Crankcase baffle
I guess #555783 is the number for the crankcase breather that is in the upper block that connects to the outer road draft tube. I guess some people refer to this as the "beer can". Trying to find this part locally if possible.
I'll be dismantling a 1955 324 engine soon. If you haven't found this yet I'm thinking your describing the can shaped piece that fits under the valley pan at the rear of the block, correct? Did you get the crank bolt and washer yet?
John
John
