PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88
  1. 1964 jetstar 88 conv. rearwell trim
  2. 72 Glove Box wanted
  3. Center Console (dual gate) Non-restored
  4. Rear Bumper 442 style (w/ cutouts) USED
  5. In need of a set of front door panals for a 72 what ya got??
  6. Kace
  7. AC Brackets Needed
  8. Need Engine
  9. Aftermarket oil pan
  10. 53 Olds Sillplates
  11. '75 Omega backup lights needed
  12. 76 Cutass S (73-77)
  13. I don't know what it's called....
  14. 1970 cutlass 4 core radiator top plate
  15. Stamped "Oldsmobile" Valve Covers
  16. 1970 cutlass conv.
  17. Rear window trim, 77 supreme/salon
  18. oldsmobile cylinder heads
  19. 1967 CS -front license plate bracket
  20. 1967 c/s left rear bottom quarter trim & f85 rr ww trim
  21. cam
  22. 74-75 Delta Conv rear upper panels
  23. 74-75 Delta Conv rear upper panels
  24. Wanted>66/67 a/c-heater control panel
  25. WANTED: wheels for my 1972 Cutlass
  26. 71-72 Ram-air hood wanted
  27. WTB: 4v Intake Manifold and Carb for 330 (1966)
  28. 1980 cutlass supreme gauge cluster
  29. 64 olds dynamic 88
  30. Front Upper Control Arms 65, 66 or 67
  31. 64 Old Dynamic 88
  32. 71-72 Cutlass Lower AC Valance
  33. HORN for 1951 Oldsmobile '98. 6 volt
  34. WTB:66 Cutlass transmission cross member
  35. Wanted: Misc Cutlass parts/exhaust manifold
  36. 1961 Olds 88 Clock
  37. 71 455 carb + intake
  38. 66 or 67 E Block Needed
  39. Steering Wheel 1986 Olds Full Size
  40. ALMOST THERE body parts needed
  41. Wanted: 1962/1963 Olds Jetfire parts:
  42. 55 98 REAR SEAT with arm rest
  43. 67 68 69 3sp floor shifter & speedo
  44. WANTED: Intake Bolts With Stud
  45. 72 Cutlass Parts Wanted
  46. dash vents
  47. Dashboard/Glove Box area
  48. 1957 Olds 88/98 Parts FS;
  49. 1972 Cutlass eyebrow molding
  50. 72 cutlass supreme bumpers
  51. 64-66 simulated wood steering wheel
  52. 68-69 Red Fenderwells
  53. Trunk Torsion Bar - 67 Cutlass
  54. Head light Switch Harness
  55. 66 Toronado Fender Trim Needed
  56. 66 olds toronado dash pad needed
  57. 70 Dash Pad
  58. 1951 Olds HORN, 6 volt wanted
  59. parts wanted
  60. A/C Parts Needed
  61. '51 Olds 6 volt HORN wanted.
  62. Single D Head
  63. '65 442 A/C Control Needed
  64. Sill Plates for 65 Starfire
  65. 1973 olds 98 parts wanted
  66. front bumper
  67. Instrument Dash Cluster
  68. Harmonic Balancer
  69. Need windshield wiper arm for 1971 Cutlass S
  70. 75 Delta glovebox hinge
  71. Wanted - 57 Olds 371 oil pan
  72. 1966 Olds Delta 88
  73. 1966 Oldsmobile Starfire
  74. 1966 Oldsmobile 88 Dash Pad
  75. Exhaust Manifold Parts Needed
  76. Exhaust manifold parts needed
  77. 1967 olds delta 88 parts needed
  78. Qjet nothing special
  79. 67 Cutlass Trunk Trim
  80. 62 Full-size Bumpers
  81. 68-69 F-Eightyfive fender emblem
  82. 455 a/c brackets
  83. Timing tab/pointer for 72 350
  84. 65 cutlass steering wheel center
  85. Brass Adapter T Fitting
  86. NEEDED L FENDER for 68 442
  87. 65 remote mirror
  88. 72 sport mirrors
  89. 1971 Delta 88 trunk molding...
  90. 64 cutlass parts
  91. big block wanted in Alabama
  92. 65 442/Cutlass parts needed
  93. back seat anyone ??????
  94. Oldsmobile 1966 1970 Interior Lock Replacement Kit 2
  95. 307 eingine
  96. 1970 Bumper
  97. WTB : 68 Cutlass/442 headlight housings
  98. Manual tranny for a '71
  99. I want anything for a 71-76 delta 88
  100. Passenger side mirror
  101. Deluxe chrome mirror
  102. 1958 Olds 98 Parts Needed
  103. 67 Bumper Jack Wanted
  104. 66 330 Timing Case Cover
  105. distributor cam 394
  106. 66 cutlass 1/4 windows & runchannels
  107. 1960 Olds Air Conditioning
  108. working covert. pump/motor
  109. Wanted 1972 442 NOS Passenger Front Grille
  110. Piece of Rear Quarter
  111. Parking brake switch
  112. Tri-power
  113. wanted! 70 toronado interior mirror
  114. 74 delta tail light wanted
  115. Olds 350 headers
  116. 1970 Vista cruiser brake drums
  117. 66 Cornering Lamps
  118. 69 Delta 88 hood
  119. 62 Dash Trim
  120. Edelbrock intake manifold and carb wanted!!!
  121. Need Seatbelts
  122. WTB Clock Delete Panel
  123. Brake hose bracket "Retainer"
  124. WTB O type 3 series carrier
  125. Need radio delete plate for a 70 Cutlass S
  126. Want to trade? I need 70-72 AC Vents (L+R)
  127. Looking for a few things
  128. Sport Mirrors
  129. Wanted: steering wheel for a 1973 Olds 98
  130. Wanted 1968 Cutlass S Passenger Fender
  131. BBO WZ exhaust manifolds
  132. 65 cutlass dash bezel
  133. WTB:1964-65 Steering Wheel
  134. "OLDSMOBILE" trunk/hood letters
  135. parts wanted
  136. 67 delta 88 bumpers
  137. I need a single 15" SS3 wheel with a bolt on cap.
  138. BBO intake manifold wanted!!!!
  139. olds 350
  140. Need a Oil Pan for an Olds 455 in SOCAL
  141. Turbo 400
  142. 1987 Cutlass Ciera Cruiser RH Headlight Door
  143. 66 442 3:55 Posi Wanted and......
  144. wanted 70 cutlass hood extensions.
  145. 66 442 rear carpet
  146. WTB bumpers
  147. WTB--1973 olds 98 headlight bezels
  148. 68 Standard F85 Door panels
  149. Alternator/PS brackets from 403's in Firebirds
  150. 72 442 Dash Steering Column Bezel
  151. Rally pack Bezel 67 66 442
  152. 69 442 rear window glass
  153. 1962 oldsmobile convertible parts
  154. Experience shipping parts to Europe?
  155. Parts needed for 72 Cutlass Convertible
  156. NOS quarter panel needed
  157. WTB: Fiberglass Bumpers for '65 442
  158. Charcoal filter cannister
  159. 68-69 #5 heads
  160. 1972 Cutlass Fan Shroud
  161. Bumper for Dynamic 88 convertible
  162. 70 cutlass front brake line bracket &fastener
  163. 64-65 Cutlass-throttle linkage
  164. 69 442 holiday coupe tinted door glass wanted
  165. Parts for F-85 1963 wanted
  166. 1970 442 convert. bucket seat parts
  167. Frame wanted for 1960 Super 88
  168. Rim Blow Wheel
  169. 71 cutlass supreme
  170. WTB: 14 x 7 SSI's
  171. 1968 442 distributor
  172. 71/72 442 ac evaporator
  173. parts needed
  174. Need LH Mldg 67 Cutlass
  175. 71 Cutlass Tailight Lenses
  176. Wanted-- 68-71 GM seatbelts-- Black
  177. 68-70 Big Car (88-98) front disc brakes
  178. wanted 67 cutlass parts
  179. valve angle cutter --carbide tipped
  180. Black rear seatbelts w/stagecoach
  181. Need Holley carb
  182. Need 72 cutlass parts
  183. need 308 or 29? for a 65 cutlass
  184. Need V8 Starter Brace
  185. 1968 delta 88 hub
  186. flexplate for 1966 olds 330
  187. 1966 425 Quadrajet Carburetor
  188. Shoulder belt buckles-2, rt. backup lens
  189. parts needed please
  190. parts needed
  191. need rear of hood chrome for 71 cutlass
  192. Good fender
  193. Clam shells needed
  194. Front license plate bracket.
  195. Transmission housing
  196. wanted: front fender script "Toronado" from '68 or '69
  197. wanted: rear fender script "Ninety Eight" from '67 or '68
  198. Taillight for '67 98
  199. My W30 harness burned and caught on fire
  200. KA waterpump pulley
  201. wtb 455 rods
  202. front grills 80 olds
  203. wtb aluminum intake 455 & 350
  204. WTB O4B Spread Bore Edelbrock Intake
  205. wanted 1972 truck lid for a cutlass supreme
  206. WTB: 1978 98 oil pan
  207. Need a 1972 Cutlass battery tray
  208. 50 Olds 88 drivers 1/4 molding
  209. Wanted parts for 1964 Oldsmobile Starfire convertible
  210. 68-72 cutlass bucket seat trackes
  211. ignition
  212. 1) 15" chrome rally rim
  213. 403 Olds
  214. Bucket Seat Adjuster Springs
  215. Red Air Cleaner 425 high comp Rocket
  216. Compressor Brackets for 1971 Cutlass 350
  217. 1969 ORIGINAL BLACK 442 seat belts
  218. Glove Box Lock & Key / Power Steering Pump / Fan Clutch
  219. 54 olds front seat
  220. 1966 delta 88 dr side fender
  221. bucket seats
  222. 1964 Jetstar 88
  223. Transmission Dipstick Tube
  224. power steering pump
  225. Edelbrock Olds 455 Performer RPM Heads
  226. 51-52 fender
  227. Need RH remote mirror 1977 model 98
  228. 73 cutlass power steering pulley
  229. NEED front TURN INDICATOR ASSY 59 OLDS
  230. wanted 1987 cutlass blue console lid
  231. 70 cutlass center console
  232. Cruiser control cutlass supreme 1967
  233. 1964 F-85 4 door glass regulator channels (?)
  234. performer intake manifold for 455
  235. wtb 442 center caps
  236. 1971 cutlass rear bumper bolts,nice used or NOS
  237. need parts for 72 auto console
  238. '68-'72 Olds wagon tailgate trim
  239. 69 Blue interior parts
  240. 71 fenders and doors
  241. WTB Blue arm rests
  242. Wanted!-78-80 Cutlass Supreme Rear Bumper, Chrome Mirrors and Maroon drivers A Pillar
  243. fan shroud
  244. wanted parts for a 1977 cutlass
  245. Wanted: 1964 F-85 dog dish hubcaps
  246. 1970 Cutlass S body moldings
  247. 1958 olds
  248. Wanted: 1962/1963 Olds Cutlass F85 4 speed trans mount.
  249. 1966 Olds 98 Speedometer
  250. wiper switch
