
- 86 98 rear backup lens
- Service Guild/Technical Bulletins
- Rear bumper for 66 ninety-eight coupe.
- Vista parts
- console
- Sport mirrors
- needing a trunk striker for my 77 omega sx
- needing a chevy 69 350 engine
- Wanted: 69 cutlass drivers door window regulator
- I need a dash for a 77 Cutlass Salon
- N66 / Superstock II Wheels 14x7
- 66/67 Cutlass 442 F-85 Radio Plates
- 1970-72 Rally Pac Temp/Oil/Fuel Gauge Pod
- 1970 Passenger Side Sport Mirror
- Rear Bumper 79 Omega
- Jetfire parts needed
- 1963 Holiday emblem needed
- 1966,1967 th425 trans needed
- 1959 taillite a
- 71 Supeme wheel well moldings
- 1969 vinyl top trim
- WTB NOS clutch rod boot & Tempest
- 68-70 water pumps
- Need 70 F-85 glovebox door and emblem
- 71 console metal textured cover
- OAI breather setup for a 70 455
- Wanted to buy: early Oldsmobile 8 track tapes
- Wanted in N FL: '70 442 #'s for hood tongue + (2) Fender "2", driver quality
- NOS transmision pan for Toronado
- Chrome Shop Lost My Parts!!!
- 15 inch spoked hub caps
- 455 olds power
- 79 delta 88 Quarter Panel both sides
- '70 Passenger Side Sport Mirror
- 67 442 rally pac
- 394 dipstck tube/ water outlet
- A/C Outlet Duct and Connecting Hose For A 1968 Cutlass
- Muncie M20 for ´66 F85
- 69 driver quality front door panels
- WANTED: 61' Dynamic 88 parts
- 324,1.8 adjustable rockers
- BBO pulleys
- WTB: Red Horn Button for a 4-Spoke Sport Wheel
- in need of 455 heads!
- Looking for horn button cap assembly 1980 olds cutlass calais sport wheel
- Oldsmobile 350 intake
- 62 Olds Starfire A/C brackets
- Need Hood Hinge Springs...GM # 574802
- Need some things for my 71 Cutlass
- 1966/67 Toronado options
- Looking for Firestone tires
- needing Bucket seat backs
- '73 98 Parts
- '75 H/O Cutlass Supreme white rear inner door panels
- Sport Wheel horn button (black), does not need to be perfect/show
- '73-'75 Hurst Dual Gate Top Plate, fair condition/repaired ok
- 71 or 72 Rochester Carburetor
- 2 Connecting Rods for 394 engine ('62 Olds Dynamic)
- 72 Cutlass S Steering Wheel
- Parking brake cable guides
- 1971 cutlass sport steering wheel
- Moulding
- WTB: 1959 or 1960 Olds 371 engine
- '75 442 wheel, Goodyear HR70-15
- 69 Delta 88 Royale
- 68 cutlass console
- 455 or 425 engine
- Seat trim bezel, map lights, and twilight sentinal wanted
- Need SSIII Rocket centercap
- Radiator Shroud (1975 Cutlass)
- 1964,394 fuel pump
- 1968-70 Rear Spoiler Wanted
- WTB - 67 Toronado Exhaust Manifold
- 67 Cutlass Radiator Top Plate, Windshield Needed in N FL
- Need Rally Pack gauge part
- Duane Hayes in Peyton, Co contact?
- 70 442 Fan Wanted
- A/C bracket needed
- Need spinner hubcaps - 62 Starfire
- Hurst Olds aluminum intake
- 1964 Cutlass/F85 Filler Panels
- Need dipstick tube for 67 Toronado.
- 1964 Starfire Parts Needed
- 1965 Dynamic 88 Rear Bumper
- 1964 f85 bumpers
- Oil Pan
- 1969 Cutlass Holiday Coupe Trunk lid
- Cornering lights for 69 Olds 98
- bad bullet mirror (driver) wanted or shells for sale
- Need 1973-1974 SS wheels
- Edelbrock Olds 350 Performer #2711 Wanted
- '70-'72 Rally Pack Temp/Oil/Fuel Pod
- 1970 - 72 A body Parts (Cutlass) needed
- 71 Toronado
- 1958 Super 88 Coupe parts needed - HELP!
- 70-72 console rear lense
- Wanted: '68 Hood Hinges and '68 Front Bumper, N FL
- Needed Parts for My 1974 Cutlass W/350
- seeking 2 groove power steering pump pulley
- 307 Roller/350 D spider and dogbones
- 1967 442 headlight bezels
- looking for running 455 in NE
- 1968 Cutlass A/C Vent Duct
- wanted 1967 olds cutlass 442 hood dayton ohio
- 68 400 Choke Thermostat
- NEED parts
- wanted Oldsmobile Bulletin n/c 70-1
- M21 back drive linkage
- 1965 Olds 98 Gas Tank
- WTB: 67 442 Grille
- 65 quarter lip
- Trunk trim "oldsmobile" for '68 cutlass Convertible
- Looking for this Plastic Clip
- For a '37 Olds Touring Sedan
- 1965 Cutlass Window Regulator
- 1971 Cutlass Pearl seat buttons
- 68-72 AC Box Shell
- Rocker Arms, Trunions, Bolts for Oldsmobile V8 engines
- AC 40712 Fuel pump
- WANTED 70 442 HEADLIGHT BEZELS NOS Drivers side or both
- WTB 65 Cutlass Radio and Deluxe Hubcaps
- 1968 Ninety Eight NOS
- frame
- 1987 Cutlass Ciera 4 cyl eng. Torque Bracket
- 1972 hood grills
- Turbo 350 governors
- 1966 Cutlass/442 Bumpers
- '68-9 INTAKE J-398662 or 405233
- Bracket
- 442 1969 orig. antenna
- 1970 Toronado drivers fender & trunk lid needed.
- 3.08 3.23 1969 type o carrier
