PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Need 2 394 cu in Flat Top Pistons
  2. 1967 AC compressor mounting hardware
  3. Need parts for a 76 Cutlass
  4. 69 cutlass drum hub
  5. Wanted OL4B intake for 350
  6. 1962 super 88 trim
  7. 65 Cutlass 330 non-AC PS pulley
  8. Manual steering Pitman Arm for a 56
  9. Seeking: Grommet for Power Window Harness (Rear)
  10. 1962 Starfire rear bumper
  11. 64 cutlass
  12. Right rear wheel well opening molding
  13. Vacuum tree needed, 69-70.
  14. Wanted aluminum fan blade from W car
  15. 56 Olds Side Trim
  16. Body Panels
  17. cruise control part
  18. Holiday 88 Chrome Trim
  19. need spring and rod for manual trans 55 olds
  20. Seeking a 66 olds TRACK PACK breather
  21. 69 442
  22. 66 442 hood
  23. Hitch for a 1964 Cutlass
  24. 1970 Fan blade
  25. Trunk Floor Pan
  26. 68 442 convert trunk lid
  27. Inspection cover screws
  28. 4 speed flywheel , for 350 nodular crank
  29. 1967 Cutlass/442 Wiper Arm
  30. ARH BBO 2in HEADERS
  31. 69 Cutlass: Black and Green Power seat cables + actuator
  32. 1964 vista cruiser
  33. 70-72 442/cutlass non console shifter w housing rods levers
  34. wanted 73-74 omega hatch mouldings
  35. Wanted - NOS or near perfect 71/72 Cutlass S Front Fenders
  36. Power Window Wiring Harness Piece
  37. 1987 to 1990 Oldsmobile Custom Cruiser fiber optic parts
  38. 1959 Olds steering wheel wanted
  39. parts for 76 olds cutlass 442
  40. TH400 Converter pan/Cover Olds
  41. WTB heads 1960 super88 394 ci
  42. WTB 70 turbo 400 trans - OW or OG code
  43. Oai w 25 hood for 71
  44. 57 olds 88
  45. WANTED 1952 Olds 98 steering box manual
  46. 1954, 1955 Olds hydramatic flywheel
  47. 55 Olds wiper arms needed
  48. wanted 1956 headlight buckets
  49. 1979 cutlass grille
  50. 56 2-door H/T Back Glass
  51. WTB: SS1 repops or originals, 15"
  52. Wanted 1962 14" wheels for Starfire (4)
  53. 66' Toronado 'chrome' wheels wanted
  54. Carb /intake for 61-62 star
  55. 1969 442 fenders
  56. WTB 64-65 Wagon LH tail light inner lens
  57. Parts wanted:
  58. 71/72 left fender
  59. looking for 403 motor mounts
  60. 3/4 Inch Beige Body Side Molding needed
  61. WTB for 1959 Olds Super88
  62. 57 Stainless
  63. Window crank knobs wanted
  64. bbo super comp headers 3202
  65. 68 442 post dark red interior and steering wheel
  66. 1966 f85 deluxe trim
  67. WTB Front Drivers side window (1965)
  68. 68-9 Cutlass/442 rally pack fuel gauge housing
  69. Parts List
  70. 1972 Cutlass Supreme Convertible Parts Needed
  71. Speedometer driven gear
  72. Wanted 57 standard Trany clutch fork.
  73. 66 Cutlass rear tail lights
  74. HELP IN DESPARATE NEED 69 cutlass 442 trim
  75. Vert seat belts
  76. 66 pistons
  77. Parts
  78. wtb headers
  79. 8 track player needed
  80. bumper suport brakets 69 cutlass
  81. Defrost switch '72
  82. 72' Cutlass S trim, frt bumper, dash, headlight bezel
  83. 1965 442
  84. 2.56 gears
  85. wanted 1970 OW or OG 400 turbo transmission
  86. Need a new fuel tank for 1967 Toronado
  87. Vista Roof Glass 64-67
  88. 70 Cutlass fenders
  89. 71 455 flexplate
  90. ash tray
  91. 69 thermostat housing, water neck,starter,pulleys
  92. 1969 Cutlass S chrome for Wheel Wells
  93. Rear Bumper 1965 Olds 88
  94. quadrajet 455 core year 1970 7040252 or similar
  95. Weld wheels
  96. WTB: 307 exhaust manifolds tube style
  97. 1976 cutlass s 442 parts
  98. 83 H/O body tape
  99. Hub cap retainers 55 olds 88
  100. Oldsmobile 455
  101. WTD: Hood Spear 67 Cutlass Supreme
  102. 73-77 Cutlass steering column
  103. 70-72 Cutlass console wanted
  104. WTB: 1970 Cutlass/442 decklid
  105. '68-9 "J" Inake wanted
  106. transmission TH350
  107. '66 Cutlass Convertible Resto
  108. Looking for a posi and ring & Pinion for a 9.3 rearend
  109. 63 F-85 back seat
  110. 71 supreme grills
  111. 1962 olds 98 hood hinges needed
  112. 70 442 Front Bumper Support Needed
  113. 68 Cutlass door and fender molding
  114. 400 piston
  115. 330 v8
  116. HEI Distributor for Olds 455 wanted
  117. Sheet metal below rear window and trunk
  118. WTB Power steering gear box for 55 olds
  119. fender skirts wanted for 55 olds 88
  120. camsem69
  121. 1957 Oldsmobile Fiesta 88 chrome trim..
  122. 1970 442 M21 4 Speed Back Drive Linkage
  123. 1973 Cutlass S/442 front bumper + rear
  124. wtb 72 vista parts
  125. Wanted: Wheel Opening Molding 1972 Cutlass
  126. 80's Delta red tail lights
  127. olds hub cap key socket
  128. 77 Oldsmobile Omega SX
  129. tilt steering
  130. Need Parts for '65 f85 Deluxe
  131. 3 speed shifter wanted
  132. 83 Hurst radio
  133. 66 442 Drivers Side Quarter Panel
  134. 1970 442 Convertible Quarter Panels NOS
  135. Oil Fill Tube 66 400 cu. in.
  136. 1970 442 Convertible Quarter Panels NOS
  137. Looking for 68 holiday coupe doors
  138. WTB - F heads for 70 442
  139. 66/67 Cutlass PS Rear Wheel Arch
  140. 68 442 Hood Moldin
  141. 1968 SSII trim ring
  142. 1967 Oldsmobile Cutlass Rear End Assembly
  143. 56 Olds rims
  144. 84 olds customer cruiser wagon
  145. missing hood latch
  146. 1979 Cutlass Cat Bracket Needed
  147. Looking for a 83 H-O speedometer head
  148. chrome notched valve covers
  149. WTB - '86 Cutlass Supreme door mirror
  150. WTB - 64 Starfire parts
  151. 1969 442 parts needed
  152. Wtb rear chrome bumper guard
  153. I need a front header panel and front driver side fender for my 1975 Olds Delta 88...
  154. 68-72 Vista parts needed
  155. vent window bolt
  156. need a 70-72 Cutlass console shifter
  157. 9" A-body rear end
  158. WANTED 1970 vista cruiser parts ontario canada
  159. 1968 Cutlass dash parts
  160. 1968 Cutlass Convertible trunk lid edge trim
  161. 1968 Cutlass Horns
  162. Looking for black floor mats front and rear for 71 Cutlass
  163. 8 track
  164. 1968 442 wiper knob
  165. 1978 olds
  166. 70 A Body Rear Quarter Drain Plugs
  167. 2 bbl throttle cable needed
  168. Tilt column for 71 convert cutlass
  169. 1974-1976 Olds 98 or Delta 88 DASH PAD
  170. 1988 Calais (FWD) parts needed
  171. WTB: 1970 inner front fender extensions
  172. 72 Stone Shield, Headlight Housing & 442 Emblems
  173. Dual gate shifter mount brackets
  174. 455 manifold
  175. broken 69 tic-toc-tach
  176. WANTED: 1985 Cutlass Supreme 442 vehicle cover
  177. 1970 442 Heater Switch
  178. 74 cutlass grilles and swivel seat belts
  179. 1111468 distributor and X-Y exhaust manifolds
  180. 455 main girdle
  181. 1957- 64 rear backing plate and drums
  182. Vista Cruiser
  183. 68 Cutlass Hood Trim
  184. Embossed Valve Covers
  185. 66 cutlass washer tank
  186. 1964 Dynamic 88 trim needed
  187. 69 cutlass power windows
  188. Need One G70 X 14 Firestone RWL
  189. 62 starfire Gas Tank
  190. oldsmobile f85 1962-1963
  191. 64/98 exhaust hangers
  192. 72 442 rear body panel
  193. new guy looking for interior trim pieces
  194. fan clutch
  195. 68 console shifter cable
  196. 324 running engine wanted washington state
  197. WTB - 71 Sienna Brown Seat Belts
  198. WTB 455 flywheel
  199. 1958 olds J2 tri-power air cleaner rocker
  200. 350 olds oil pan
  201. Need a door on the west coast
  202. Another New Guy 1964 Stafire Parts needed
  203. 1969 Cutlass S heater parts
  204. 1970 442 Chassis Service Manual
  205. 77 Cutlass hood and quarter panel fillers
  206. 1955 hood moulding
  207. Looking for an engine near mt vernon, wa
  208. 50 88 rear Q trim
  209. 1969 Chrome trim for post doors
  210. trunk floor 72 cutlass
  211. Window cranking mechanism
  212. Saddle interior 72 cutlass supreme
  213. smallblock dual 4 intake
  214. 72 Cutlass Rpm tic toc tach
  215. looking for parts for a 53 98 modell
  216. 70 72 notch interior dark saddle interior
  217. 1970 442 Dash/Column Cover Plate
  218. 1952 Olds 98 convertible pts wanted
  219. 1969 W30 ram air cleaner base
  220. Olds307 Throttle bracket
  221. 67 Olds 98 HVAC control panel
  222. Choke/Choke Thermostat for '67 4-4-2
  223. 1954 Rocket 88 Wheels
  224. '66-67 full wheel well trim
  225. Big Block Fender Brace
  226. 1967 Automatic shifter assembly to 3 speed
  227. 67 cutlass rear seat 1/4 trim
  228. 400 or 425 rods
  229. G body cutlass door
  230. '73 Toronado drivers door handle
  231. '69 cutlass 4dr parts wanted
  232. 66 442 trunk release
  233. 70-72 speedometer
  234. Wanted Early 70 W30 Intake OLDSMOBILE
  235. Post doors
  236. Looking for 69-72 bucket seat backs
  237. 74 Female Front Bucket Seat Belt
  238. '66 442 - Passenger front bucket seat
  239. Conv rear seat frame
  240. 1972 442 Rear Window Molding Set
  241. 1965 cutlass clock
  242. 68-72 rear lower boxed control arms
  243. Wanted, 1957 Jetaway Dipstick and Filler Tube
  244. 70 Lower Fender Brace
  245. '70 Deluxe Shoulder Belts
  246. 1957 4d Headliner Trim
  247. 71 cutlass bucket seat tracks
  248. 70-72 Cutlass parts needed
  249. 69 Cutlass Parts Needed
  250. NOS Super Stock II bezels
