View Full Version : Parts Wanted
- 69 h/o SJ rear
- Bench release lever 69 cutlass
- 1965 Cutlass 2 speed wiper switch
- Wanted: 1975 Cutlass parts for Hurst/Olds project
- 68/69 442 Gold auto console
- Night Watch
- 1968 Cutlass Non AC Dash Pad in Perfect Condition
- 70-72 Cutlass Rocker Panel Molding
- wanted 68 442 hood
- Omega parts, 7" 425 rods, wanted
- Wanted 36 Olds couple parts
- 1977 olds cutlass dash
- 63 super 88 holiday starter
- 69 a-body Disc brake spindles
- Wanted single d head to trade for f head
- Windshield Washer 64 f-85
- Wnated Pair of Working 1970 Cutlass Horns
- WTB 394 Olds 3x2
- Hei distributor
- Wanted: 68-72 Conv A Post Pillar Pads
- wanted
- 1965 2-door Delta 88 Front Windshield trim?
- Parts getting ready to move
- looking for 70 left eyebrow trim NOS
- WTB ignition switch
- dash bezel 1967
- Vista parts
- WTB: Transmission filler tube
- power antenna
- '65 f-85 parts wanted
- Help! Need G-body rear control arm bolts
- Parts For a 67 442
- A/C firewall sheet metal
- 1957,1958 Fiesta wagon liftgate,other glass+seats
- Gbody Items Needed to Complete Several Restorations
- 72 Cutlass
- 63 Delta mirror
- 72 tail light lense (lower)
- 13 inch wheel for '63 F-85?
- 71 vert sheet metal need
- 65 olds 442 body parts needed
- Cutlass bumper guards
- 62-64 394 Power Steering pump and brackets
- 62-64 394 exhaust manifold (single ex.) wanted
- reverse lockout rod
- Looking for 69 442 backup lights
- th400 longshaft dipstick tube
- Wanted: 70-72 Door panel hanger brackets
- 1972 cutlass parts wanted
- Reverse lenses, rear plate mount and chrome trim for 84 cutlass
- 69 h/o rear end
- 49 Olds Clutch Pedal Return Spring
- WTB OE 69 Husrt Olds top can
- 72 Cutlass Supreme Top windshield chrome molding
- Needed
- 1966 Oldsmobile Delta 88 Rear View Mirrors
- 1972 Cutlass Supreme Shifter Knob
- Frame Mounts/harness
- '65 Starfire carb or other 4 jet carb
- 65 F85 Junction block
- 1969 442 gas, temp, oil gauge
- 72 cutlass supreme convertible parts wanted
- Wanted: One hubcap and one door pull cap for 1971 Ninety Eight
- 57/58 CP Headliner bows Wanted
- 68 442 antenna
- 1968 Cutlass Heater Control Cables Non-AC
- Wanted: 67 Vista Cruiser parts
- 67 442 wire harness
- 71 -- need washer bottle and rad bottle
- Source for Carb Kits for 66 Tri Carb
- 4.33 Gears for 66 442 L69
- Black fenderwells wanted...
- power regulators for 62 starfire convertible
- parts wanted 63 f-85
- 65-70 88-98 drum brake spindles
- Edelbrock Performer 455
- Wanted 66 Cutlass/442 radio faceplate and radio
- 1953 88 sheet metal
- 1967 Right Hand Mirror Wanted
- Need gas tank 1964 vista cruiser
- 62' old 394 alternator bracket
- 1966 A-body Buckets and Tilt column
- 1966 dynamic 88 Wire wheel hubcaps
- Need '66 442 Valve Cover Breather
- 65 starfire tilt tele column
- OAI hood
- Need light socket for 72 Cutlass A/T console
- wtb 70-72 flapper door for OAI air cleaner
- Bill Piper
- 68/69 350 cast iron intake 4 bbl
- used good condition rear 1970 Cutlass bumper
- tires wanted
- 68 cutlass hood hinges
- 70 cutlass fenders
- 1969 A/T Console Wanted.
- Wanted!
- 1967 442 trim
- Looking for 2 speed Wiper Switch - 66 442
- 3.42 gears
- 455 dip stick
- Looking for c heads
- Engine anyone????
- Wanted>turbo 400 trans speedo gear 45 tooth
- Wanted: Windlace for a 70 442 Hardtop
- Wanted/NEED!: 68-69 442 400 90 degree fuel pump adaptor.
- G-body driveshaft in Chicago
- rear bumper needed for a 66 Olds dynamic 88
- Looking for exhaust manifolds for 394
- Alternator bracket for big block 1967 w/ps & AC
- 1980 Cutlass Supreme RH Headlight Bezel
- window stops
- 67 Cutlass tilt column
- Looking for a 1968 442 rear bumper
- Front piece above bumper
- 67 Cutlass
- 1970 Cutlass Supreme Convertible LH Rear Vinyl panel
- Need Drivers Side Rear Vinyl Panel
- 1965 cutlass/442 parts
- Goodyear Polyglas GT tire for trunk display
- Sport Steering Wheel horn plunger..
- 1981 Delta 4 door parts.
- 65 starfire window washer spray nozzles
- '74 Omega parts wanted
- g body exterior door handle insert decal?
- 1970 Cutlass throttle cable parts
- 1972 Cutlass Supreme Sport Mirrors
- 60 olds 98 ac brackets
- 10 Left handed lug nuts for my 55
- WTB 15x7 steelies
- 67 Cutlass or 442 upper tail light bezels
- 1968 air breather tube grommet
- 68 442 fan shroud needed
- 1966 Toronado Steering Column
- I need a Female Connector
- Want Tail panel
- looking for moulding for 65 f85 holiday
- LH Front Maroon Door Handle Assy 99 Aurora
- rear speaker brkt/hardware
- Alternator needed ASAP 1100880
- 1982 Olds 98
- 1967 442 Door Panel Emblem
- Need radiator top plate for 68 350 Cutlass
- Parts in Dallas
- 70 Passenger only sport mirror
- 68 Cutlass 4 core Radiator top plate
- 69 driver remote mirror
- Dash parts 65 delta 88
- 1965 cutlass lower passenger 1/4 patch
- 68 442 Grille
- 70-72 automatic console
- Whindshield Washer Nozzles (Squirters)
- speaker grille
- Need hood hinges for 71
- front dash speaker bracket 70 442
- 73 350 starter and 3 groove wp pulley
- 1965 Delta 88 Blower motor to heater core duct?
- 1966 Delta88 turn signal lenses
- Alternator bracket 394 1962-63
- Need Passenger Fender 67 Cutlass/442
- 324 2bbl air cleaner
- 79-85 Toronado Output Shaft Support
- WTB: Front armrest pad
- 69 drip rail molding
- 1968 Olds 350 Headers
- Need 1962 Olds 88 Dash Pad
- Dash Bezel for a 67 TH 400 needed
- TH350 Speedo driven gear
- Air cleaner base
- some extra equipment
- WTB power steering pump/bracket assy
- 1955 Super 88 Molding/trim
- WTB - Cigarette lighter assembly '63 F-85
- 1969 Cutlass disc spindle
- 455 Valves wanted
- 68 442 air cleaner emblem / pan
- Wanted 70 Cutlass seat belts
- wanted 1969 cutlass convertible passenger side door
- Wanted: 1969 442-400V8 Dip Stick (oil level indicator)
- Door Trim 1956 98: Chicago IL
- 68-69 400268,400269,or 400289 waterpump
- vista parts
- 72 Cutlass Convertible Top Switch (or rear window switch from Vista)
- AC Pulleys
- Edelbrock 065
- 1969 442 turbo 400 wire & trans plug!
- 68 442 left front lower control arm wanted
- Rally Pac 72 Cutlass
- 72 cutlass armrest bases
- WTB 68 waterpump
- WTB 68 930 Distributor core
- 4 barrel carb and intake
- rally pac 1969 442
- Plastic SSII center caps
- 1972 Toronado, (eldorado)
- 1962 Oldsmobile full size
- WTB Fan and Clutch
- Blower intake [671]
- 68-69 ac waterpump 400268
- '70 442 Parking Brake Lever
- Front bumper for '63 F-85
- sbo heads
- Wanted: rear axle bearing retainer plate.
- Glove box light for 71 Cutlass Supreme
- 1965 olds parts (delta 88)
- Wtb:1962 394 alternator brackets
- Driver Side Fresh Air Vent Baffle - 66 442
- 1969 442 convertible radiator core support
- Looking for A/C Parts and WZ manifolds
- ac part for 72 cutlass supreme
- 65 starfire exhaust tips
- 1972 cutlass supreme
- Wanted: Valve Spring Retainer
- 68/69 cutlass vert drivers side rear quarter trim
- Need turbo 350 slip yoke
- Wanted 1967 Horn Relay
- Edelbrock performer intake 2151
- rear body panel 67 Olds cutlass/442
- looking for Disc Brakes for a 1968 Cutlass S
- 1962 F-85 Steering Wheel WANTED
- Where to purchase Hurst Shifter T Handle
- Brake Drums 1957 Oldsmobile
- Wanted: 72 Cutlass th350 Detent Cable
- Rear bumper for 76 toronado
- Looking for 1966 442 trunk lid trim
- 350 main caps
- 1959 front/rear bumpers wanted.
- 62 starfire pwr seat switch needed
- 70-71 Cutlass SX Molding
- 68 Cutlass rear bumper
- Tail light lenses for 1963 98
- 1997 Aurora Interior Light
- AC Brackets for 70 Cutlass
- Toronado 1966
- Center cap insert
- carb wanted 1970 455
- WTB: SSII Wheel center cap
- 455 quadrajet wanted
- Clay
- Auto Meter Gauges with Oldsmobile Logo
- Steering Wheel
- turbo jetfire motor
- looking for 72 442 grills
- Door Armrest Bases - 69-72 WTB
- 1969 442 convertible question / radiator core support?
- Wanted 57 olds brake drums
- "A" casting big block heads
- 72 Cutlass S parts needed
- B Heads needed with T suffix
- Looking for 1966 frame 4 speed ao smith
