67 442 Proportioning Valve Drum Brakes
Old May 17, 2018 | 03:14 AM
4-Speed's Avatar
Looking for a decent, original drum brake proportioning valve for 67 442-
thanks-
Dave
Old May 17, 2018 | 05:03 AM
toymobile's Avatar
I may have one, if it will stop raining I will check.
Johnny
PS I can't find what I think you are looking for, I must have thrown it away.
Old May 17, 2018 | 05:25 AM
ROCKETMAN269V's Avatar
Drum brake cars do not have a proportioning valve; they simply use a junction block to connect the lines together.
Old May 17, 2018 | 08:14 AM
lemoldsnut's Avatar
I have several
Larry
lemoldsnut@aol.com
Old May 17, 2018 | 09:00 AM
^^^THIS!
The distribution block has a differential pressure switch, which is simply a piston that slides one way or the other and trips a switch if you lose pressure in one side of the system. This makes the BRAKE light on the dash come on - usually right as your foot goes all the way to the floor.
More to the point, even factory 1967 A-body DISK brake cars do not use a proportioning valve. They use a metering valve that delays application of the front brakes slightly to allow the rear drums to take up all the slack in the actuating links before the front disks start to apply. This is NOT a proportioning valve. The prop valve changes the ratio of pressures between the front and back brakes. The 67 full size disk brake cars DID use a prop valve in addition to the metering valve. The A-body cars did not use a prop valve until the 1971 model year.
Old May 17, 2018 | 10:54 AM
jollyolds's Avatar
pm sent
Old May 17, 2018 | 05:11 PM
Rocketguy's Avatar
. . . . . a metering valve that delays application of the front brakes slightly to allow the rear drums to take up all the slack in the actuating links before the front disks start to apply.
Joe,
What is the difference between this and a residual pressure valve?
Old May 17, 2018 | 05:36 PM
Originally Posted by Rocketguy
Joe,
Both are spring loaded check valves, but with flow restrictions in opposite directions. The residual pressure valve holds pressure in the line between the valve and the wheel cylinders. The metering valve holds pressure in the line between the valve and the M/C.
Old May 17, 2018 | 05:58 PM
4-Speed's Avatar
You guys are great! thanks for all of the info, Ill contact my friend and confirm exactly what he's looking for and get back-
Thanks-again
Dave
Old May 17, 2018 | 07:30 PM
66-3X2 442's Avatar
The 67 distribution valve/block is available new. I think I got mine from The Right Stuff. No need to buy used when a new unit is available.
Magna86
Jun 6, 2014 07:40 AM
Oldssupreme
Jan 29, 2013 07:03 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
