ISO 1970 442 Downshift wiring feed
Old Aug 31, 2020 | 07:50 AM
EngineErnie's Avatar
EngineErnie
I am in search of the two wires and clip that runs from the under dash harness and plugs into the gas pedal (as shown in the photo below) downshift assembly. My two wires are cut and I need to make a repair. I would like some extra length of wires to allow us to make the repair.
Old Aug 31, 2020 | 08:42 AM
4speed455's Avatar
I should have this. Let me double check condition and I will PM you with details later.
ROCKETMAN269V's Avatar
I have some harnesses for parts. How long of a "pigtail" do you need? Thanks, Bob.
Old Aug 31, 2020 | 09:14 AM
EngineErnie
I need it from the pedal all the way to the steering column itself (and ideally 3-6 extra inches of the wiring if you can trace it back over the steering column and safely get to it/remove that much). Thanks. My zip code for shipping calculations is 37122
Old Aug 31, 2020 | 10:12 AM
I will check to see what I have. Thanks, Bob.
Old Aug 31, 2020 | 02:40 PM
I need it from the pedal all the way to the steering column itself (and ideally 3-6 extra inches of the wiring if you can trace it back over the steering column and safely get to it/remove that much)........
Okay, the harnesses that I have are not in a vehicle. What is the TOTAL length that you want from the plug to the end of the wire where I will cut it. Thanks, Bob.
Old Aug 31, 2020 | 03:48 PM
EngineErnie
Bob can you cut 20 inches worth of the two wires?
Old Aug 31, 2020 | 04:10 PM
4speed455's Avatar
PM sent.
Old Aug 31, 2020 | 04:13 PM
Not a problem. Email me so we can finalize payment, shipping, etc.: drolds1@bellsouth.net. Thanks, Bob.
Old Aug 31, 2020 | 04:14 PM
EngineErnie
Bob
i have found one already but thank you
brad
Oldracerjones
Oct 1, 2019 02:42 PM
tru-blue 442
Dec 5, 2017 09:30 AM
joesw31
Sep 8, 2017 03:29 PM
Timberice
Aug 16, 2014 09:46 AM
g77rvd
Jan 27, 2011 06:29 PM
