PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1968 Cutlass Convertible Quarter Panel Moldings
  2. 1968 Oldsmobile 98 gravel deflector
  3. Dual Gate parts
  4. Shift Indicator Steering Column Bracket - Wanted
  5. 1966 442 lockset
  6. 1969 Cutlass grilles
  7. 1969 Cutlass S
  8. 1969 Cutlass S
  9. Rear interior quarter panels 71 Cutlass Conv
  10. 1968 Cutlass Reverse Lights
  11. 1964 f85 headlight switch
  12. Straight 8 piston rods or 303,324
  13. 1971 Cutlass Supreme Grills
  14. 72 cutlass supreme roof (Baltimore, Maryland)
  15. Looking for Bumper Bracket Washers
  16. 68 Cutlass Convertible Pillar Post seal metal track
  17. Corner moulding wanted 71 442
  18. Corner moulding wanted 71 442
  19. 70-72 am/fm radio
  20. bumper jack
  21. '70 AC Duct & POA Valve Clamp Wanted
  22. Kickdown Switch needed
  23. Wanted 1967-68 oldsmobile 12 bolt o type 31 spline axle shaft !!
  24. Wanted: 1990 Olds 307 Valve Cover
  25. 1967 kickdown switch wanted
  26. Rear deck filler panel
  27. Front Brake Drums for 67 Delta 88
  28. door and quarter window parts
  29. 1980 Cutlass Tail Lights
  30. Toronado Floor Mat
  31. 67 Cutlass Supreme - Needing parts
  32. 70-72 A Body Headlight Switch Ground Strap
  33. 1982 oldsmobile 98 regency
  34. 1982 oldsmobile 98 regency
  35. 1970 442,5 piece bracket For A/C compressor
  36. 4 core radiator top plate
  37. Muncie shift levers needed
  38. Fresh air vent cable
  39. Need a 56-1/2" drive shaft - '70 Cutlass 4-speed
  40. In search of this...
  41. NOS 67 and 72 Cutlass floormats, front, black
  42. WTB 1969 Cutlass/442 front bumper
  43. Need a 401372 6 bladed fan
  44. 77 442 Interiror parts
  45. 1964 Oldsmobile 98 front wheel hub
  46. bumper trim
  47. 1961 super 88 clutch parts
  48. Wanted 68 442 radiator top support
  49. Rare 1969/1970 88 and 98 Front Hubs and Disc Rotors
  50. Driver side rear window 4dr 1980 Regency
  51. One 73 to 80 14cc dish Olds 350 standard piston and rod needed
  52. 68 442
  53. WTB Dual Gate Shift Neutral Safety Switch '70-72
  54. 57-58 road draft tube
  55. Wanted: Radio for 1957 Olds 88
  56. 1970 SSI 14x7 rims
  57. Quadrajet secondary rods
  58. Wanted 75-76 delta taillights & 68-69 remote mirror pedestal
  59. Berejik Metal Dealer Emblem
  60. Need rear window trim for 71 Cutlass S
  61. Wire from engine bay to brake distributor block
  62. 1972 Cutlass Supreme coolant reservoir & bracket
  63. WTB 71 Olds steering Wheel
  64. 1969 or 1970 Olds 455
  65. Reverse lockout spring for rod down by trans
  66. 57 trans bell housing
  67. Fuel pump ac part # 40772 needed
  68. 8 Track Housing wanted
  69. WTB - '70 442 4 speed Driveshaft / Propeller Shaft
  70. Frame side motor mounts for gbody Oldsmobile
  71. 1970 Cool Ant Pump Non AIR Large outlet
  72. 1970 442 Coolant Reservoir
  73. Wanted 70-72 Cutlass S/442 quarter panel patches LH/RH
  74. WTB 1970 rear wing/spoiler W-35
  75. WTB 64-67 Intake Stud Bolt
  76. 70-72 Dash Pad and Panel Mounting Studs
  77. Remote Mirror
  78. Wanted Seat belt bolts 71 442
  79. 1956 front hub
  80. 67 442 fan
  81. 1973-74 dual hump cross member for MT
  82. 68 Vent window mounting screws and a brake release handle
  83. 68 Cutlass Supreme Holiday Sedan 4 dr door panels
  84. Wanted: 1979 Cutlass Supreme horn cap (steering wheel emblem)
  85. In search of...
  86. M21 speedometer 90* adapter needed
  87. want: oil filler stand pipe for 350 in exc cond.
  88. NOS 65 Starfire/Jetstar 1
  89. 58 Olds switch to Power steering
  90. Wanted 1966 vista cruiser nos parts
  91. '70 442 Grills - pieces needed for repairs
  92. Wanted AM/FM Cassette 16065414 for 1990 Olds Custom Cruiser
  93. 67 442 bumper restoration
  94. 64/65 Cutlass Dash Bezel
  95. Shifter cable
  96. 65 Cutlass lower core support needed
  97. 88 window handle
  98. Trunk Liner Wanted
  99. Z Exhaust Manifold
  100. Any built performace BB Olds 455's out there?
  101. Iso 68 B- body Posi differential
  102. Power steering box
  103. Edelbrock o65
  104. 1968-1968 Cutlass Outside Mirror Mounting Nuts
  105. 1970 Heat Shroud and Riser - Wanted
  106. throttle return spring
  107. Harrison EC - Wanted
  108. 6462137 Oil Sending Unit Wanted
  109. Bracket '70 442 Manual Brakes
  110. Power antenna chrome bezel and gasket
  111. 1970-72 LH Rear Wheel Opening Moulding
  112. 1967 Cutlass Supreme
  113. Exhaust Heat Riser Rebuild Kit
  114. 1957 Straight front bumper
  115. SSII wheels
  116. Hey guy’s, I’m look’n for some parts.....
  117. Looking for 1968 Cutlass Convertible DS Remote Mirror
  118. Radiator overflow hose clip
  119. w31 fuel line
  120. '70-72 8 Track Player Housing WTB
  121. Looking for a 70/71 Deluxe steering wheel
  122. 1970 Fan Blade
  123. WTB 69 442 front license plate frame
  124. ISO 1970 442 Downshift wiring feed
  125. Tilt column shift tube
  126. WTB '70 442 hot air pipe
  127. 1966 88 fender patch
  128. !
  129. Tailight housings
  130. WTB 69 or 70 442 air cleaner non OAI
  131. WTB 1969 cutlass convertible peak trim
  132. Manifold heat shroud for '70 350 - damaged?
  133. Anybody parting put 71-72 D88 and/or Ninety Eights?
  134. 200r4 BOP
  135. Needed - panel below rear window to trunk.
  136. Cutlass S hood tongue emblem 1970
  137. Upholstery/seat restorer referral
  138. Thornton big block shortys
  139. Iso 69 n34 sport wheel
  140. Cruise Control
  141. Looking for 66/67 Wiper Transmission
  142. Strato Bucket seat lock strap assm.
  143. WTB AC Dash Feed Duct left vent for 70 442
  144. '70 - '72 Cutlass Convertible Trunk Striker
  145. Valve covers
  146. 455 engine
  147. Hi and Lo horn for 1970 442
  148. 75 Cutlass Supreme vinyl roof trim
  149. 1968 Passenger Side Vent Window
  150. 1968 442 master cylinder 5452310 wanted CT code
  151. Contact info of man familiar with rocket science & CBW
  152. ISO 64-66 floor shift OPERATIONAL Shifting HANDLE mechanizm
  153. Dual Snorkel Air Cleaner for HEI
  154. Power antenas prior to '72...
  155. stone shield 71
  156. 1969 Cutlass Washer Fluid Jar
  157. 1972 Cutlass Supreme Radiator Top Plate
  158. 73 Valance Lenses wanted
  159. Passenger side alternator brackets
  160. 69 cutlass hood latch spike
  161. WTB - Edelbrock 6051 Aluminum Cylinder Head
  162. In Search of Trunk Oldsmobile Plate and Driver mirror cable
  163. H Heads
  164. gas pedal assemble
  165. Wanted - 4950788 Clutch Fan
  166. Wanted - '71 Cutlass Headlight Bezels
  167. 1967 cutlass hood lip trim wanted
  168. Wtb 72 cutlass supreme 442 hood
  169. 1970 W30 Ignition Coil & Bracket needed
  170. WTB: 1970 rally pack gauges & tach
  171. distributor 69 H/O
  172. Drive shaft
  173. 71 Rocket 350 PCV Valve NOS #
  174. 403 in NW
  175. 71 Vista Cruiser part or really good fabricator
  176. 330 or 350
  177. Idle stop solenoid
  178. 1964 330 timing cover seal
  179. 1967 CutLass Air Cuditioning Center Duct
  180. Chrome 14 x 6 SS1 (disc brakes)
  181. 1963 Oldsmobile Starfire Right Tail Lens
  182. Wanted Hood twist locks
  183. Sport wheel with black center cap Wanted
  184. Console door
  185. 70 tic toc tach
  186. 66-67 vista roof glass wanted
  187. 1971 cutlass engine and forward lig
  188. 76 Olds 98 parts
  189. QJet Front Vacuum Pull Off Bracket and Screws
  190. WTB Left Side Notched Valve Cover
  191. 71 442 driverside glass green
  192. 71 442 driverside glass green
  193. Wanted: Harmonic balancer
  194. Nice 71-2 front bumpers
  195. Stainless Wheel Well Mouldings for '69 Toronado
  196. Wanted: Passenger Side Door Handle Transmission
  197. 1963 Super 88 Hubcap
  198. cultass cruiser header panel
  199. Jack bracket
  200. M/T Valve Covers
  201. '65 Vista Cruiser Plastic Glass Trim
  202. 70 A/C Duct
  203. 66 cutlass windshield washer nozzle
  204. 1973-75 Reservoir Bracket
  205. 71' Cutlass lower steering column bowl, Floor shift, non Tilt.
  206. 1988 Oldsmobile 98 regency brougham
  207. Looking for 200r4 transmission
  208. Performer 2151 wanted
  209. Iso nice red 67-68 steerin wheel
  210. Tri carb end carbs linkage rod wanted
  211. '73 Emissions Decal
  212. NOS First Type 70-72 A/C Muffler
  213. Looking for 1961-1962 Olds 88 Bendix Brake booster
  214. Turbo 400
  215. Looking for a 1970 Hot Air Pipe for 455
  216. Wanted: 70-72 Supreme Quarter Panels w/Sail panels.
  217. 64 Cutlass Rocker Molding End Caps
  218. 15" 5 on 5 Bolt circle steel wheel
  219. Oldsmobile 303 Rocket Engine Spark wire Covers
  220. 69 cutlass hood latch pin
  221. Piston
  222. WANTED: 64-65 power seat track driver
  223. Power seat tracks
  224. 1971/1972 T44 hood lock assembly
  225. 71' 5" Cutlass black door panel carpet.
  226. W-27 rear end 1970 W-30
  227. Parking brake light switch
  228. '70 Cutlass/442/VC Steering Wheel - Gold interior
  229. someone was looking for 70 442 sport mirrors
  230. Wanted: Red Sport Steering Wheel for 1973 Cutlass
  231. Soft ray roof glass for 65 Vista Cruiser
  232. 1964 Cutlass, turning signal stalk + Rocker trim (pictures inside)
  233. 1972 442 grilles
  234. Neutral safety switch needed
  235. 69 rear sockets or harness oem
  236. 69 Cutlass Hood
  237. Wanted
  238. Wanted Tail Gate Window mechanism
  239. 1969 Olds Delta 88
  240. 65 blue interior
  241. 65 dash pads. Aqua and dark blue
  242. 64 cutlass hood wanted
  243. 1969 HO alternator 37A
  244. 69 Cutlass Hood
  245. 🚨🚨🚨looking For Parts 1967 Delta 88
  246. Headlight switch bulb bracket
  247. 66 442 heater/ac fan switch
  248. Fuel Tank - 1967 Delta 88
  249. Clutch return spring clip
  250. 1957 drivetrain wanted
