Crankcase baffle
Old Aug 10, 2013 | 12:34 PM
Olds Scott's Avatar
Crankcase baffle
Looking for a crankcase baffle for a 1955 Oldsmobile 324 engine in the SoCal area if possible. Wasn't with the engine when I purchased it and doing the rebuild.
Old Aug 16, 2013 | 05:22 PM
Olds Scott's Avatar
Part #555783 crankcase baffle if someone has one. That part and crank bolt with washer is only things that are missing off engine.
Old Aug 17, 2013 | 10:20 AM
Olds Scott's Avatar
I guess #555783 is the number for the crankcase breather that is in the upper block that connects to the outer road draft tube. I guess some people refer to this as the "beer can". Trying to find this part locally if possible.
Old Sep 2, 2013 | 03:47 PM
2blu442's Avatar
I'll be dismantling a 1955 324 engine soon. If you haven't found this yet I'm thinking your describing the can shaped piece that fits under the valley pan at the rear of the block, correct? Did you get the crank bolt and washer yet?
John
Old Sep 2, 2013 | 06:49 PM
Olds Scott's Avatar
That is exactly what I am looking for. And no I have not found the crank bolt and washer. PM me when you get a chance.
DeltaDevil88
May 13, 2011 12:33 AM
dman0712
Nov 22, 2010 06:35 PM
Insom
Oct 16, 2010 07:52 AM
gtonut57
Aurora
Jan 1, 2010 01:35 PM
65cutty
Feb 24, 2009 05:18 AM
