Olds 455 manual transmission crankshaft.
Old Jan 25, 2022 | 08:16 AM
KCastl03's Avatar
Located in Charlotte NC area. Let me know if anyone has one. Thanks!
Old Jan 25, 2022 | 12:20 PM
RAG's Avatar
RAG
I have one but it's in NM, willing to box it and send it by freight.
Old Jan 25, 2022 | 06:30 PM
1970greensupreme's Avatar
You could use a auto crank, a decent machine shop could drill the end of the crank for a standard pilot bushing from say a SBC. I had one done probably 30 years ago.
Old Jan 25, 2022 | 06:56 PM
2blu442's Avatar
If you have a good automatic crankshaft here's a diagram of how to have it cut/drilled for a pilot bearing or bushing. I used this to have a crank done several years ago and it worked perfect.
Old Jan 25, 2022 | 07:28 PM
RAG's Avatar
RAG
I had a machine shop do that 2 years ago and they charged $200. 30 years ago the same shop charged me $50. It's not cost effective anymore.
Old Jan 26, 2022 | 07:44 AM
Hammerdrop's Avatar
I thought there was a bearing that would fit OVER the end of the crank.
Old Jan 26, 2022 | 10:39 AM
edzolz's Avatar
There is a bearing adapter but it requires cutting some off of the input of the transmission gear.
Old Jan 26, 2022 | 11:46 AM
lunaboy's Avatar
The Rocket Astronomer
have one here in texas if you ever this way
Old Jan 27, 2022 | 09:40 AM
tiogatwister's Avatar
I machine the cranks for $100, but I am located in the Detroit metro area.
Old Jan 27, 2022 | 08:36 PM
oldstata's Avatar
Justin
this bushing does need to have to be crank drill about a 1/2 deeper to clear or cut the trans input shaft
these are from a friend. I am planning on doing this very soon.
also if your already rebuilding the engine I can’t see them not being able to drill the crank for you
Old Feb 5, 2022 | 06:45 AM
37OldsCoupe's Avatar
Sent you a PM
Rick
Old Feb 5, 2022 | 08:47 PM
oldstata's Avatar
Justin
Rvsmith5
Jul 28, 2018 01:51 PM
bennie442s
Jan 8, 2018 01:56 PM
rad
Feb 28, 2016 09:05 AM
bryndalfly
Jul 10, 2013 05:01 AM
1971olds350
Apr 29, 2009 11:01 AM
