PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Wtb 69-72 nos convertible weatherstrip
  2. 67 Cutlass Supreme passenger outside mirror wanted
  3. ISO OEM window sweeps
  4. Wanted 71 ram air hood
  5. Milodon Deep pan 1968-1972
  6. Trunk Tail Panel
  7. 66 cutlass water shields
  8. 69 442 Convertible Red Seat Covers
  9. "Medium Fawn Interior Paint" - Needed in a Spray Can...
  10. 1969 Muncie back drive bracket
  11. Set of 89 trofeo wheels w/abs
  12. Olds Hurst Dual-Gate Shift Knob Daka-Ware 1968-1975
  13. 1969 Core Support, Hood, Hood Tooth
  14. 1956 Oldsmobile rocket 88 oil pan
  15. 66 cutlass hood posting for a friend
  16. WTB-Hood Latch Area Underskin for 71 72 Cutlass
  17. Looking for white and chrome side body molding 3m for a 1975 Delta 88 Royal convertib
  18. WTB 1967-69 auto console door
  19. 1968 Olds 98 script
  20. 1100853 alternator wanted
  21. I am searching: Brake Distribution Block (Oldsmobile Jetstar 88, build 1965)
  22. 67 Cutlas Supreme Need drivers side Trunk Hinge.
  23. 68-72 Power Steering Pitman Arm
  24. 66 442 Ignition switch bezel
  25. 56 rochester 4gc
  26. 1965 1966 full size convertible interior windshield moldings
  27. WTB 1970 hockey sticks hood trim NOS
  28. SSII or SSIII wheels
  29. Need stock A4 (307) or Edel Performer intake for 403
  30. 68 442 tach
  31. Need help
  32. Wanted: SSII Center Caps
  33. 1973 omega
  34. '71 Cutlass Clock Lamp Wiring Harness Pigtail
  35. 1955 Olds 88
  36. Going back to a Quadrajet and need hardware
  37. G Body bucket seats & Console
  38. WANTED 71 W30 Intake Vacuum Fitting
  39. OCA License Frame
  40. ZR radiator tag
  41. WTB: 1970 Roof Rail Weatherstrip Channel
  42. Wanted: 1973 only Quarter Window Plastic Trim
  43. Olds 455 manual transmission crankshaft.
  44. Wanted: 1973-1977 BOP rear axle
  45. Spindle nut help
  46. 455 Big Block w/ AC Alternator Mounts
  47. Edelbrock 04B Spreadbore Intake
  48. 65 Cutlass Lower Body Molding
  49. 1967 Oldsmobile 98. Wheel opening & skirt
  50. Looking for pulley’s
  51. 70 clam shell mirrors
  52. 1980-90 Custom Cruiser Rear Bumper Fillers
  53. 1966-72 Olds alternator brackets non air
  54. WTB: 70 442 4 speed block
  55. WTB 1940 Olds coupe drivers rear fender.
  56. 68 OAI Dual Snorkel Air Cleaner
  57. 1967 Cutlass Cruise Control
  58. Wanting a 1967 442 Hood
  59. 1966 F85/Cutlass front bumper
  60. Starter core 1108333 wanted
  61. 1969 Cutlass 442 RH headlight assembly- NOS only
  62. Edelbrock Victor BB intake
  63. 68 Cutlass/442 Passenger lower quarter patch panel
  64. 1968 Cutlass/442 Gauge Housings
  65. Big Block EFI intake manifold and Dual Sync Distributor
  66. 1964 hood letters
  67. 1987 Cutlass Supreme 2 Door Rear Quarter
  68. 1987 Cutlass Supreme 2 Door Rear Quarter
  69. Wtb: 1969 OLDSMOBILE 98 power steering gear box
  70. Wtb: 1958 OLDSMOBILE power steering pump bracket
  71. Wtb: 1954 OLDSMOBILE hood letter set
  72. 69 Cutlass S bumpers
  73. 1972 Cutlass Supreme Horns
  74. 1958 Manual Brake Master Cylinder
  75. 67 Rochester Carb Baseplate
  76. 1969 442 black interior
  77. Non AC kick panel grilles
  78. Looking for nice 1974 442 grills.
  79. 61 Olds 88,98, Starfire Deluxe Steering Wheel
  80. 90 degree speedometer adaptor
  81. 67 442 door panel
  82. clutch return kit
  83. 371 Magneto
  84. 69 cutlass core support
  85. Backdrive linkage, 72, 455/400
  86. 73 delta 88 driver mirror
  87. License Plate Frame
  88. wanted nos 1972 442 grills
  89. 1970 w31 manifold
  90. shift collar for 1950 hydramatic, column shift
  91. 1970 a/c front compressor bracket.
  92. 1972
  93. WTB: Rally Pac Oil Pressure Sender for 68-72
  94. 4 way Seat Switch
  95. Big block engine mount frame pads
  96. 65 Starfire wiper switch
  97. Wanted: 1970 98 T/T Rim-Blow Steering Wheel
  98. Wanted: 1970 Night Watch Amplifier
  99. 83 Cutlass radio trim
  100. WTB Accessory horn ring 1950
  101. Floor shifter, Rear bumper
  102. 1969 442 Hood
  103. 1966 Cutlass convertible frame
  104. Looking for 1980 cutlass 442 parts
  105. ‘65 Rochester 4GC
  106. WTB: Cassette Player for 1988 Troféo
  107. WTB: pass. RH side sport mirror 71-72 Cutlass
  108. WTB - 1970 Ignition Cylinder Lock
  109. 66-67 Manual trans. throttle bell crank
  110. Console lock assembly 65-69
  111. WTB 14x6 beauty rings for SSiI wheels
  112. Jetstar 88
  113. shroud clips
  114. 1969 airbox vent
  115. Red W30 Fender Well - Patch pieces wanted
  116. 71 Supreme Jade Green Interior Parts
  117. 1970 w31 manifold
  118. WANTED '64 Olds speedometer part.
  119. '64 Cutlass Convertible front passenger door regulator needed
  120. ISO Green 8 track plastic
  121. WTB 1970 442 engine/block for 4 speed
  122. 70-72 console hinge wanted
  123. 1968-9 Cutlass Fender Molding - NOS
  124. 1967 442 headlight bezels
  125. WTB 12-Bolt Limited Slip 3:08 or 3:23
  126. ISO bell housing.
  127. 1973/74 Oldsmobile Omega Grille Badge
  128. Wanted: Edelbrock 7111 Intake Manifold
  129. WTB 3.42 ring and pinion.
  130. Wanted: 1970 Dual Gate Neutral safety switch
  131. Wanted- Tilt wheel steering column for a 73 Olds 98
  132. Wanted 1 NOS 419269 15" trim ring
  133. 1981 - 1987 Oldsmobile Cutlass Front Fender Molding
  134. 1954 drivers rocker molding
  135. Harmonic Balancer for a 1965 400
  136. WTB 72 Radiator Core Support
  137. SBO Heads & Intake-WANTED
  138. 1970 Cutlass column shift - needing the "hook" for indicator
  139. Looking for a 63-64 394 block
  140. 1964 olds cutlass holiday hardtop
  141. 1974-1977 Cutlass seat belts
  142. 69 Front Bumper
  143. 1970-1972 Cutlass right rear window corner plastic molding
  144. 15x7 SSII or SSIII trim rings and backup lens
  145. 66-69 parts list please read
  146. 69 442 LH Remote Mirror 399519/60309401
  147. Big body crossmember
  148. Steering Column
  149. 72 Cutlass NOS Door Weatherstrip
  150. 1965 442 alternator part # 1100694
  151. ‘65 400 - North East?
  152. 1977 Cutlass window roller needed picture attached.
  153. Nos interior door handles
  154. Bucket seats and console for a 1981 Cutlass
  155. 1978-1988 Rally gauge cluster
  156. 78-88 Cutlass Rally Speedometer Gauge
  157. Center console for '72 Cutlass
  158. Fly Wheel
  159. Fender
  160. 67-70 Toronado bumper jack box
  161. 72 Console wiring harness
  162. In need of trim piece for 1980 Cutlass Supreme
  163. 65 big car battery tray and hold down
  164. A pillar Trim
  165. Need help selecting quality parts
  166. '63 f-85
  167. 69 door panels
  168. WTB Manual steering box for 1970 Cutlass
  169. 69 hurst
  170. Need a Set of 81-87 Cutlass Doors
  171. 1956 Oldsmobile 88 4 door trunk pan/rear wheel wells
  172. 1984 Olds 98 steering wheel
  173. Parts wanted for 1987 442
  174. 1970 442 Door Hinge bolts
  175. 69 68 dash pad
  176. Oldsmobile Script Valve Covers
  177. 1968-1969 cutlass doors and fenders wanted
  178. 1970-72 Drivers Side NOS Door Skin
  179. WTB Deluxe Saddle seatbelts
  180. Cometic MLS head gaskets
  181. Seat belt retractor cover
  182. WTB '79-79 Olds Cutlass 442 Hurst Steering wheel-tan
  183. wanted '69 400 "c" heads
  184. Wanted: 72 Blue Bucket seat parts
  185. 65 f-85
  186. 68 2 dr post white interior needed
  187. 1964 Cutlass Frame
  188. Wtb: Nice original gas cap for a 72
  189. 69 under bumper scoops
  190. 15x7 bolt on center cap Super Stock II’s
  191. 1964 cutlass bumpers
  192. Wanted: 1973 Delta 88 front bumper "rubber trim"!
  193. Dual Gate dust cover black plastic thing
  194. 70-72 seat covers wanted
  195. Console part needed
  196. 1977 442 interior parts
  197. Need 1976 455 Rocker Arm Bridge?
  198. Steering wheel, 72 Delta 88
  199. W35 Rear Spoiler Gaskets
  200. 455 power steering bracket(s)
  201. 68 Cutlass Convertible Frame
  202. Does anybody have one?
  203. Cutlass S wheels
  204. 1956 Olds 88 (324) Misc Parts
  205. '71 - '72 Cutlass Turn Signal Lever
  206. Wanted Lower dash piece for a 1976 olds 98 very nice to excellent conditiont
  207. Looking to get a red dashboard and steering wheel
  208. Iso - 1987 cutlass aluminum ralley wheels
  209. 71 442 Jack Hook
  210. WTB 1970 Oldsmobile 442 Rochester Quadrajet 7040257
  211. '83 88 Dark Briar Brown Mats
  212. 1968 real 442 passenger fender not cutlass wanted
  213. 1955 Olds Back up Light bases
  214. 71-72 8.5 10 bolt posi axle near Minnesota
  215. Bumpers for 1968 442
  216. Sedan "B" pillar covers
  217. Part needed Vista Cruiser
  218. 1973 Delta 88
  219. 1970 w31 manifold
  220. On the hunt..
  221. No’s harmonic balancer 400 455 wanted or info on rebuilder
  222. Wanted NOS 71 350 Cam
  223. 1968 442 holiday coupe door and rear panel chrome trim wanted
  224. 1956 88 Power Steering Pump
  225. 72 442 Console Box Liner
  226. 400269 water pump date range 45 to 90
  227. 1968 Oldsmobile Cutlass S automatic column shift linkage
  228. WTB running Olds 350
  229. 15x7 SSll WHEEL
  230. 70-72 black rally wheel "horn cap"
  231. WTB: 1970 NOS side radiator flap covers
  232. WTB:1970 442 Hard top coupe rear package tray
  233. 1965 442 rear power antenna
  234. 1939 hood emblem
  235. Hood latch release cable clip
  236. 67 valve cover breather FB55
  237. Please help! Frame needed!
  238. 71 Toronado steering wheel
  239. 1967 Cutlass Passenger side Bucket Seat Track
  240. 1970 Cutlass Radio
  241. 68 2 dr post interior panels
  242. A part for my 1984 Olds 98 tilt steering column
  243. On the look out for air cleaner assembly
  244. 69 bumper brackets
  245. 69 Cutlass PS Headlight Housing
  246. 68 442/Cutlass trunk molding
  247. Edelbrock O65 dual quad intake wanted
  248. In Search of 67 Cutlass Deck Lid
  249. 1978-1980 Cutlass Supreme Brougham Coupe
  250. 1970 Cutlass / 442 Trunk Release Button
