'71 Cutlass Clock Lamp Wiring Harness Pigtail
Old Jan 27, 2022 | 02:33 PM
NO LONGER NEEDED
As per the image (below) I need the clock lamp wiring harness pigtail which includes the sockets. Thanks.
Old Jan 27, 2022 | 11:18 PM
Pretty sure you already have the harness. I think the clock plug was part of every dash harness. It’s a orange wire with a black plug very close to the clock.
Old Jan 28, 2022 | 06:27 AM
Matt - I need the clock lamp wiring harness pigtail which includes the sockets for bulbs - for illumination of the lamps. I believe you're correct on the (16 GA) female orange wire black (+) plug - it's most likely contained in the dash wiring harness.
The (16 GA) female orange wire black (+) plug will plug into the (center) positive (+) spade on the clock for continuous voltage to the clock. I believe (hope) there is an additional 20 GA GRAY wire with black plug which emanates/feeds off the INSTRUMENT LAMPS (ASHTRAY & CLOCK LAMP, CONSOLE & ACSRY LAMP FEED, HEATER LAMP). It is this GRAY wire with black plug which will feed the clock lamp wiring harness pigtail (see image).
Old Jan 28, 2022 | 11:51 AM
PatL's Avatar
I bought a reproduction 3 or 4 years ago, I believe I got it from M&H.
Old Jan 28, 2022 | 11:54 AM
Hi Pat - I ordered one this morning off eBay (PartsPlace). I did see some from M&H. I can't recall if this one is manufactured by M&H - might be. Thanks.
https://www.ebay.com/itm/352108410250
Old Jan 28, 2022 | 11:59 AM
PatL's Avatar
I Pat - I ordered one this morning off eBay (PartsPlace). I did see some from M&H. I can't recall if this one is manufactured by M&H - might be. Thanks.
Yes, Norm, that is it.
Old Jan 28, 2022 | 12:00 PM
I just found the exact same one on M&H, so they all most likely get theirs from M&H. Thanks for the feedback.
Bad68442
Jan 25, 2022 07:03 PM
Jul 20, 2012 06:27 PM
Flye
Aug 2, 2011 12:45 PM
wazoo
Dec 9, 2009 10:30 AM
Chumley
Dec 4, 2006 06:27 PM
