65 Cutlass lower core support needed
Old Sep 7, 2020 | 04:50 PM
therobski's Avatar
Hey guys I'm looking for the lower core support for a 65 A-body. I'm going to cut the bottom of the core support off my 64 off and graft the 65 in, giving me 3 more inches in length of radiator for the 400E.Thanks.
Old Sep 7, 2020 | 06:00 PM
Big Daddy Spo's Avatar
Hey Robski,
I don't have a 65 core support, but I made this mod on my 64 to get the aluminum radiator lower. It was real easy with only a couple of extension plates welded in. Works well, as none of the other geometry changes. Should be an easy fix for you with all the welding you've done.
Old Sep 7, 2020 | 09:11 PM
edzolz's Avatar
I have a nice 67 core support. Never any rust. Not sure if it would fit a 65 or not but you might get the width you want from part of it. $100 if you pick it up in
Red Oak.
Ed
Old Sep 8, 2020 | 08:32 AM
RAG's Avatar
RAG
Core Support
I have a lower core support to sell separately in NM, email me at rgreen@q.com for photo and price.
Roger
Old Sep 8, 2020 | 09:01 AM
therobski's Avatar
BIGDADDY-by chance were did get those pre-fabbed vertical extensions? That would be the perfect solution...
Old Sep 9, 2020 | 05:53 AM
lemoldsnut's Avatar
almost any sheetmetal shop should be able to make them with your measurements. Check with heating companies around your area. They all use sheet metal fab shops or have one of their own to do that.
Old Sep 9, 2020 | 07:24 AM
therobski's Avatar
I found a piece locally here in the Dallas area. Thanks guys..
Old Sep 9, 2020 | 08:20 PM
Gerald Nickels's Avatar
What I did on my 64 Cutlass was drill out rivets 4 on each side on both core supports then bolt it on your 64 core support done deal.
Gerald
Old Sep 10, 2020 | 07:13 AM
therobski's Avatar
Is that a longer-deeper 65 rad or something else? I want to get the biggest rad that will into the space allowed. Thanks.
Old Sep 10, 2020 | 09:08 PM
Its a 3 core.
sbceater
Jul 27, 2014 08:41 PM
Napoleon Solo
Apr 29, 2013 10:16 AM
Pacecar
Body work
Aug 27, 2012 06:44 PM
therobski
Apr 8, 2012 05:52 AM
