65 F85 Junction block
Old Oct 6, 2012 | 08:54 AM
darkcrave's Avatar
Im looking for a Oldsmobile Junction block new or used. Its the junction box on the driver side fenderwell. If anyone can help that would be great!
Please contact me
GMGiuffre@gmail.com
Old Oct 6, 2012 | 10:55 AM
oldstata's Avatar
Justin
Are you talking about the horn relay that has the junction for power ? If so fusik has new ones they are pricy tho 70.00 pulse shipping R203 part #
Old Oct 6, 2012 | 11:28 AM
darkcrave's Avatar
This is the bugger Im having issues with:
I have been searching google and ebay, with no luck
Old Oct 6, 2012 | 11:32 AM
oldstata's Avatar
Justin
Yep that's the hOrn relay look it up at fusik there pricy I been looking for a used one with no luck
Old Oct 6, 2012 | 11:39 AM
darkcrave's Avatar
Would this cause a issue starting? I cant start my car with the key. But if i bypass the wires coming from the firewall to the + i can basically hotwire my car
Old Oct 6, 2012 | 11:43 AM
oldstata's Avatar
Justin
Maybe not sure I wouldn't think so does your horn work ?
What wire are you jumping you could have a bad starter solenoid and you might be by passing it
Old Oct 6, 2012 | 11:51 AM
darkcrave's Avatar
My horn button is MIA. The two soild red wires i have bypassed to a switch to start it. I have always had this issue, I replaced the starter about 2 years ago.
Old Oct 6, 2012 | 11:57 AM
oldstata's Avatar
Justin
Mine is bypassed too not sure but my yellow /black wire is cut and I have a wire from key switch it power to start mine maybe some one can chime in I have not got to far on my wiring because the junction relay is missing
Sorry I couldnt be more helpfull
In theory that black wire with the blue butt connector if you ground that wire your horn should sound if you have good working horns and if the relay is good that black wire grounds the relay witch sends power to the green wire to the horns
Old Oct 6, 2012 | 12:10 PM
darkcrave's Avatar
Its needs relacing anyways, along with the harness. But ill see if it works and ill fill you in
Old Oct 6, 2012 | 12:15 PM
oldstata's Avatar
Justin
A quick way to test horns put power to green wire it will make you jump lol if they work mine did they were loud
mphyle0927
Nov 5, 2013 10:03 AM
cessna195
Feb 22, 2011 10:59 AM
whosyourdaddy
Nov 12, 2010 08:39 PM
64 Cutlass
Aug 1, 2009 06:22 AM
supersport
Jan 15, 2009 09:43 PM
