PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1965 ninety eight power window switches
  2. 75 olds delta 88 pinch weld trim, lower door panels, blk front seat belts
  3. 394 4 speed
  4. Am Fm radio ,8 track
  5. 1965 442 Drivers Side Scoop for a friend
  6. 1969 red inner wells, used is great
  7. Looking for 455 heads
  8. C head
  9. 73 Cutlass Supreme Wheel Arch Trims for Quarter Panels
  10. WTB Carb for a 1978 260 engine
  11. WTB: Bowl from a Rochester 2G carb small base to suit J2 in 1958 olds
  12. 1972 Cutlass headlight surround
  13. 68 Olds 350 Non-A/C car build Cutlass S
  14. WTB: W-31 Aluminum Intake
  15. 1962 super 88
  16. 1973 Cutlass S / 442 Back up lenses
  17. 70 convertible top header bow
  18. R/L headlight and parklight Bezel
  19. 1969 through 1972 Buck Seats
  20. #5 cylinder heads
  21. WTB: 1970 Non A/C Kick Panels
  22. 65 442 parts needed
  23. 1967 Toronado car fire. Need Parts.
  24. choke thermostat
  25. 72 cutlass tail light
  26. WTB: 1980s B/C body front bumper
  27. '69 Dash Parts
  28. 70 E heads--Will Pay $400
  29. WTB: 70-72 Manual Trans Shifter for Non Console
  30. 1970 ram air hood wanted, repo OK
  31. manual steering box wanted
  32. 59 radiator or radiator core
  33. 64 Cutlass Fiberglass
  34. Vacuum actuators
  35. 64 cutlass trim
  36. throttle kickdown switch
  37. TCS solenoid needed
  38. 1965 Cutlass/442 Tail Lights/Rear Trim Panel
  39. Running 425 or 455
  40. anybody in the seattle area have an extra 455 timing tab?
  41. "O" axle ring and pinion
  42. 66 330 Exhaust Manofolds.
  43. 1970 442 power window parts
  44. 176 tooth stick fly wheel
  45. 1970 NOS Cutlass Headlamp Bezels
  46. NEED Th400 Shifter Cable Selector Bracket
  47. Need wiper motor for 71 "s"
  48. Front Fender trim for '47 Model 66
  49. Rear Window Molding
  50. Tilt Steering Wheel Cam Needed '68
  51. 330 or 350 engine or bottom end
  52. 68 Cutlass S Hood and Trunk Lid
  53. 1974 Delta 88 Tail lights
  54. want a used 56 olds windshield
  55. 1965 442 Side Scoops Driver or better
  56. 71-72 Cutlass Bumper guards
  57. Crankcase baffle
  58. radiator shroud
  59. 1961-63 cutlass solid front floorpan+tint windshield
  60. 1971 Cutlass S Front License Plate Bracket
  61. 67 Cutlass, front hood molding
  62. 64 olds cutlass convertible trim needed!
  63. 71 Cutlass
  64. 77-79 rear quarter window
  65. 1967 98 convertible
  66. Looking for gas gauge
  67. 68 442 parts needed
  68. 67 Toronado Door Panels
  69. 67 Cutlass, rear q. panel molding
  70. Need 66 442 panel between trunk & bumper
  71. 64 Olds Cutlass convertible parts needed please!
  72. Trans Portable Radio Cable Wanted for 1959
  73. need rubber bumper strips for 73 442
  74. spider and dog bones from a 307 hydraulic roller cam motor
  75. 68 Cutlass S 442 Clone Restore Parts needed
  76. Gas Pedal for a th350
  77. Looking for '71-'76 B/C Body Rear Sway Bar!
  78. glove box lid
  79. '72 Vista Cruiser parts wanted
  80. Wanted 67 wagon roof rack (Non Vista)
  81. WTB: 1970-72 Tag Light
  82. 68-72 post coupe exterior molding b pillar clips
  83. 1979 Cutlass Calais
  84. WTB 3 spd Shifter
  85. 1969 Olds 98 parts needed
  86. WTB or trade Harland Sharp roller rockers
  87. Need 1970 W-30 Complete Engine
  88. 25 tooth orange muncie speedo gear
  89. 1971 442 OG Transmission
  90. 1975 cutlass supreme shifter cable
  91. 1962 super 88 gas tank and rear bumper
  92. 71-72 OAI hood
  93. 1969 442/cutlass conv quarter panels
  94. need a set of rear springs for 68 442
  95. late 70's starfire type tan 4 spoke steering wheel
  96. 56 Olds distributor
  97. Wiper linkage
  98. 4 spoke Steering Wheel for a 1971
  99. alternator support bracket 71 -350
  100. 1967 Cutlass/442 Parts Wanted
  101. Friend of a friend needs nice '75 Delta 88 bumpers
  102. Wanted: RF lower fender brace for 67 442
  103. WTB Engine
  104. '69 AM/FM Stereo Radio Front/Rear Spkr Knob
  105. Heat shield for a 1970 442 W30
  106. Sport Steering wheel hardware
  107. NOS Fenders for 1970
  108. wanted
  109. 1970 dashpot
  110. Rear Sway Bar for '67 Delta!
  111. 7028250 Quadrajet or baseplate
  112. wanted 1990 Trofeo
  113. WTB: '71-'72 vacuum control switch
  114. 69 442 drivers door panel post cpe
  115. 1968 Cutlass 2 Door Post rear quarter window channel
  116. ISO various 71 convertible parts
  117. early flywheel
  118. Dark Green 72 Supreme Headrests, for Buckets
  119. Wanted: 1970 Cutlass Steering Wheel
  120. 67 sending unit
  121. 67 Toronado Cancel Cam
  122. Help 67 Part Number Please, Parts Book
  123. 72 cutlass overflow tank
  124. Looking for shroud
  125. 455 oil pan
  126. 68-72?
  127. New '70 Cutlass Headlamp Surrounds
  128. 68 Toronado front wheel hub assembly
  129. Wanted Grill for Rallye 350
  130. 71-72 Cutlass Fender Eyebrow Molding - LH
  131. Pearl headrests
  132. 1975 Cutlass parts needed
  133. 68 Parts Wanted
  134. looking for a speedometer
  135. looking for 68 cutlass parts
  136. WTD: 67 Cutlass Type 'O' axle
  137. 71/72 Passenger door Saving my wifes car after Sandy storm
  138. SS1, 15", 7" and 8"
  139. hood lip molding and wheel well moldings for 77 cutlass supreme
  140. looking for back seat window trim for 77 cutlass supreme
  141. 1966 Olds 442 Steering wheel
  142. 1967 Toronado Parking cables
  143. 1966 442 Antenna mount and antenna
  144. i need door panels for 69 cutlass 2dr
  145. Are all these posts still active??
  146. 70 olds 442 engine or block
  147. Seeking power window switch retainers/clips - 1970
  148. single "F" head ?? 7040256, 7040253
  149. olds tach
  150. 8.5" 10-bolt Posi Rear Axle
  151. Dash and engine harness
  152. 66 442 bumper filler
  153. Seeking OEM convertible boot slide rail
  154. steering column
  155. 76 Olds 455 engine
  156. 1968 cutlass convertible center console auto tranny
  157. Oil Slinger
  158. 1949 Olds rear center section 3.42 - 3.23
  159. dash pad 68 98
  160. Looking for Power Antenna Escutcheon !
  161. 1972 Supreme wheel well molding
  162. Top control switch, sun visor...
  163. side mirror
  164. 1967 442 Parts
  165. WANTED: Windage Tray
  166. 1968 98
  167. correct conv boot snaps
  168. Need '66 Toro Hubcaps!
  169. Need at least one door, two would be great
  170. Wanted: 1956 Olds Super 88 fender to firewall strut bar
  171. hub cap key for a 80-84 delta 88
  172. Vista / cutlass wagon rear air deflector
  173. SS-IV Polycast Wheels
  174. 1967 442 Hood
  175. WTB 3711 Choke & EGR Block-Off Plates/Gasket/Bolts
  176. 1973 Cutlass Supreme Parts Wanted
  177. 1972 Cutlass Supreme Rocker Molding
  178. 1962 Dynamic steering column/turn signal switch pin
  179. 69 Cutlass Hood
  180. Need G-Body Rearend
  181. Stall/Gears/Intake/Cam
  182. 1968 455 dip stick tube
  183. 70-72 455 frame mounts
  184. 1966 cutlass hood edge trim - says "Oldsmobile"
  185. Parts needed for 1977 cutlass
  186. Wanted: 56 Buick Century parts
  187. 1968 442 convertible trunk molding
  188. 1965 442
  189. 1967 convertible window felts
  190. 70 Olds F85 Gas Pedal
  191. 67 Cutlass Trunk Rod Spring Needed
  192. 1968-1969 Cutlass Emblems
  193. '70 442 Grille(s)
  194. Wanted: Fender Skirts for 1959 Olds 98
  195. WTB 65 400 ci dipstick
  196. Needed 69 Cutlass speedo cable assembly
  197. Pushrods Needed
  198. WTB correct headrests for 66 442
  199. Center console for 1971 442
  200. Wanted notched valve covers and w z manifolds
  201. TH 400 Modulator line wanted
  202. 1965 Cutlass, 442, F85 Radiator Cowl Assembly
  203. Wanted 1969 442 w30 w31 olds type o 12 bolt posi rear end 3:42 code (tm)
  204. Wanted-- 1971 Cutlass Supreme Grill
  205. 1972 Cutlass Drivers Seat Cover Wanted - Back Part Only
  206. 71 cutlas long A/C duct valance
  207. XT stamped 14x7 steel wheel for 1970 442
  208. need driveshaft 69 442 auto
  209. Miscellaneous 72 Cutlass parts needed
  210. 455 crankshaft
  211. 65-66 glove box door latch
  212. 69 cutlass convertible parts
  213. WANTED: 1975 Cutlass LR AC LAP VENT GRN or BLK preferred
  214. 70-72 Cutlass/442 Dash Pad
  215. wtb grille/stone shield
  216. gas tank sending unit
  217. 1970 442 8 track
  218. back seat 1968 cutlass convertible
  219. Tranny Pan
  220. Need 69 AC dash pad
  221. 1973 delta 88 bumpers front/read wanted
  222. Side winder tach for 1966 442
  223. 1970 442 tach
  224. Need 68 Cutlass Drivers Side Door - Canada
  225. 71 Cutlass Core Support
  226. Need 2 groove power steering pump pulley 1971 Cutlass
  227. WTB Passenger Recliner Lever
  228. Lookinf for a 70 455 block code 30Mxxxxxx
  229. Looking for a 1970 OW transmision
  230. Front wheel drum brake hub
  231. Looking for door mirrors for 66 delta88
  232. 65 Delta Bumper
  233. Brake Master Cylinder/ Horn Relay
  234. 1966 cutlass gauges
  235. Crank pulley
  236. Need a drivers side seat belt 94 Cutlass Conv or compatible
  237. Parking brake equalizer
  238. piston
  239. 1970442 fenders
  240. One SSII Bolt on center caps
  241. 66 dynamic 88 parts
  242. Air Conditioner Delete
  243. Nice Vintage Keystone Classics 15"/ Need to Sell
  244. 70-72 Supreme/Conv lower quarters
  245. 1970-1972 NOS Hardtop "S" Quarter Panels
  246. 1965 Cutlass Automatic Floor Shifter
  247. 1941 Olds Hydramatic
  248. Rear Convertible Seat 1965
  249. Need two 15" rims - 71' Cutlass
  250. Need 324 heater hose plate (?)
