76 cutlass
Old Jan 15, 2020 | 03:35 AM
Bouzouki's Avatar
76 cutlass
Hello everyone I’m looking for a dual exhaust crossmember for a 76 cutlass supreme it currently has single exhaust can somebody help where can I find one that will fit so I can run the dual system thank you
also looking for a direct fit 2.5 dual exhaust anybody knows where I can find one they only sell for headers not for exhaust manifolds can anybody please help thank you
Old Jan 15, 2020 | 05:10 AM
ROCKETMAN269V's Avatar
You need to find one from a '73-'74; '75 was the first year for catalytic convertors and the last for true duals.
Old Jan 15, 2020 | 07:10 AM
svnt442's Avatar
Originally Posted by ROCKETMAN269V
You need to find one from a '73-'74; '75 was the first year for catalytic convertors and the first for single exhaust only.
FTFY
When they introduced the catalytic converter exhaust systems GM completely did away with true dual exhaust, even on the Corvette. They didn't start changing back to true dual systems until the mid 90's
Old Jan 15, 2020 | 12:23 PM
Bouzouki's Avatar
Originally Posted by svnt442
FTFY
so the 74 crossmember will fit the 76??
also looking for a pair of #6 heads if anybody gas any and also a dual exhaust where can I find a direct fit thank you
Old Jan 15, 2020 | 02:21 PM
deadeyejedi's Avatar
I posted a parts wanted ad here for mine ,took a little while but did get one .Yes the 74 dual hump will bolt right in your 76 using your existing holes no drilling required
Old Jan 15, 2020 | 02:29 PM
Bouzouki's Avatar
Thank you brother
Old Jan 15, 2020 | 02:54 PM
[QUOTE=Bouzouki;1221043].........also looking for a pair of #6 heads if anybody has any......./QUOTE]
I have the #6 heads. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jan 15, 2020 | 02:55 PM
crimsoncolby's Avatar
You can also use one from a '73/'74 Chevelle, Monte Carlo if that helps expand your search.
Old Jan 15, 2020 | 03:21 PM
svnt442's Avatar
Cutlass, Chevelle, Monte Carlo, Skylark, Lemans.
Old Jan 15, 2020 | 05:46 PM
Don't think Skylark will be wide enough. Century would work...as will Grand Prix, Grand Am, also. DO NOT use an El Camino/Sprint, though.
Old Jan 15, 2020 | 07:39 PM
vintagepne's Avatar
Check with Fusick Oldsmobile parts or YearOne I remember seeing what you are looking for at one of those companies.
Old Jan 15, 2020 | 08:01 PM
svnt442's Avatar
I couldn't remember if the skylark was an A body or X body those years. I looked it up and It appeared to be an A body....meh. There is also the Buick Special, but I don't know if they used that name before cats or not. A friend had a 76 special with a 231 in it. It was faster than my 75 Cutlass with a 260....that's not saying much.
Old Jan 16, 2020 | 06:41 AM
There are some aftermarket ones being sold. Personally, I like the looks of the originals rather than the chopped, boxy look of the repros...but, they do the job. I've even seen people cut and weld their own from a single exhaust crossmember.
Old Jan 16, 2020 | 11:19 AM
bigrbandit's Avatar
72 Cutlass Ponca City OK
https://www.summitracing.com/parts/s.../model/cutlass
Old Jan 17, 2020 | 12:50 PM
Summerof84's Avatar
Is this car just a driver? I have one off a 76 that the guy welded for dual exhaust. It's not pretty, but I'll sell it cheap.
Old Jan 17, 2020 | 01:49 PM
Bouzouki's Avatar
How much bro???
Old Jan 18, 2020 | 02:06 PM
Summerof84's Avatar
A couple pics. It's not ever going to fail, that's for sure!
Off 76 Cutlass
Rock solid
Old Jan 18, 2020 | 03:25 PM
Looks like a sturdy crossmember but looks more like a gbody crossmember .
Old Jan 19, 2020 | 09:33 AM
Summerof84's Avatar
Wouldn't a g body one be 2" narrower? This measured 52 1/2" and was on a 76 S at one time before being scrapped. That's all I know.
Old Jan 19, 2020 | 11:28 AM
Yes the gbody crossmember is narrower , I suspect the guy who built that one just used a gbody crossmember and made it the appropriate width for a 76 . He more than likely would have had to redrill holes in the frame as well .definately creative .
Old Jan 19, 2020 | 06:22 PM
Summerof84's Avatar
You do realize the 75-77 ones are angled to clear the catalytic convertor just like the G body?
Old Jan 19, 2020 | 06:35 PM
Yes I do I have one of each sitting in my garage both are originals and the 75-77 doesn’t have no where near the bend in it that the gbody one or the pic above has .either way if the one pictured above was in a 76 and the op wants to use it by all means use it .
Old Jan 20, 2020 | 12:35 PM
brownbomber77's Avatar
64-72 convertible will work, you just need to drill your own holes in the frame. I have one from a coupe and it's 54" wide. I installed it and drilled two new holes.
Old Jan 22, 2020 | 04:33 PM
rocketscientis's Avatar
73 - 77 dual hump X member
Hav a selection of those
stamped steel or tubular
Hav selection if #6 heads as well as any other # or letter
Pls call / txt 989 721 9432 if intrestred
Lansing Michigan
48872
Tim Gilliam
Hurst/Olds
Sep 24, 2012 12:46 PM
88hurstolds
Jul 14, 2012 12:28 PM
ksmitty
May 6, 2011 03:50 PM
tnelson
Dec 17, 2010 10:51 PM
Big John 85
Feb 6, 2009 11:01 AM
