PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 65 cutlass frame
  2. 1969 A body power window regulators wanted
  3. 330 flywheel
  4. 66-7 A- body side window seal/trim
  5. G body rear upper control arms
  6. fuel pump 40712 delco
  7. 1970-1972 Non AC vents
  8. Rear Deck Lid bumpers
  9. Rectangular 68 Cutlass Supreme Rear Courtesy Light Lens Covers
  10. 7028251 Carb
  11. Power Seat switch needed for 68-72 cutlass 442
  12. 69 Oldsmobile Cutlass parts needed
  13. Wanted 69 Cutlass/442 Cigarette lighter
  14. Fan Shroud Attachments - 58 +
  15. 76 RH AC Panel
  16. Need SP T400 solenoid
  17. Olds 350 #8 heads wanted
  18. Wanted: 1954 Olds 98 trunk script
  19. 68 Cutlass/442 door wdge guards...
  20. 1961 Dynamic 88 wheels (2) wanted
  21. WTB Vacuum Advance MS-427-16
  22. Wanted 1 single solitary bastard Moxkey Thompson rocket arm cover
  23. Air cleaner
  24. Exhaust manifold Drivers side 1962 Oldsmobile dynamic 88
  25. Few parts Wanted such as 66-7 A body fan shroud
  26. Needed Asap.66 2spd correct shifter
  27. Dealer batch for trunk lid “David Ertley”
  28. 69/70 Delta 88 Front Bumper
  29. Iso kent- moore j-
  30. 1949/50 Olds 88 door limiters
  31. valve covers
  32. 1965 442 printed circuit board
  33. Control arm bolts
  34. Wanted 69 442 / Cutlass NOS front fenders
  35. 1972 delta 88 steering wheel
  36. valve covers wanted 455
  37. 70 Cutlass 4bbl air cleaner base
  38. Instrument cluster
  39. ISO Heater Core ’70 CS no A/C
  40. 69 NOS F-85 Front Bumper
  41. WTB: 1969 rear end ratio for A/C car
  42. WTB: 1969 Convertible Power Windows and power locks
  43. WTB: 1969 power Truck lid release
  44. Needed: 1969 Cutlass driver bucket power seat assembly
  45. 64 fiesta parts
  46. Need 2 items for a 1965 cutlass 442
  47. 1970 Bucket Seat Back - Need One
  48. Clock
  49. 200 r4 transmission Type T/GN
  50. 350 olds standard bore pistons
  51. 1972 Cutlass parts needed....
  52. Wanted 65 Cutlass Bumpers
  53. 1965 dynamic washer reservoir
  54. Oldsmobile PARTS Chassis and Body Catalogue. # 573.
  55. Oldsmobile PARTS Chassis and Body Catalogue. # 573.
  56. 1970 cutlass radiator support
  57. Oil filter housing
  58. 1972 ram air hood
  59. 1972 442 headlight bezel
  60. 1972 Cutlass Supreme Power Windows
  61. 70 Trunk Button
  62. 1111977 Distributor
  63. Wanted: 1970 Remote Trunk Release Button
  64. 65 f85
  65. 1972 442 hood moulding
  66. 1969 cutlass 442 rear side marker lights
  67. 74 Cutlass choke pull off rod needed
  68. 67 Cutlass fan shroud
  69. 1987 / 88 oldsmobile cutlass euro front clip
  70. 67 330 flex plate
  71. 49-50 Olds door
  72. Wanted: 1965 Olds Cutlass 442 Convertible Frame
  73. 64 cutlass front bumper
  74. Wanted 455 engine for a 1971 Cut
  75. Rear Bumper Guard 1987 Cutlass Supreme
  76. Looking for rear lower quarter patch panels for 1965 f85
  77. WANTED: 1964 Cutlass lens
  78. Want '70 sport mirrors please.
  79. Mickey Thompson headers
  80. parts wanted
  81. '69 AC/heater blower knob
  82. 48 98 Arm Rests
  83. F-85 Grill
  84. WTB trunk drip rail sheetmetal???
  85. 1955-54 headlight switch with rheostat for dash lights
  86. 1984 old custom cruiser wagon
  87. "Wanted - Full Set of 4 - Buick Poverty / Dog Dish Hubcaps"...
  88. 65 Jetstar Starfire headlight bezels
  89. 1965 1966 full size dash pad needed
  90. Scrap inner fender
  91. 1108348 Starter late 68 or early 69 date code
  92. pace car decals
  93. WTB Olds Center Caps GM # 557564 1977 1978 1979 Rally Wheels
  94. ignition coil bracket
  95. OG Transmission
  96. 72 supreme
  97. ISO 1968 442 driver side head light backing filler plate
  98. WTB: 71-72 Repro Ram Air 442 Hood
  99. Need 4 core radiator with CI and IF on tanks
  100. Horn button for 78-79 Batwing Steering wheel
  101. ISO of front door hinges
  102. 1966 1967 Cutlass/442/F85 Dashboard heater delete cover
  103. Need brake drum for 68 Olds 98
  104. 57 88 Convertible parts wanted
  105. 70 split bench armrest rear cover
  106. Tan steering wheel
  107. 70-72 Dual Gate shifter
  108. L69 “tripower” intake
  109. NOS 983108 cutlass door edge guards
  110. WTB - 1970 442 4speed 4 core radiator
  111. 68-72 GM Convertible Chassis
  112. 64 Jetstar 88 Upper Hood Lead Edge SS Trim
  113. Looking to buy 66-67 cutlass front bumper
  114. 1970 455 1108389 HT Starter
  115. 72 CS 2 door coupe body side molding
  116. 1965 442 gas filler neck
  117. '69 Cutlass Front Bumper
  118. 1970 455 HT Starter
  119. WTB 69 442 Rear Bumper
  120. Air Condition Brackets
  121. Iso pre 72 power anteni or parts or nos , 1100879 alternator , 1111973 distributor
  122. 1936 oldsmobile fuel sender unit
  123. Rochester Quadrajet
  124. 75 and 73 parts wanted
  125. WTB 1965 BOP Posi rear 8.2 10 bolt (complete)
  126. 72 passenger sport mirror lens
  127. 1972 Cutlass Driver's Side Door Latch Mechanism
  128. Wanted: 90 Degree Speedometer Adapter 395430
  129. Parts for my 66 olds vista cruiser
  130. 1967 pulleys and brackets
  131. SS 1 repo center caps
  132. 1956 Olds UK
  133. 1970 2-door power lock setup
  134. 6 Blade/19" Diameter Clutch Fan Fan
  135. 65 Cutlass clock
  136. 66 L-69 Tri-carb tags
  137. Wanted used black 2 door carpet bucket.
  138. Wanted 1972 Oai air cleaner/ w30 intake
  139. Black non ac kick panels 69 cutlass
  140. 8.2" BOP Posi Spider Gears
  141. 1971 NOS trunk lid
  142. Hard to get parts
  143. WANTED: 1964-65 Cutlass Carpet Toe Kick Panel
  144. rear bearing cap
  145. 73 cutlass dash speaker and defrost cover
  146. WTB: 455 Crank & Balancer
  147. 1970 carb cores
  148. NOS Front Brake Hoses for F-85 / Cutlass / 442
  149. 1956 oldsmobile 88 front lower bumper
  150. Looking for a NOS 1970 442 RH grille
  151. Power steering pulley: 399403 KG (1 groove)
  152. 70 GM lap belt release button
  153. SSIV wheels
  154. 1961 Oldsmobile Clamps and fuel fitting , big car or f85
  155. 1965 Club Coupe Parts Wanted
  156. Oldsmobile heads
  157. Rear sway bar
  158. firestone 70-14 wide oval tire
  159. Front and rear bumper 1965 Cutlass
  160. 67 Cowl Screen Needed
  161. PARTS WANTED PLEASE: Tail Lights/Tail Light Bezels
  162. Wanted: 1968 cutlass left front headlight housing molding
  163. Wanted: 1968 cutlass left front turn signal
  164. 1949-195? Headlights
  165. Glove box doors various models
  166. AC Dash Feed Duct
  167. Spinning buyer flag wanted / needed
  168. front bumper wanted
  169. 71-72 correct sport mirrors
  170. Wanted: Rust free lower control arms for a 1970 A-Body
  171. 1969 Cutlass/ 442 automatic center console, shifter and cable
  172. 1970 NOS stuff
  173. rotisserie wanted
  174. Iso 67 steering wheel pieces and 69 Vista trim
  175. 1965 425 alternator brackets
  176. 1967 Cutlass Hood
  177. 1966 L69 tri carb carburetor tags
  178. Oldsmobile 1964 330 v8 shaft rocker arm
  179. Wheelhousing Inner & Outer
  180. WTB: Performer intake for 455
  181. 1965 - 67 442 interior light assembly
  182. 1970 442 / 455 oil pan OE only
  183. 55 Holiday Backup Light cover?
  184. Notched Valve Covers
  185. 1962 accelerator linkage
  186. 72 Distributor Wanted
  187. "Wanted - G78-14 White Wall Spare Tire with Black Steel Wheel - Never Used"...
  188. 1970 Oldsmobile Quadrajet
  189. 68 Cutlass Sedan Passenger Side Power Window Motors
  190. 66 Cutlass Dash Pad
  191. 1966 OLDSMOBILE 88 - Bummper bolt and bracket
  192. 1971 olds cutlass chassis wanted in NY
  193. 2.56 rear end and axles 1962 to 1964 f/s olds/pontiac
  194. AC Ductwork
  195. 1968 Cutlass tilt steering column
  196. drivers side gold welt
  197. 1938 oldsmobile fenders
  198. 1968 442, looking both frt fenders and door trim
  199. WTB OEM 3.42 Gear set OR 671 Carrier
  200. WTB: 1959 Olds Power Antenna
  201. 79 Olds carburetor 17059253
  202. Your Old/Replaced SX emblems
  203. 1955 324 Road Draft Tube Assembly
  204. Looking for wire hold down clips
  205. 1970 complete trunk floor
  206. Molding
  207. 1983 Rocker Trim Needed, Driver Side
  208. 1969-1972 Steering column wave washer
  209. Power window conduit
  210. Steering column wave washer
  211. 67 Cutlass supreme rear wheel pot metal trim
  212. 73-77 Cutlass ducktail rear spoiler
  213. WTB - Fan Top Plate
  214. Black carpet
  215. Driver side Alternator bracket
  216. '70 Cutlass rear floor mat, black
  217. 1981 Custom cruiser passenger doors and quarter panel needed
  218. Original Four Speed Driveshaft wanted
  219. wanted mint 71 Cutlass 442 windsheild washer bottle
  220. 76 cutlass
  221. complete 455 in chicago area
  222. 71 -72 Cutlass Convertible Chassis
  223. Front of dash/upper cowl for 68 Cutlass
  224. 1968 Oldsmobile 455 Brackets
  225. Quarter panel skin 1966-1967
  226. 68 442
  227. Rear window chrome trim
  228. WTB 4 core harrison radiator 1970 W30 4-speed
  229. 67 cutlass/442 R/F fender brace
  230. 62 Olds Engine Needed
  231. Wanted 1970 olds 98 fender skirt chrome
  232. 1969 442 rear bench seat
  233. 425 emblems
  234. ISO Blue Inner door panels 1971 Cutlass S Car
  235. 1967 4 BBL air cleaner base
  236. 65 cutlass trim
  237. A-body ?68-72 Front bench with armrest
  238. 1969 442 rear black door panels
  239. Vista Cruiser glass
  240. For a 1976 cutlass supreme brougham
  241. Bucket seats for my 69 442
  242. Bearing cover
  243. K50 Breather option
  244. wanted 70-77 sport steering wheel horn button black
  245. WTB Nice OEM Trico Drivers Side Wiper Arm
  246. NOS f85 1961 right extension
  247. 1961 f85 bracket coil
  248. 68-72 Convertible Top Header Bow
  249. White headrests 70 -72 Cutlass buckets
  250. ‘70-‘72 Manual transmission shifter hump
