1975 H/O Exhaust
Old Sep 23, 2012 | 06:28 PM
Tim Gilliam's Avatar
1975 H/O Exhaust
It came with a single exhaust. I want to put dual exhaust on it. How possible is this? I talked to my exhaust guy the other day and he wasn't sure because he said something about the tranny support might be in the way. Has anyone done this before and can you give me some idea's on what I am in for when I do this?
Old Sep 23, 2012 | 06:46 PM
Eddie Hansen's Avatar
I would think at worse you would need to find a 73 cross member I am not sure what year they switched from dual or single I know my 69 came with the double hump regardless of single or dual exhaust , I know/73 and 74 came with real duals but might have had specific cross members
Old Sep 24, 2012 | 07:07 AM
The 1973-1977 A-body cars used the same basic frame and the 73-74 cars were available from the factory with dual exhaust. Simply get a "double hump" trans crossmember from any 1973-74 GM intermediate (Cutlass, Monte Carlo, LeMans, Regal, etc) and it's a bolt-in.
Old Sep 24, 2012 | 07:12 AM
Do I need to worry about it being a TH400 tranny or are they universal between them and the TH350's?
Old Sep 24, 2012 | 10:12 AM
Crossmembers are the same. It wasn't until the A/G body cars (1978-88) that different crossmembers were used for different transmissions.
Old Sep 24, 2012 | 11:38 AM
So where would be the best place to get one of these and what am I looking for? Is it just a double hump on them?
Is there anything weird about the exhaust itself that I will need to worry about besides this?
Old Sep 24, 2012 | 12:31 PM
To clarify, EVERY 73-74 A-body came with a double hump crossmember, since dual exhaust was an option. You're stuck looking for a used one from the usual sources.
Again, dual exhaust was an option in 73-74. Get the pipes for one of those cars with the same engine. If you have a 350, you'll need to cap the crossover port on the passenger side exhaust manifold. If you have a 455 you'll want to swap to the W/Z manifolds.
Old Sep 24, 2012 | 12:46 PM
Okay junkyard shopping I will be doing.
Can you explain to me why? I was planning on using the stock manifolds and cutting somewhere down below the engine. My muffler guy mentioned something about maybe needing a new manifold for it. I'm at a loss as to what changing the manifold would gain and if I am why not just go to headers(which I really wasn't interested in doing).
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
landyacht1
Nov 19, 2009 12:33 PM
chkoo7
Aug 10, 2003 10:05 PM
