Need '66 Toro Hubcaps!
Looking for a nice set of '66 Toro hubcaps.....I have a set of 15" wheels for my '67 Delta, and need these caps as they were what Olds used with this option. Thanks!
Erik
Here's what I've been able to find. The one on the left has real bad curb rash. The one on the right does too, but not as bad. The two closeups are of the one on the right. Let me know if this would be usable to you.
John
John
Assuming your fitting the rims from the Delta onto a Toronado, can I first recommend you test fit those rims first. The Toro had a zero offset wheel so the Toro and El Dorado wheels are specific to E-bodies only and aren't really interchangeable with other GM products.
Or, if you'r just trying to get a dog dish look on your Delta, than first test fit the Toro cap to your Delta steel wheel to make sure it fits first. I through the Toro cap was unique to the E-body rims.
The '66 Toro cap was used on the '67 Delta when the rarely order disc brake option was chosen. At the time, olds didn't have a 15" hubcap, so they used the '66 Toro cap. Yes, they do fit on the upgraded 15" rim for the B bodied cars.
