1949 Olds rear center section 3.42 - 3.23
Old Jul 20, 2013 | 12:27 PM
snkbte's Avatar
Looking for a good center section with either 3.42's or 3.23's. Will buy outright or swap for the current one in my car. it is a 4.11 rear, and quiet as a mouse. Email me with what you have.
csx1965@Comcast.net
Old Jul 20, 2013 | 04:33 PM
Threejdsolds's Avatar
I have a 1953 . Will that interchange with the 1949 ?
Old Jul 20, 2013 | 07:51 PM
snkbte's Avatar
From what I have read, 47 through 55 are all interchangeable. What gear ratio is the one you have ?
Old Jul 23, 2013 | 11:48 AM
I will check the gear ratio and let you know. John
Old Aug 2, 2013 | 05:03 PM
snkbte's Avatar
Bump to the top. Thanks.
Old Sep 19, 2013 | 08:37 PM
snkbte's Avatar
Still in need of a center section with 3.23 or 3.42 rear gears. Someone has to have a spare one they are willing to part with.
Email me at
csx1965@comcast.net
Old Oct 9, 2013 | 06:59 PM
snkbte's Avatar
Bump to the top....still looking
Old Oct 9, 2013 | 10:51 PM
I will try to get pictures of my 53 rear end posted this wknd.John
Old Oct 9, 2013 | 11:35 PM
Ozzie's Avatar
Exclamation Be careful
If you want to exchange the carrier assembly as a unit, the 29th Hollander says that from late '49 to '52 (8 cyl. cars) will interchange. (Hollander number 525). It has the filler plug in the carrier and has 7/16" bolt holes. For Hydramatic the ring/pinion teeth counts available are: 39-10; 40-11; 41-12; 42-13; and 40-13. It also says that the Hollander number 523, late '49-56 Pontiac will work if you drill out the 3/8" holes to 7/16". On some the carrier caps must be ground a bit for clearance.
Old Apr 19, 2014 | 02:16 PM
snkbte's Avatar
Thanks for the information Ozzie. I am still looking, but nothing yet. Now that the good weather is here, I' d really like to change the rear end. Anybody have one they are willing to part with ?
88charlie
Apr 4, 2014 01:18 PM
1977 C-10
Feb 26, 2014 07:41 PM
warrior71
Nov 2, 2013 07:17 AM
therobski
Aug 3, 2010 01:42 PM
MN71W30
Mar 2, 2009 06:34 PM
