PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1966 10 bolt 8.2 antispin rear axle
  2. 57 super 88 parts
  3. 1958/57 pitman arm
  4. 1972 Alternator
  5. WTB - 1987 custom cruiser voltmeter gauge (GM 25016601)
  6. Wanted 1969 Cutlass/442 front bumper and brackets
  7. WTB 1967 Cutlass Headlight Switch Bezel
  8. I need Rocker Molding
  9. 1972 Cutlass Supreme
  10. Sport mirrior
  11. 1966 toronado
  12. Right rear lower door molding for '55 88
  13. looking for a fitting, 1969 Cutlass
  14. Rear bumper
  15. Wanted: 1970 Cutlass Voltage Regulator
  16. 1967 Cutlass Parts
  17. 7040251 carb wanted
  18. antenna
  19. 67 Cutlass Steering Wheel Trim
  20. Wanted-NOS front wheelwell molding 230924
  21. 72 cutlass pillar cover
  22. 1967 442
  23. 73-77 3.73 posi rear
  24. 1964 Cutlass exterior bottom trim piece
  25. wtb.1975 center console{red)dash(red)
  26. WTB 1956 inner fenders and splash panels!
  27. Wanted 65 cutlass parking brake warning light
  28. 1965 Oldsmobile 98 Throttle Control Switch
  29. 57 371 Dual Quad intake
  30. Wanted: 1970 Cutlass Supreme Hood Spear
  31. N93 Wheels for 1964/65
  32. 67 cutlass A/C vents
  33. WTB 71/72 Cutlass backup light housings
  34. 1969 442 spare tire hold down
  35. 1970 fm stereo Mutiplexer wanted
  36. 1970 a/c car alternator brackets 455
  37. Jetstr 88 fender
  38. Wanted 1963 Cutlass Jetfire NOS parts and rear bumper!
  39. 455 Block
  40. 1971 Axle Shaft
  41. WTB - 70/71/72 AM/FM Radio
  42. Wanted 70-77 nos or mint sport wheel
  43. Oai hood
  44. Stock air cleaner wanted
  45. Beatup 63-65 side mirror
  46. 69 Center AC opening cover
  47. 1972 olds delta 88 royale conv
  48. 1969 N34 steering wheel cap
  49. Powermaster xs 9510
  50. Wanted Trunk Floor
  51. Looking for floor plan sections for 1974 Cutlass
  52. '63 4 speed parts needed
  53. 64 starfire front brake dums
  54. 67 hood molding&antenna cable
  55. Olds 455 main caps and bolts
  56. 1966 Cutlass Hood Wanted
  57. wanted 85 Toronado Grill
  58. Rochester Q-jet #7040255
  59. 1970 Delta 88/98 hood
  60. 67 Cutlass front bucket seats
  61. Column drop gasket
  62. switch pin turn signal
  63. Package Tray Sheet Metal For a 70 442 Holiday Coupe
  64. 77 Cutlass Black brougham seat
  65. WTB seat belts for my 63 F85
  66. 69 Cutlass fender eyebrow needed
  67. 1970 442 muncie 4 speed parts needed
  68. 1965 Cutlass AM/FM
  69. 1971 Cutlass Supreme
  70. Wanted 71-72 Cutlass Hood without grills
  71. Fbody 403 Accessory brackets
  72. blower intake
  73. 1971 442 4 speed intake
  74. Door sill plates
  75. 69 Cutlass Glove Box Swing Stop
  76. 1972 Cutlass Supreme Reverse Light Housing
  77. Stainless trim for 68 sport coupe
  78. '69 Air Cleanet
  79. WTB 69 Cutlass S trunk lid trim
  80. 1970 442 Driver Quality Black Bucket Seat Headrests for Pick-up at Olds Homecoming
  81. 1970 442 Driver Quality Rear Bumper for Pick-up at Olds Homecoming Show
  82. Need rim for 1970 Pace Car
  83. 71 S door panels
  84. 68 Cutlass 442 Parts Wanted
  85. 1965 cutlass 442 battery bracket
  86. 1970 Headlight Mounting Set
  87. 69 442 Sports Coupe parts needed
  88. 1964 or 65 f85/442/cutlass speaker hole cover
  89. 62 Jetfire trunk emblem wanted
  90. '70-72 Tic Toc Tach - Suitable for Parts
  91. Speedometer
  92. 1111982 dist.
  93. Wanted: oil pan for 1964 Starfire 394
  94. 1967 floor shift Bezel
  95. Wanted: Convertible Interior Pieces - Gold
  96. 72 Supreme interior door handle mechanisms
  97. 61-63 Oldsmobile wheels
  98. 1983 Cust. Cruiser pass. door top molding
  99. 1964 394 cui STD Main/rod bearings needed
  100. NOS EGR Valve wanted
  101. 65 Jetstar 88 bumper brackets
  102. 2bbl intake for 350 near cleveland
  103. 1959 Ashtray light
  104. 66-67 Cutlass dash panel
  105. Seats
  106. Door hinge Spring
  107. Standard bore 455 high compression pistons
  108. Crossmember
  109. Wanted: 1970 442 Alternator - 1100890
  110. Wanted 7040255 carb
  111. 80s B wagon RH parking lamp
  112. 1970 442 sport mirrors
  113. 6.70 X 15 tire
  114. WTB: Misc. Parts fo 71 W30 Restoration
  115. WTB: 94 Cutlass Convertible Interior Parts
  116. 1971-72 Cutlass front bumper
  117. Wanted: '75/'76 Olds 455
  118. Looking for 58 Super 88 stuff...
  119. 1969 Cutlass door glass
  120. 1961 f85 wagon deluxe fenders
  121. WTB RH 1970-72 cutlass quarter panel
  122. 68 Cutlass S Hood Hinges needed
  123. WTB 77 Cutlass quarter panel
  124. WTB 72 442 Cutlass Hood with scoops
  125. WTB 70 sport mirrors
  126. side mirror
  127. wanted 71-76 B-body rear sway bar
  128. Wanted: 1957 Oldsmobile radiator
  129. Vent window regulator
  130. 1970 rally pack gauges
  131. 75 Cutlass Supreme upper door panel
  132. Sealed power lifters wanted HT-957
  133. 71 4 Speed Parts
  134. WTB Pulleys and brackets for 350 to 455 (tall valve covers)
  135. toro headlight bezels
  136. Looking for quadrajet parts
  137. Wanted: Dashboard and hood chrome for 1970 Cutlass Supreme
  138. 1967 442
  139. WTB: Long head bolt for 455
  140. Antenna Mount for '66 A-Body
  141. 70-72 clutch pedal assembly
  142. Looking for Driver-Side Door Glass for 1975 Cutlass Surpeme!
  143. 1969 Oldsmobile 442 Steering Column clip wanted
  144. Olds N93 wheels
  145. WTB Vent Window Crank Handles
  146. Fender
  147. '48 98 deluxe steering wheel parts
  148. 1965 cutlass am radio
  149. 70-72 Vista Cruiser rear bumper
  150. 72 98 hood cable and dash lens
  151. Cutlass salon sedan body parts
  152. 67 442 Proportioning Valve Drum Brakes
  153. Sidewinder tach
  154. High imprtance... 9.3 olds full size ring and pinion needed. 2.93 3.08 3.23 3.42
  155. W-31 pistons
  156. 403 short block
  157. Wanted: 1970 442 rear bumper NOS
  158. Wanted KA M21 transmission tag
  159. 1965 Cutlass F-85 frame
  160. Wanted: 7040257 carb
  161. 70 Olds 442/cutlass/Vista Cruiser Parts Needed
  162. New power window switches
  163. Wanted: 1964 Olds 88 bumpers and trim clips
  164. Need Frint Bucket Seats for my 1975 Cutlass!
  165. Need Power Brake Booster for 65-66 Full Size With Manual Transmission
  166. Wanted Hurst mud flaps
  167. 1969 442 hardtop power window set up
  168. Olds 12-Bolt 3.23 Posi Rearend
  169. '67 442 Instrument Cluster
  170. 70-72 cutlass lower A/C vent panel
  171. WANTED Firestone Drag 500
  172. PC 1967 Cutlass A/C blower switch
  173. NEED" 65 Cutlass 442 rear back up lights
  174. Needed '65 D/S rear lower quarter
  175. 455 misc. engine parts
  176. 1970-1972 Cutlass wagon parts
  177. WTB Carb 7041253
  178. Wanted - 1965 Jetstar 88 Convertible Peak Molding
  179. Alternators wanted
  180. 72 Power trunk actuator / solenoid
  181. 69 Cutlass
  182. 66 park brake light
  183. 1964 Cutlass wheel arch trim
  184. 1970 idiot light fuel gauge assembly
  185. 1985 Calias hood needed.
  186. 72 Cutlass S split bench seat covers
  187. 70-72 Fender Supports for 455 Cars
  188. Wanted - 1969 Cutlass 442 convertible Torque Box
  189. kick down cable clip/ timing tab
  190. 1956 headlight cups / rings
  191. Wtb
  192. '67 driver side hood hinge or pair
  193. 76-77 cutlass 2 door sill plates
  194. 67 Cutlass Washer Bottle Cap
  195. Rear Spoiler- original
  196. 1970 Cutlass Blue Dash Pad
  197. 68-72 B pillar trim, 4 door/wagon
  198. 70-72 cutlass RH 1/4 panel
  199. *Wanted - 1965 442 Left Front Fender Eyebrow Molding,
  200. 67 330 Oil Dipstick Needed
  201. Throttle linkage bracket
  202. Switch Pitch Torque Converter
  203. In search of u shaped rubber front piece 8 track 69-72
  204. Sport steering wheel 9758389 horn button tan /camel
  205. 1964 Starfire rear w/o mouldings, misc. body moulding clips
  206. 67-69 Auto Console top plate
  207. WANTED: 64-67 seat belts (BLACK)
  208. NOS rear license lamp lens
  209. 1948 olds 68 4dr drivers glass and channel
  210. BOP 8.2 caps
  211. Door Lock Rods
  212. WTB: LH quarter panel for 72 Supreme
  213. battery tray for 65 Cutlass
  214. 67 front fender wheel mouldings
  215. Front license plate bracket
  216. 56 Olds Holiday backup light
  217. 1968-69 Vista Cruiser/Cutlass Cruiser parts needed
  218. Need fan & spacer & pulleys for '66 Toro
  219. 68 98/B-body parts, plus Bucket Seats
  220. Looking for Hardened center front crank bolt - 68 455
  221. WTB-1970 Sport Mirror base
  222. Need a '62 Brake Drum Vibration Damper Spring
  223. '64 Big Car Chin "Spoiler"
  224. WANTED>65 DELTA 88 Grommet
  225. 1974 HO W30 Parts Needed
  226. ISO Quadrajet Air Horn
  227. 1970 Cutlass cruise control parts
  228. Searching for a posi rear for 1968 Oldsmobile 98 coupe. Please help?
  229. 1970 Cutlass body side molding
  230. ISO 68-69 Cutlass rear window defogger switch
  231. Wtb power steering reservoir
  232. Seeking a '70-72 442 air cleaner base
  233. 1970 Alternator #890
  234. 1970 #879 Alternator
  235. Interior for 1963 F-85
  236. Need '71-72 Cutlass front bumper
  237. wanted 70 wing
  238. Exhaust manifolds wanted
  239. BBO script valve covers
  240. Wanted: Edelbrock script valve covers
  241. Olds 215 Offenhauser Valve Covers
  242. Edelbrock Intake and Disc Brakes
  243. Toro hub cover
  244. Need original 1971 cutlass hood hindges , both
  245. Finding parts for 72 cutlass supreme
  246. 91 OCC cladding
  247. 72 cutlass supreme rear window trim needed
  248. Rear Bumper Braces, 66' 442/cutlass
  249. '70 442 TH-400 Trans Dip Stick
  250. 1970 Coil Bracket - Used or NOS
