1968 Oldsmobile Cutlass S automatic column shift linkage
Old Dec 4, 2021 | 01:28 PM
1968Cutlassfallbrook's Avatar
1968 Oldsmobile Cutlass S automatic column shift wire for indicator
Hello
i’m looking for the wire that connects the column to the shifter indicator as mine is missing it’s for a 1968 cutlass S
Old Dec 4, 2021 | 02:37 PM
Just to clarify, are you looking for the little wire hook that runs from the column to the speedo, or the column shift linkage that runs from the column to the trans? Your title says one thing, your post says a different thing.
Old Dec 4, 2021 | 02:42 PM
Column wire 68cutlass
Yes I’m looking for the wire connection from column to indicator
Old Dec 4, 2021 | 02:52 PM
442crzy's Avatar
PM sent
Old Dec 4, 2021 | 03:07 PM
68 clip hook and link for automatic column shift
It’s the link and hook I’m looking for also the clip
Old Dec 4, 2021 | 06:34 PM
rcorrigan5's Avatar
Randy C.
How it looks behind the dash...
Old Dec 4, 2021 | 06:46 PM
Does it look like a paper clip that screws into column or does it have a tab or something
Old Dec 5, 2021 | 07:57 AM
rcorrigan5's Avatar
Randy C.
As I recall it looks like a pulled apart paper clip where one end goes into a hole on the spring-loaded gear indicator tab on the back of the speedometer and whose other end fits on the metal piece attached to the steering column.
Randy C.
Old Dec 5, 2021 | 08:17 AM
Thank you Randy hopefully someone will have an extra laying around they might let go
Old Dec 15, 2021 | 08:57 AM
Still looking for link and hook for column shift automatic
Still searching for the link and hook for my 1968 cutlass s automatic column shift to show what gear I’m in with the indicator
Old Dec 15, 2021 | 09:53 AM
matt68F-85's Avatar
I have one. PM me your address.
Old Dec 15, 2021 | 11:17 AM
Column shift automatic hook needed
Thank you to matt68F-85he was able to provide me with the link so now I’m looking for anyone who might have the hook that attaches to the column thank you for your help
Old Dec 21, 2021 | 08:30 AM
Column hook
I was wondering do 68 to 72 use the same hook for a column or is it 68 to 69 as I’m still looking any help will be greatly appreciated
Old Dec 21, 2021 | 08:38 AM
68-69 is a different P/N than 70-72
Old Dec 31, 2021 | 02:48 AM
6844268's Avatar
i may have that hook, it will take some time as a stripped a 68 yrs ago and kept every nut and bolt. i have buckets i need to look thru!
Old Dec 31, 2021 | 03:18 AM
6844268's Avatar
first pile i looked in, is this it?
Old Dec 31, 2021 | 07:29 AM
Hook
Yes that is what I been looking for
Old Dec 31, 2021 | 07:43 AM
6844268's Avatar
pm sent
Old Dec 31, 2021 | 04:49 PM
Thank you for all those who have helped I finally have all the parts needed so no longer seeking
scrappie
Aug 9, 2018 01:21 PM
young olds
May 1, 2018 04:55 PM
6884rocket
Oct 29, 2016 05:16 PM
cruznn
Sep 24, 2007 07:09 AM
<Cody>
Aug 10, 2003 10:00 PM
