Hey guys I'm looking for the lower core support for a 65 A-body. I'm going to cut the bottom of the core support off my 64 off and graft the 65 in, giving me 3 more inches in length of radiator for the 400E.Thanks.
Hey Robski,
I don't have a 65 core support, but I made this mod on my 64 to get the aluminum radiator lower. It was real easy with only a couple of extension plates welded in. Works well, as none of the other geometry changes. Should be an easy fix for you with all the welding you've done.
I have a nice 67 core support. Never any rust. Not sure if it would fit a 65 or not but you might get the width you want from part of it. $100 if you pick it up in
Red Oak.
Ed
almost any sheetmetal shop should be able to make them with your measurements. Check with heating companies around your area. They all use sheet metal fab shops or have one of their own to do that.
